  4. Homekit in iobroker auf Synology - Installation bricht ab
    5.6k
3 Beiträge 3 Kommentatoren 1.3k Aufrufe
    dli
    leider bekomme bei der Installation des Homekit Adapters folgende Fehlermeldung. (andere Adapter kann ich installieren)
    Ich hoffe auf eure Hilfe, fange gerade erst an mit iobroker und diese Funktion ist für mich sehr wichtig.
    Meine Umgebung:
    • Synology ds214+ (iobroker)
    • CCU2
    <u>hier die Fehlermedlung:</u>
    $ ./iobroker add homekit2
    npm install iobroker.homekit2 –production --prefix "/volume1/homes/admin/opt/iobroker" (System call)
    gyp
    ERR! build error
    gyp ERR! stack Error: not found: make
    gyp ERR! stack at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)gyp
    ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp
    ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16gyp
    ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR! stack
    at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)gyp ERR! System Linux 3.2.40
    gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/curve25519gyp ERR! node -v v4.4.2
    gyp ERR! node-gyp -v v3.3.1
    gyp ERR! not ok
    gyp
    ERR!
    build error
    gyp
    ERR!
    gyp
    ERR! stack
    gyp ERR! stack at E (/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR!
    gyp ERR! stack
    at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    gyp
    ERR!
    System
    Linux 3.2.40gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
    gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/ed25519
    gyp ERR! not ok
    gyp
    ERR! build error
    gyp
    ERR! stack Error: not found: makegyp
    ERR! stack
    at F (/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)gyp ERR!
    ERR!
    stack at /usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5
    gyp ERR! stack at /usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5
    gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/mdns
    gyp ERR! not ok
    node-pre-gyp
    ERR! Tried to download(403): https://rvagg-node.s3-us-west-2.amazona ... a32.tar.gz node-pre-gyp ERR! Pre-built binaries not found for bignum@0.12.5 and node@4.4.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    gyp
    ERR!
    build error
    gyp ERR! stack at F (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:63:19)
    gyp ERR! stack
    at E (/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:72:29)gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/which.js:81:16
    gyp ERR! stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5gyp ERR!
    stack at /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5gyp ERR! stack at FSReqWrap.oncomplete (fs.js:82:15)
    gyp ERR! System
    Linux 3.2.40
    gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding/bignum.node" "--module_name=bignum" "--module_path=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding"
    gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignumgyp ERR! node -v v4.4.2
    gyp ERR! not ok
    node-pre-gyp ERR! build error
    node-pre-gyp
    ERR! stack Error: Failed to execute '/volume1/@appstore/Node.js_v4/usr/local/bin/node /volume1/@appstore/Node.js_v4/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding/bignum.node --module_name=bignum --module_path=/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/binding' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
    node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    node-pre-gyp
    ERR! stack at ChildProcess.emit (events.js:172:7)node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:827:16)
    node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
    node-pre-gyp
    node-pre-gyp ERR! command "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"node-pre-gyp ERR! cwd /volume1/homes/admin/opt/iobroker/node_modules/iobroker.homekit2/node_modules/hap-nodejs/node_modules/srp/node_modules/bignum
    node-pre-gyp ERR! node -v v4.4.2
    node-pre-gyp ERR! node-pre-gyp -v v0.6.32
    node-pre-gyp ERR! not ok
    npm
    ERR!
    Linux 3.2.40
    npm ERR! argv "/volume1/@appstore/Node.js_v4/usr/local/bin/node" "/usr/local/bin/npm" "install" "iobroker.homekit2" "--production" "--prefix" "/volume1/homes/admin/opt/iobroker"npm ERR! node v4.4.2
    npm ERR! npm v2.15.0
    npm
    ERR! code ELIFECYCLE
    npm ERR! curve25519@1.1.0 install: node-gyp rebuild
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the curve25519@1.1.0 install script 'node-gyp rebuild'.
    npm ERR! This is most likely a problem with the curve25519 package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR! node-gyp rebuildnpm ERR! You can get information on how to open an issue for this project with:
    npm ERR! npm bugs curve25519
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!
    npm ERR! npm owner ls curve25519
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:
    npm ERR! /volume1/homes/admin/opt/npm-debug.log
    ERROR: host.NAS-Westkirchen Cannot install iobroker.homekit2: 1
    Gruß Dennis</anonymous>
      papi
      Ich habe einen ähnlichen Fehler, nur bei mir ist es GIT, das wohl nicht verfügbar ist.
      GIT habe ich dann mittels Paketzentrum aus der Community nachgereicht, aber das scheint wohl nicht dasselbe zu sein, denn es änderte nichts?
      • apollon77A Online
        apollon77A Online
        Du brauchst make und nen Compiler … Musst also "gcc" oder so installieren ...
        Ich fürchte aber das es auch dann, falls Du das per ipkg oder so hinbekommst, nicht weitergeht weil gllaube ich gcc4.8+gebraucht wird, DU den aber für deine Synology nicht bekommst. Hatten ähnliche Probleme schon mit anderen Adaptern ... das sind die Liits des doch nicht "offenen" und "aktuellen" Synology OS unter der Haube" :-(
