  4. Amazon Dash fehler?
    6.7k
Amazon Dash fehler?
amazon dash
2 Beiträge 1 Kommentatoren 204 Aufrufe 1 Beobachtet
    denjo
    Hallo, ich habe ein update meines JS Controller gemacht auf Node.js v12.20.0 und nur läuft mein amazon Dash adapter nicht mehr, bekomme folgende Fehler meldung.
    host.raspberrypi	2020-11-28 09:47:19.445	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.raspberrypi	2020-11-28 09:47:19.445	info	instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
    amazon-dash.0	2020-11-28 09:47:18.907	info	(9839) Terminated (NO_ERROR): Without reason
    amazon-dash.0	2020-11-28 09:47:18.906	info	(9839) terminating
    amazon-dash.0	2020-11-28 09:47:18.865	info	(9839) cleaned everything up...
    amazon-dash.0	2020-11-28 09:47:18.864	error	(9839) Error: socket: Operation not permitted at new PcapSession (/opt/iobroker/node_modules/pcap/pcap.js:60:39) at Object.exports.createSession (/opt/iobroker/node_modules/pcap/pcap.js:131:12
    amazon-dash.0	2020-11-28 09:47:18.861	error	(9839) unhandled promise rejection: socket: Operation not permitted
    amazon-dash.0	2020-11-28 09:47:18.861	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    amazon-dash.0	2020-11-28 09:47:18.856	info	(9839) starting pcap session on default interface
    amazon-dash.0	2020-11-28 09:47:18.819	info	(9839) starting. Version 1.1.0 in /opt/iobroker/node_modules/iobroker.amazon-dash, node: v12.20.0, js-controller: 3.1.6
    host.raspberrypi	2020-11-28 09:47:16.883	info	instance system.adapter.amazon-dash.0 started with pid 9839
    host.raspberrypi	2020-11-28 09:46:46.839	info	Restart adapter system.adapter.amazon-dash.0 because enabled
    host.raspberrypi	2020-11-28 09:46:46.835	info	instance system.adapter.amazon-dash.0 terminated with code 0 (NO_ERROR)
    amazon-dash.0	2020-11-28 09:46:46.313	info	(9064) Terminated (NO_ERROR): Without reason
    amazon-dash.0	2020-11-28 09:46:46.312	info	(9064) terminating
    amazon-dash.0	2020-11-28 09:46:46.285	info	(9064) cleaned everything up...
    • D denjo
      denjo
      hat sich erledigt habe den fixer vergessen
