  4. IoBroker.admin # update auf 0.4.5
    5.3k
5 Beiträge 4 Kommentatoren 1.7k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    Das Update ist ohne Probleme gelaufen.
    admin-0	2015-04-25 08:51:05	info	received all states
    admin-0	2015-04-25 08:51:05	info	received all objects
    admin-0	2015-04-25 08:51:05	info	Use link "http://localhost:8081" to configure.
    admin-0	2015-04-25 08:51:05	info	http server listening on port 8081
    admin-0	2015-04-25 08:51:05	info	requesting all objects
    admin-0	2015-04-25 08:51:05	info	requesting all states
    admin-0	2015-04-25 08:51:05	info	starting. Version 0.4.5 in /opt/iobroker/node_modules/iobroker.admin
    host-raspberrypi	2015-04-25 08:51:00	info	instance system.adapter.admin.0 started with pid 3099
    iobroker	2015-04-25 08:50:59	info	exit 0
    iobroker	2015-04-25 08:50:59	info	Adapter "admin" updated
    iobroker	2015-04-25 08:50:58	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    host-raspberrypi	2015-04-25 08:50:58	info	instance system.adapter.admin.0 terminated with code 0 (OK)
    admin-0	2015-04-25 08:50:58	info	terminating
    iobroker	2015-04-25 08:50:58	info	upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    host-raspberrypi	2015-04-25 08:50:58	info	stopInstance system.adapter.admin.0 killing pid 2099
    admin-0	2015-04-25 08:50:58	info	terminating http server on port 8081
    host-raspberrypi	2015-04-25 08:50:58	info	object change system.adapter.admin.0
    iobroker	2015-04-25 08:50:58	info	got /opt/iobroker/node_modules/iobroker.admin/admin
    iobroker	2015-04-25 08:50:52	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.admin" (System call)
    iobroker	2015-04-25 08:46:20	info	npm install iobroker.admin --production --prefix "/opt/iobroker" (System call)
    iobroker	2015-04-25 08:46:18	info	upgrade admin
    host-raspberrypi	2015-04-25 08:45:45	info	Update repository "default" under "conf/sources-dist.json"
    derAuge
    • BluefoxB Offline
      BluefoxB Offline
      Super ;)
      • derAugeD Offline
        derAugeD Offline
        derAuge
        Hi
        bei der installation von vis wird diese in die Kategorie Allgemein verschoben und bleibt nicht in Visualisation
        derAuge
          pix
          bei mir ist jetzt DWD in der Kategorie Wetter und YR.NO nicht mehr. Vorher war es umgekehrt. Es gehören wohl beide in die Kategorie Wetter.
          Homematic passt auch besser in die Kategorie Hardware (wie KNX) und Graphite, Highcharts und Flot (später) in die Kategorie Visualisation. Das Wort Visualisation ist ja eigentlich ein englisches, in deutsch heißt es Visualisierung.
          Pix
            Hallo pix,
            bei mir ist alles so, wie du es willst!?
            Lediglich vis ist nicht unter Visualisierung. Sonst sieht alles gut aus.
            Rainer
