  4. Java-Script Adapter startet ab und an nicht -> DB?
4 Beiträge 2 Kommentatoren 735 Aufrufe
  • sissiwupS Offline
    sissiwupS Offline
    sissiwup
    Normaler Start:
    2016-11-16 04:05:48.691  - info: javascript.0 terminating
    2016-11-16 04:05:48.887  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
    2016-11-16 04:11:41.818  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 515
    2016-11-16 04:12:00.103  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
    2016-11-16 04:12:00.175  - info: javascript.0 requesting all states
    2016-11-16 04:12:00.186  - info: javascript.0 requesting all objects
    2016-11-16 04:12:09.147  - info: javascript.0 received all states
    2016-11-16 04:12:13.740  - info: javascript.0 received all objects
    2016-11-16 04:12:18.920  - info: javascript.0 Start javascript script.js.ereignisse
    2016-11-16 04:12:20.551  - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
    Start ohne Skripte zu initialisieren:
    2016-11-17 04:05:43.684  - info: javascript.0 terminating
    2016-11-17 04:05:43.916  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
    2016-11-17 04:11:37.940  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12174
    2016-11-17 04:11:56.047  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
    2016-11-17 04:11:56.129  - info: javascript.0 requesting all states
    2016-11-17 04:11:56.140  - info: javascript.0 requesting all objects
    2016-11-17 04:12:05.932  - info: javascript.0 received all states
    2016-11-17 04:12:10.809  - info: javascript.0 received all objects
    2016-11-17 04:13:59.884  - warn: javascript.0 Reconnection to DB.
    2016-11-17 04:14:00.630  - warn: javascript.0 Reconnection to DB.
    2016-11-17 11:42:06.763  - info: host.raspberrypi object change system.adapter.javascript.0
    2016-11-17 11:42:06.790  - info: host.raspberrypi stopInstance system.adapter.javascript.0
    2016-11-17 11:42:06.794  - info: host.raspberrypi stopInstance system.adapter.javascript.0 killing pid 12174
    2016-11-17 11:42:06.868  - info: javascript.0 terminating
    2016-11-17 11:42:06.965  - info: host.raspberrypi instance system.adapter.javascript.0 terminated with code 0 (OK)
    2016-11-17 11:42:09.386  - info: host.raspberrypi instance system.adapter.javascript.0 started with pid 12060
    2016-11-17 11:42:14.561  - info: javascript.0 starting. Version 3.1.0 in /opt/iobroker/node_modules/iobroker.javascript, node: v4.6.0
    2016-11-17 11:42:14.606  - info: javascript.0 requesting all states
    2016-11-17 11:42:14.613  - info: javascript.0 requesting all objects
    2016-11-17 11:42:20.738  - info: javascript.0 received all states
    2016-11-17 11:42:24.296  - info: javascript.0 received all objects
    2016-11-17 11:42:24.423  - info: javascript.0 Start javascript script.js.ereignisse
    2016-11-17 11:42:25.198  - info: javascript.0 script.js.ereignisse: DeviceST=ST-05:1.STATE
    (um 11.42 habe ich dann einen Restart des Script-Adapters gemacht. Er wird aber normal als running, ohne Probleme angezeigt)
    => Hat das warn: Reconnection to DB etwas zu sagen?
    MfG
    Sissi
    • BluefoxB Offline
      BluefoxB Offline
      @sissiwup:
      Normaler Start:
      => Hat das warn: Reconnection to DB etwas zu sagen? `
      Vermutlich ist der Adapter am Start so mit Skripten beschäftigt, dass er keine Zeit zum Kommunizieren hat. Und die Verbindung zum Controller wird abgebrochen.
      Versuche ein paar Intensivskripte mit setTimeout zu versehen.
      • sissiwupS Offline
        sissiwupS Offline
        sissiwup
        habe jetzt mal das "servicemeldungen" von paul53 deaktiviert.
        Kann sein, das seit dem ich das nutze, die Fehler auftauchen.
        Werde das mal beobachten. Danke für den Tipp.
        MfG
        Sissi
        • sissiwupS Offline
          sissiwupS Offline
          sissiwup
          Aktuell läuft er. Ich werde es weiter beobachten.
          MfG
          Sissi
