  4. Redis macht Probleme
    5.3k
4 Beiträge 3 Kommentatoren 2.2k Aufrufe
  • H Offline
    Heinzelmaennchen
    Hallo Bluefox,
    bei mir macht derzeit redis Probleme. Ich habe mal das Log eingefügt.
    admin.0	2014-12-21 14:09:33	error	Error: Redis connection to 127.0.0.1:6379 failed - connect ECONNREFUSED at RedisClient.on_error (/opt/iobroker/node_modules/redis/index.js:185:24) at Socket. (/opt/iobroker/node_mod
    admin.0	2014-12-21 14:09:33	error	Redis connection to 127.0.0.1:6379 failed - connect ECONNREFUSED
    admin.0	2014-12-21 14:09:33	error	Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED at RedisClient.on_error (/opt/iobroker/node_modules/redis/index.js:185:24) at Socket. (/opt/iobroker/node_mod
    admin.0	2014-12-21 14:09:33	error	uncaught exception: Redis connection to localhost:6379 failed - connect ECONNREFUSED
    admin.0	2014-12-21 14:09:33	error	objectsInRedis: Error: Redis connection to localhost:6379 failed - connect ECONNREFUSED at RedisClient.on_error (/opt/iobroker/node_modules/redis/index.js:185:24) at Socket. (/opt/i
    admin.0	2014-12-21 14:09:33	error	objectsInRedis: Redis connection to localhost:6379 failed - connect ECONNREFUSED
    admin.0	2014-12-21 14:09:33	error	Error: Redis connection to 127.0.0.1:6379 failed - write EPIPE at RedisClient.on_error (/opt/iobroker/node_modules/redis/index.js:185:24) at Socket. (/opt/iobroker/node_modules/redi
    admin.0	2014-12-21 14:09:33	error	Redis connection to 127.0.0.1:6379 failed - write EPIPE
    admin.0	2014-12-21 14:09:33	error	Cannot parse log object
    history.0	2014-12-21 14:09:29	info	history.0 moved 481 history datapoints from Redis history.b-control-em.0.Teridian_L1 to CouchDB history.b-control-em.0.Teridian_L1.20141221
    history.0	2014-12-21 14:09:29	info	history.0 moving 481 entries to couchdb
    history.0	2014-12-21 14:09:18	info	history.0 moved 481 history datapoints from Redis history.b-control-em.0.Sprechanlage to CouchDB history.b-control-em.0.Sprechanlage.20141221
    Momentan kann ich das Verhalten noch nicht nachvollziehen. Aber zumindest das Log sagt, dass es über history erzeugte Einträge nach Couchdb schicken will. Was natürlich nicht sein kann. Auch ein restart von redis hilft dann nichts mehr. Ich muss rebooten.
    Irgendwelche Ideen, was ich falsch mache oder anders machen kann?
    Bernhard
    Bernhard
    263 Kanäle in 91 Geräten
    3x Sonos Play:1, 1x Sonos:Amp, 1x Sonos Playbar
    4x Hue E27, 21xHue GU10, 1x Lightify RGB Stripe, 1x Lightify E27 TW
    • BluefoxB Offline
      BluefoxB Offline
      @Heinzelmaennchen:
      Irgendwelche Ideen, was ich falsch mache oder anders machen kann? `
      Geht es dann nach reboot?
      Ist das cubie?
      • H Offline
        Heinzelmaennchen
        Nein, ist ein bananapi.
        Und ja, nach einem Reboot klappt dann erst mal wieder alles.
        Ich habe eben mal auch gleich nach dem reboot den Graphite Adapter deaktiviert. Dann scheint es zumindest besser zu laufen. ich glaube, an dieser Stelle stößt man auf das Problem, dass so viele gleichzeitige Inputs (herein über die drei b-control adapter) und Outputs (hinaus nach graphite) dem armen kleinen Rechnerlein bz. der SD-Karte zu sehr zu schaffen macht.
        Das wäre dann mal ein Grund Graphite und den Adapter auf einen anderen Host zu legen. Wäre das denn möglicherweise eine Lösung?
        Bernhard
        Bernhard
          Hallo und frohe Weihnachten!
          Ich hänge mich mal hier an, obwohl mein Problem etwas anders gelagert ist:
          Ich habe folgende Fehlermeldungen (Info):
          socketio.0	2014-12-26 16:16:09	info	getCouchLog history.system.host.cubie.load.20141215
          socketio.0	2014-12-26 16:16:09	info	getCouchLog history.system.host.cubie.load.20141216
          socketio.0	2014-12-26 16:16:09	info	getCouchLog history.system.host.cubie.load.20141217
          socketio.0	2014-12-26 16:16:09	info	getCouchLog history.system.host.cubie.load.20141218
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141219
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141220
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141221
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141222
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141223
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141224
          socketio.0	2014-12-26 16:16:08	info	getCouchLog history.system.host.cubie.load.20141225
          socketio.0	2014-12-26 16:16:07	info	getCouchLog history.system.host.cubie.load.20141226
          socketio.0	2014-12-26 16:16:00	info	getCouchLog history.system.host.cubie.load.20141215
          socketio.0	2014-12-26 16:16:00	info	getCouchLog history.system.host.cubie.load.20141216
          socketio.0	2014-12-26 16:16:00	info	getCouchLog history.system.host.cubie.load.20141217
          socketio.0	2014-12-26 16:15:59	info	getCouchLog history.system.host.cubie.load.20141218
          socketio.0	2014-12-26 16:15:59	info	getCouchLog history.system.host.cubie.load.20141219
          socketio.0	2014-12-26 16:15:59	info	getCouchLog history.system.host.cubie.load.20141220
          socketio.0	2014-12-26 16:15:59	info	getCouchLog history.system.host.cubie.load.20141221
          socketio.0	2014-12-26 16:15:59	info	getCouchLog history.system.host.cubie.load.20141222
          socketio.0	2014-12-26 16:15:58	info	getCouchLog history.system.host.cubie.load.20141223
          socketio.0	2014-12-26 16:15:58	info	getCouchLog history.system.host.cubie.load.20141224
          socketio.0	2014-12-26 16:15:58	info	getCouchLog history.system.host.cubie.load.20141225
          socketio.0	2014-12-26 16:15:58	info	getCouchLog history.system.host.cubie.load.20141226
          admin.0	2014-12-26 16:15:49	info	getCouchLog history.system.host.cubie.load.20141225
          admin.0	2014-12-26 16:15:49	info	getCouchLog history.system.host.cubie.load.20141226
          Unter History wird bei einem anderen Datenpunkt keine Liste mehr angezeigt, der Graph endet am 23.12. um 19:43.
          Ich denke, dass hier das Limit von 480 Datenpunkten die Ursache ist.
          EDIT: Nach reboot wieder drei Werte (und nur dieses)in der Liste, in der Graphik werden diese drei Punkte korrekt hinten angehängt und die Linie vom 23.12. bis jetzt durchverbunden.
          Ich hoffe ich komme in der nächsten Zeit wieder zum Testen.
          Rainer
