  4. [Frage]Nach Fehler bei Redis-Anmeldung startet ioBroker immer wieder neu
6 Beiträge 3 Kommentatoren 1.4k Aufrufe
    pix
    hatte größere Probleme mit meinem Server. Nun ist er wieder flott, allerdings startet iobroker nicht sauber:
    2016-10-26 18:20:09.264  - [32minfo[39m: iobroker exit 0
    2016-10-26 18:20:09.367  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
    2016-10-26 18:20:09.368  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
    2016-10-26 18:20:15.393  - [32minfo[39m: host.MacMini-Ethernet.fritz.box iobroker.js-controller version 0.12.3 js-controller starting
    2016-10-26 18:20:15.401  - [32minfo[39m: host.MacMini-Ethernet.fritz.box Copyright (c) 2014-2016 bluefox, hobbyquaker
    2016-10-26 18:20:15.402  - [32minfo[39m: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
    2016-10-26 18:20:15.403  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ip addresses: fe80::ca2a:14ff:fe58:bcd 192.168.178.38 fe80::bd31:d67e:532a:4255 fd26:78a9:c46b:bf48:bd31:d67e:532a:4255
    2016-10-26 18:20:15.439  - [32minfo[39m: host.MacMini-Ethernet.fritz.box States connected to redis 127.0.0.1:6379
    2016-10-26 18:20:15.442  - [32minfo[39m: host.MacMini-Ethernet.fritz.box InRedisDB connected
    2016-10-26 18:20:15.464  - [31merror[39m: uncaught exception: that._clone is not a function
    2016-10-26 18:20:15.468  - [31merror[39m: TypeError: that._clone is not a function
        at /Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInRedis.js:1135:36
        at Command.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/lib/states/statesInRedis.js:602:49)
        at normal_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:714:21)
        at RedisClient.return_reply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:816:9)
        at JavascriptRedisParser.Parser.returnReply (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:188:18)
        at JavascriptRedisParser.execute (/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/node_modules/redis-parser/lib/parser.js:415:12)
        at Socket. <anonymous>(/Users/pix/Documents/iobroker/node_modules/iobroker.js-controller/node_modules/redis/index.js:267:27)
        at emitOne (events.js:77:13)
        at Socket.emit (events.js:169:7)
        at readableAddChunk (_stream_readable.js:153:18)
    2016-10-26 18:20:15.471  - [32minfo[39m: iobroker _restart
    2016-10-26 18:20:15.487  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
    2016-10-26 18:20:15.672  - [32minfo[39m: iobroker Starting node restart.js
    2016-10-26 18:20:15.683  - [32minfo[39m: iobroker exit 0
    2016-10-26 18:20:15.792  - [32minfo[39m: host.MacMini-Ethernet.fritz.box received SIGTERM
    2016-10-26 18:20:15.793  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated
    2016-10-26 18:20:21.431  - [32minfo[39m: host.MacMini-Ethernet.fritz.box iobroker.js-controller version 0.12.3 js-controller starting
    2016-10-26 18:20:21.439  - [32minfo[39m: host.MacMini-Ethernet.fritz.box Copyright (c) 2014-2016 bluefox, hobbyquaker
    2016-10-26 18:20:21.440  - [32minfo[39m: host.MacMini-Ethernet.fritz.box hostname: MacMini-Ethernet.fritz.box
    2016-10-26 18:20:21.441  - [32minfo[39m: host.MacMini-Ethernet.fritz.box ip addresses: fe80::ca2a:14ff:fe58:bcd 192.168.178.38 fe80::bd31:d67e:532a:4255 fd26:78a9:c46b:bf48:bd31:d67e:532a:4255
    2016-10-26 18:20:21.478  - [32minfo[39m: host.MacMini-Ethernet.fritz.box States connected to redis 127.0.0.1:6379
    2016-10-26 18:20:21.480  - [32minfo[39m: host.MacMini-Ethernet.fritz.box InRedisDB connected
    2016-10-26 18:20:21.501  - [31merror[39m: uncaught exception: that._clone is not a function
    2016-10-26 18:20:21.505  - [31merror[39m: TypeError: that._clone is not a function
    2016-10-26 18:20:21.507  - [32minfo[39m: iobroker _restart
    2016-10-26 18:20:21.519  - [32minfo[39m: host.MacMini-Ethernet.fritz.box terminated</anonymous></anonymous>
    Irgendwas stimmt mit redis wohl nicht. Redis Server läuft aber.
    ./iobroker setup custom
    ````auch schon ausgeführt und alles auf redis umgestellt. Kein Erfolg
    Ebenso führ der controller ein "restart" aus. Damit startet eine Schleife aus Start und Absturz, die ich mit````
    ./iobroker stop
    ````nicht beenden kann.
    Jemand ne Idee?
    Pix
      Hat es dir beim Crash ein Script zerschossen?
      @pix:
      at readableAddChunk (_stream_readable.js:153:18)</anonymous> `
      Vielleicht hilft es in den Sekunden, die ioBroker hoch ist mal den Js-Adapter zu stoppen.
      Rainer
      • BluefoxB Offline
        BluefoxB Offline
        @pix:
        ./iobroker stop
        Jemand ne Idee?
        Pix `
        Es ist nicht klar, wie es früher lief. Probiere die aktuellste 0.13.0 Version.
          pix
          So, nach Tagen das Ding immer noch nicht wieder zum Laufen gekriegt :evil:
          Server platt gemacht und komplett neu installiert, inklusive node, npm, iobroker.
          Dann iobroker-data Ordner zurückkopiert.
          Fehler wie oben.
          Dann JS-Controller 0.13 installiert, dann kommt````
          MacMini-Ethernet:iobroker pix$ ./iobroker start
          Starting iobroker controller daemon...
          iobroker controller daemon failed to start: 2
          Error: 2
          Tipps?
          Pix
            pix
            Okay, habe mein Timemachine Backup des iobroker Ordners vom letzten Sonntag! (5 Tage) wieder eingespielt.
            Alles fährt wieder hoch :P , leider sind aber alle States weg 😢
            Manche sind wichtig für die Funktion von Skripts. Leider lassen sie sich nicht einfach per wiederherstellen. Weiß da jemand Rat?
              pix
              Habe die States von Hand wieder mit Werten gefüllt. War natürlich etwas Arbeit. 😢
              Gibt es ein Skript, dass alle States durchgeht, ob sie "undefined" sind und dann in InfluxDB nachsieht, ob es einen Wert gibt und diesen schließlich in den State schreibt?
              Pix
