  4. [Problem] blink4home adapter
    6.7k
blink4home
7 Beiträge 3 Kommentatoren 1.7k Aufrufe 3 Beobachtet
    Smartuser
    schrieb am zuletzt editiert von Smartuser
    Hallo Zusammen,
    ich habe heute den Blink4Home Adapter installiert, bekomme aber folgende Fehlermeldungen:
    blink4home.0	2020-07-14 21:07:16.538	error	(13866) Error: Authentication problem: second attempt at Request._callback (/opt/iobroker/node_modules/iobroker.blink4home/node_modules/node-blink-security/lib/blink.js:328:22) at self.callbac
    blink4home.0	2020-07-14 21:07:16.535	error	(13866) unhandled promise rejection: Authentication problem: second attempt
    blink4home.0	2020-07-14 21:07:16.533	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    blink4home.0	2020-07-14 21:07:16.224	info	(13866) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.18.2, js-controller: 3.1.6
    host.rock64	2020-07-14 19:07:12.873	info	instance system.adapter.blink4home.0 started with pid 13866
    host.rock64	2020-07-14 19:06:50.720	info	Restart adapter system.adapter.blink4home.0 because enabled
    host.rock64	2020-07-14 19:06:50.718	info	instance system.adapter.blink4home.0 terminated with code 0 (NO_ERROR)
    blink4home.0	2020-07-14 19:06:50.156	info	(13043) Terminated (NO_ERROR): Without reason
    blink4home.0	2020-07-14 19:06:50.153	info	(13043) terminating
    blink4home.0	2020-07-14 19:06:50.104	error	at processTicksAndRejections (internal/process/task_queues.js:84:21)
    blink4home.0	2020-07-14 19:06:50.104	error	at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
    blink4home.0	2020-07-14 19:06:50.104	error	at emitErrorNT (internal/streams/destroy.js:92:8)
    blink4home.0	2020-07-14 19:06:50.104	error	at TLSSocket.emit (events.js:315:20)
    blink4home.0	2020-07-14 19:06:50.104	error	at TLSSocket.socketErrorListener (_http_client.js:426:9)
    blink4home.0	2020-07-14 19:06:50.104	error	at ClientRequest.emit (events.js:315:20)
    blink4home.0	2020-07-14 19:06:50.104	error	at Request.onRequestError (/opt/iobroker/node_modules/iobroker.blink4home/node_modules/request/request.js:878:8)
    blink4home.0	2020-07-14 19:06:50.104	error	at Request.emit (events.js:315:20)
    blink4home.0	2020-07-14 19:06:50.104	error	at self.callback (/opt/iobroker/node_modules/iobroker.blink4home/node_modules/request/request.js:186:22)
    blink4home.0	2020-07-14 19:06:50.104	error	at Request._callback (/opt/iobroker/node_modules/iobroker.blink4home/node_modules/node-blink-security/lib/blink.js:328:22)
    blink4home.0	2020-07-14 19:06:50.104	error	(13043) Error: Authentication problem: second attempt
    blink4home.0	2020-07-14 19:06:50.102	error	(13043) unhandled promise rejection: Authentication problem: second attempt
    Unhandled	2020-07-14 19:06:50.100	error	promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    blink4home.0	2020-07-14 19:06:49.742	info	(13043) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.18.2, js-controller: 3.1.6
    host.rock64	2020-07-14 19:06:46.383	info	instance system.adapter.blink4home.0 started with pid 13043
    host.rock64	2020-07-14 19:06:16.353	info	Restart adapter system.adapter.blink4home.0 because enabled
    Es scheint so als gibt es ein Problem bei der Anmeldung.
    node-blink-security ist installiert.
    rock64@rock64:~$ cd /opt/iobroker/
    rock64@rock64:/opt/iobroker$ npm install node-blink-security
    [sudo] password for rock64:
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.1.3 (node_modules/fsevents):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.1.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    + node-blink-security@4.1.5
    updated 1 package in 41.239s
    26 packages are looking for funding
      run `npm fund` for details
    Wird da noch etwas anderes benötigt? Oder kennt jemand dieses Problem?
    • S Smartuser
      Hallo Zusammen,
      Smartuser
      Ich push nochmal 😇
      JayRJ 1 Antwort Letzte Antwort
      • S Smartuser
        Ich push nochmal 😇
        JayRJ Offline
        JayRJ Offline
        JayR
        @Smartuser : Hast du schon eine Lösung für dein Problem gefunden? Ich habe das gleiche Problem wie du:
        2020-10-16 07:28:42.040 - debug: blink4home.0 (14646) Redis Objects: Use Redis connection: 0.0.0.0:9001
        2020-10-16 07:28:42.337 - debug: blink4home.0 (14646) Objects client ready ... initialize now
        2020-10-16 07:28:42.597 - debug: blink4home.0 (14646) Objects create System PubSub Client
        2020-10-16 07:28:42.599 - debug: blink4home.0 (14646) Objects create User PubSub Client
        2020-10-16 07:28:42.600 - debug: blink4home.0 (14646) Objects client initialize lua scripts
        2020-10-16 07:28:42.718 - debug: blink4home.0 (14646) Objects connected to redis: 0.0.0.0:9001
        2020-10-16 07:28:42.726 - debug: blink4home.0 (14646) objectDB connected
        2020-10-16 07:28:42.729 - debug: blink4home.0 (14646) Redis States: Use Redis connection: 0.0.0.0:9000
        2020-10-16 07:28:42.798 - debug: blink4home.0 (14646) States create User PubSub Client
        2020-10-16 07:28:42.806 - debug: blink4home.0 (14646) States create System PubSub Client
        2020-10-16 07:28:43.062 - debug: blink4home.0 (14646) States connected to redis: 0.0.0.0:9000
        2020-10-16 07:28:43.064 - debug: blink4home.0 (14646) statesDB connected
        2020-10-16 07:28:43.862 - info: blink4home.0 (14646) starting. Version 0.1.1 in /opt/iobroker/node_modules/iobroker.blink4home, node: v12.18.3, js-controller: 3.1.6
        2020-10-16 07:28:43.900 - debug: blink4home.0 (14646) config Username: ****
        2020-10-16 07:28:43.901 - debug: blink4home.0 (14646) config Password: ****
        2020-10-16 07:28:43.902 - debug: blink4home.0 (14646) config Interval: 10
        2020-10-16 07:28:43.905 - debug: blink4home.0 (14646) start polling from server. interval 10 seconds.
        2020-10-16 07:28:44.078 - error: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        2020-10-16 07:28:44.079 - error: blink4home.0 (14646) unhandled promise rejection: Authentication problem: second attempt
        2020-10-16 07:28:44.080 - error: blink4home.0 (14646) Error: Authentication problem: second attempt
        at Request._callback (/opt/iobroker/node_modules/node-blink-security/lib/blink.js:328:22)
        at self.callback (/opt/iobroker/node_modules/node-blink-security/node_modules/request/request.js:186:22)
        at Request.onRequestError (/opt/iobroker/node_modules/node-blink-security/node_modules/request/request.js:878:8)
        2020-10-16 07:28:44.246 - info: blink4home.0 (14646) terminating
        2020-10-16 07:28:44.247 - info: blink4home.0 (14646) Terminated (NO_ERROR): Without reason
        2020-10-16 07:28:44.797 - info: host.homeautomation instance system.adapter.blink4home.0 terminated with code 0 (NO_ERROR)
        2020-10-16 07:28:44.798 - info: host.homeautomation Restart adapter system.adapter.blink4home.0 because enabled
        • JayRJ JayR
          Smartuser
          @JayR
          Nein leider nicht ... 😢
          • S Smartuser
            @JayR
            JayRJ Offline
            JayRJ Offline
            JayR
            @Smartuser Kann sich das jemand anschauen. Wird der Adapter noch weiterentwickelt?
            • JayRJ JayR
              Steph 0
              @jayr - konntst Du das lösen? Hab hier das gleiche Problem - Fehler bei der Anmeldung.
              • S Steph 0
                JayRJ Offline
                JayRJ Offline
                JayR
                @steph-0 : Ja und zwar ich bin von iobroker auf Homeassistant gewechselt. Viel höhere Qualität und Zuverlässigkeit von Integrationen und weniger Aufwand automatisierungen zu erstellen.
