  4. Homekit Verbindungs Abbrüche
2 Beiträge 1 Kommentatoren 706 Aufrufe
    bz7i
    Moin,
    habe mir Heute, auf meinen RaspberryPi, den HomeKit Adapter installiert.
    Nach einigen Anlaufschwierigkeiten, läuft es jetzt einigermaßen. Das einzige Problem welches Ich noch habe,
    das die Verbindung hin und wieder abbricht.
    host-raspberrypi	2016-10-02 19:15:56.721	info	Restart adapter system.adapter.homekit.0 because enabled
    host-raspberrypi	2016-10-02 19:15:56.720	error	instance system.adapter.homekit.0 terminated with code 0 (OK)
    TypeError:	2016-10-02 19:15:56.647	error	at HAPServer._handleCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/HAPServer.js:724:10)
    TypeError:	2016-10-02 19:15:56.647	error	at HAPServer.emit (events.js:175:7)
    TypeError:	2016-10-02 19:15:56.647	error	at emitThree (events.js:97:13)
    TypeError:	2016-10-02 19:15:56.647	error	at Bridge.Accessory._handleGetCharacteristics (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:554:8)
    TypeError:	2016-10-02 19:15:56.647	error	at Array.forEach (native)
    TypeError:	2016-10-02 19:15:56.647	error	at Bridge. (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Accessory.js:587:20)
    TypeError:	2016-10-02 19:15:56.647	error	at Characteristic.getValue (/opt/iobroker/node_modules/iobroker.homekit/node_modules/hap-nodejs/lib/Characteristic.js:120:10)
    TypeError:	2016-10-02 19:15:56.647	error	at emit (events.js:172:7)
    TypeError:	2016-10-02 19:15:56.647	error	at emitTwo (events.js:87:13)
    TypeError:	2016-10-02 19:15:56.647	error	at null. (/opt/iobroker/node_modules/iobroker.homekit/main.js:759:37)
    TypeError:	2016-10-02 19:15:56.647	error	Cannot read property 'val' of undefined
    uncaught	2016-10-02 19:15:56.639	error	exception: Cannot read property 'val' of undefined
    homekit-0	2016-10-02 19:15:53.616	info	Bridge 'ioBroker Bridge' successfully published
    homekit-0	2016-10-02 19:15:52.964	info	hap-nodejs starting...
    homekit-0	2016-10-02 19:15:50.128	info	starting. Version 0.1.4 in /opt/iobroker/node_modules/iobroker.homekit
    host-raspberrypi	2016-10-02 19:15:46.564	info	instance system.adapter.homekit.0 started with pid 4362
    host-raspberrypi	2016-10-02 19:15:16.533	info	Restart adapter system.adapter.homekit.0 because enabled
    Ich vermute es hängt mit den CUxD Objekten zusammen. Kann mir da jemand helfen ??
    Gruß Sebastian
      bz7i
      Moin,
      hab es hinbekommen. Habe alle meine Geräte, die noch nicht in den HomeKit Adapter settings aufgelistet waren, besten gewissens hinzugefügt.
      Gut möglich das Ich das Falsch interprtiert habe. Wäre über jede Fehler inc. Erklärung dankbar. Aber so funktioniert es vorerst.
      Switch	State	HM-LC-Sw1-FM		 .STATE
      Switch	State	HM-LC-Sw2-FM		 .STATE
      Switch	State	HM-LC-Sw4-DR		 .STATE
      Switch	State	HM-LC-Sw1-Pl		 .STATE
      Switch	State	HM-LC-Sw4-PCB		.STATE
      Switch	State	HM-MOD-Re-8		  .STATE
      Switch	State	HM-LC-Sw4-Ba-PCB	.STATE
      Switch	State	HM-LC-Dim1T-CV	  1.LEVEL
      Switch	State	HM-LC-Dim1L-CV	  .LEVEL
      Switch	State	HM-RC-P1			  .LEVEL
      Switch	State	HM-Sec-SCo		   1.STATE
      Switch	State	HM-SCI-3-FM		  .STATE
      Switch	State	HM-LC-Bl1PBU-FM	 1.LEVEL
      Switch	State	HM-RC-2-PBU-FM	  1.PRESS_SHORT
      Switch	State	HM-PB-2-FM		   1.PRESS_SHORT
      Switch	State	HM-Sen-EP		    .STATE
      Switch	State	HM-RCV-50		    .LEVEL
      Thermostat	CurrentTemperature	HM-CC-TC	1.TEMPERATURE
      Thermostat	CurrentTemperature	BC-RT-TRX-CyG-3	1.ACTUAL_TEMPERATURE
      Thermostat	CurrentTemperature	HM-CC-RT-DN	4.ACTUAL_TEMPERATURE
      Thermostat	CurrentTemperature	OpenWeatherMap	1.TEMPERATURE
      Thermostat	CurrentTemperature	HM-WDS10-TH-O	1.TEMPERATURE
      Thermostat	TargetTemperature	HM-CC-TC	2.SETPOINT
      Thermostat	TargetTemperature	BC-RT-TRX-CyG-3	1.SET_TEMPERATURE
      Thermostat	TargetTemperature	HM-CC-RT-DN	4.SET_TEMPERATURE
      Thermostat	State	HM-CC-TC	2.STATE
      Thermostat	CurrentRelativeHumidity	HM-CC-TC	1.HUMIDITY
      Thermostat	CurrentRelativeHumidity	OpenWeatherMap	1.HUMIDITY
      Thermostat	CurrentRelativeHumidity	HM-WDS10-TH-O	1.HUMIDITY
      Temperature	CurrentTemperature	OpenWeatherMap	1.TEMPERATURE
      Temperature	CurrentTemperature	HM-WDS10-TH-O	1.TEMPERATURE
      Humidity	CurrentRelativeHumidity	OpenWeatherMap	1.HUMIDITY
      Humidity	CurrentRelativeHumidity	HM-WDS10-TH-O	1.HUMIDITY
