  4. Pythonfehler beim Update der Adapter
python
1 Beiträge 1 Kommentatoren 294 Aufrufe
  • J Offline
    Joker971
    neuerdings bekomme ich beim updaten meiner Adapter folgendes im Log angezeigt, hier jetzt beispielhaft beim Tradfri Adapter, aber spielt keine Rolle da es bei allen Adaptern angezeigt wird:
    ERR! find Python gyp ERR! find Python Python is not set from command line or npm configurationgyp ERR! find Python Python is not set from environment variable PYTHONgyp ERR! find Python checking if "python" can be usedgyp ERR! find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR!
    find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR!
    find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR!
    find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp
    ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR!
    find Python gyp ERR! find Python **********************************************************gyp ERR!
    find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp
    ERR! find Python - Set the environment variable PYTHONgyp
    ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"
    gyp ERR! find Python For more information consult the documentation at:gyp
    ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR!
    find Python
    gyp
    ERR! configure error gyp ERR! stack Error: Could not find any Python installation to usegyp ERR!
    stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp
    ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR!
    stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:301:5)
    gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp ERR!
    stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:246:12)
    gyp ERR! stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR!
    stack     at process._tickCallback (internal/process/next_tick.js:63:19)gyp ERR! System Windows_NT 6.1.7601
    gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\diskusage
    gyp ERR! node -v v10.18.0gyp ERR!
    node-gyp -v v5.0.5gyp ERR! not ok
    gyp
    find Python - "python" is not in PATH or produced an errorgyp ERR! find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR!
    find Python - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR!
    find Python checking if Python is C:\Python27\python.exegyp ERR! find Python - "C:\Python27\python.exe" could not be rungyp ERR! find Python checking if Python is C:\Python37\python.exegyp ERR! find Python - "C:\Python37\python.exe" could not be rungyp ERR! find Python gyp ERR! find Python **********************************************************gyp ERR! find Python You need to install the latest version of Python.gyp ERR! find Python Node-gyp should be able to find and use Python. If not,gyp ERR! find Python you can try one of the following options:gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"gyp ERR! find Python   (accepted by both node-gyp and npm)gyp ERR! find Python - Set the environment variable PYTHONgyp ERR! find Python - Set the npm configuration variable python:gyp ERR! find Python   npm config set python "C:\Path\To\python.exe"gyp ERR! find Python For more information consult the documentation at:gyp ERR! find Python https://github.com/nodejs/node-gyp#installationgyp ERR! find Python **********************************************************gyp ERR! find Python
    gyp
    gyp ERR! stack Error: Could not find any Python installation to usegyp ERR! stack     at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)gyp ERR! stack     at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)gyp ERR! stack     at PythonFinder.<anonymous> (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)gyp ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
    gyp ERR! stack     at exithandler (child_process.js:301:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp
    ERR! stack     at ChildProcess.emit (events.js:198:13)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:246:12)gyp ERR! stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR!
    gyp ERR! System Windows_NT 6.1.7601gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"gyp ERR! cwd C:\ioBroker\node_modules\mdnsgyp ERR! node -v v10.18.0gyp ERR! node-gyp -v v5.0.5gyp ERR! not ok
    gyp
    find Python checking if "python2" can be usedgyp ERR! find Python - "python2" is not in PATH or produced an errorgyp ERR! find Python checking if "python3" can be usedgyp ERR! find Python
    - "python3" is not in PATH or produced an errorgyp ERR! find Python checking if the py launcher can be used to find Python 2gyp ERR! find Python - "py.exe" is not in PATH or produced an errorgyp ERR! find Python
    gyp ERR!
    ERR! stack     at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)gyp ERR! stack     at exithandler (child_process.js:301:5)gyp ERR! stack     at ChildProcess.errorhandler (child_process.js:313:5)gyp
    stack     at onErrorNT (internal/child_process.js:415:16)gyp ERR! stack     at process._tickCallback (internal/process/next_tick.js:63:19)gyp
    gyp ERR! cwd C:\ioBroker\node_modules\unix-dgramgyp ERR! node -v v10.18.0gyp
    Update "system.adapter.tradfri.0"
    upload [20] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/remote_dimmer.png icons/remote_dimmer.png image/png
    upload [19] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/remote.png icons/remote.png image/png
    upload [18] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/plug.png icons/plug.png image/png
    upload [17] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel_ws.png icons/panel_ws.png image/png
    upload [16] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel_rgb.png icons/panel_rgb.png image/png
    upload [15] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/panel.png icons/panel.png image/png
    upload [14] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/motion_sensor.png icons/motion_sensor.png image/png
    upload [13] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/gu10_ws.png icons/gu10_ws.png image/png
    upload [12] tradfri.admin C:/ioBroker/node_modules/iobroker.tradfri/admin/icons/gu10_2700k.png icons/gu10_2700k.png image/png
    Trotz der angezeigten Pythonfehler ist das update immer erfolgreich und alle Adapter laufen Problemlos aber irgendwie nervt das. Soweit ich weiss ist Python auch nicht explizit auf meinem Windows installiert. Zudem kommen diese Fehler auch erst seit kurzer Zeit.
