  4. HID Adapter lässt sich nicht installieren
hidadapter
2 Beiträge 1 Kommentatoren 438 Aufrufe 1 Beobachtet
  • F Offline
    FrenkyIO
    |Systemdata| Raspberry Pi4 4Gb|
    |Betriebssystem:| Raspbian Buster |
    |Node-Version:| 12.x.x |
    |Nodejs-Version:| 12.17.0|
    |NPM-Version:| 6.14.4 |
    |Installationsart:| Skript&#x2F |
    Kann leider den Adapter nicht installieren. Hier der Log.
    $ ./iobroker add hid  --host raspberrypi4
    NPM version: 6.14.4
    npm install iobroker.hid@0.1.17 --loglevel error --prefix "/opt/iobroker" (System call)
    ../hidapi/libusb/hid.c: In function ‘hid_read_timeout’:
    ../hidapi/libusb/hid.c:1078:6: warning: variable ‘bytes_read’ might be clobbered by ‘longjmp’ or ‘vfork’ [-Wclobbered]  int bytes_read = -1;      ^~~~~~~~~~
    In file included from ../src/HID.cc:31:../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:../../nan/nan.h:2298:62: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]     , reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)                                                              ^
    ../src/HID.cc: At global scope:../src/HID.cc:67:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]     throw(JSException);     ^~~~~
    ../src/HID.cc:70:5: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]     throw(JSException);     ^~~~~
    ../src/HID.cc:152:3: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]   throw(JSException)   ^~~~~
    ../src/HID.cc:163:3: warning: dynamic exception specifications are deprecated in C++11 [-Wdeprecated]   throw(JSException)   ^~~~~
    ../src/HID.cc: In member function ‘void HID::readResultsToJSCallbackArguments(HID::ReceiveIOCB*, v8::Local<v8::Value>*)’:../src/HID.cc:203:91: warning: ‘v8::Local<v8::Value> v8::Object::Get(v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::GetCurrentContext()->Global()->Get(Nan::New<String>("Buffer").ToLocalChecked() )        ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3553:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(Local<Value> key));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:207:74: error: no matching function for call to ‘v8::Function::NewInstance(int, v8::Local<v8::Value> [1])’     Local<Object> buf = nodeBufConstructor->NewInstance(1, nodeBufferArgs);        ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4281:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>, int, v8::Local<v8::Value>*) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4281:44: note:   candidate expects 3 arguments, 2 provided
    /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4284:44: note: candidate: ‘v8::MaybeLocal<v8::Object> v8::Function::NewInstance(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT MaybeLocal<Object> NewInstance(                                            ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:4284:44: note:   candidate expects 1 argument, 2 provided
    ../src/HID.cc: In static member function ‘static void HID::recvAsyncDone(uv_work_t*)’:../src/HID.cc:231:32: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated [-Wdeprecated-declarations]   iocb->_callback->Call(2, argv);                                ^
    In file included from ../src/HID.cc:31:../../nan/nan.h:1740:3: note: declared here   Call(int argc, v8::Local<v8::Value> argv[]) const {   ^~~~
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::read(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:257:70: warning: cast between incompatible function types from ‘void (*)(uv_work_t*)’ {aka ‘void (*)(uv_work_s*)’} to ‘uv_after_work_cb’ {aka ‘void (*)(uv_work_s*, int)’} [-Wcast-function-type]   uv_queue_work(uv_default_loop(), req, recvAsync, (uv_after_work_cb)recvAsyncDone);        ^~~~~~~~~~~~~
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::readSync(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:280:51: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buff_read[i]));                                                   ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::readTimeout(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:305:51: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buff_read[i]));                                                   ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::getFeatureReport(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:339:45: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(i, Nan::New<Integer>(buf[i]));                                             ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::sendFeatureReport(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:360:29: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     if (!messageArray->Get(i)->IsNumber()) {                             ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:363:58: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     message.push_back((unsigned char) messageArray->Get(i)->Int32Value());                                                          ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:363:72: error: no matching function for call to ‘v8::Value::Int32Value()’     message.push_back((unsigned char) messageArray->Get(i)->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::New(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:404:46: error: no matching function for call to ‘v8::Value::Int32Value()’       int32_t vendorId = info[0]->Int32Value();                                              ^
    ../src/HID.cc:405:47: error: no matching function for call to ‘v8::Value::Int32Value()’       int32_t productId = info[1]->Int32Value();                                               ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc:409:62: error: no matching function for call to ‘v8::String::Value::Value(v8::Local<v8::Value>)’         serialPointer = (wchar_t*) *v8::String::Value(info[2]);                                                              ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3158:5: note: candidate: ‘v8::String::Value::Value(v8::Isolate*, v8::Local<v8::Value>)’     Value(Isolate* isolate, Local<v8::Value> obj);     ^~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3158:5: note:   candidate expects 2 arguments, 1 provided../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::setNonBlocking(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:443:37: error: no matching function for call to ‘v8::Value::Int32Value()’   blockStatus = info[0]->Int32Value();                                     ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::write(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:468:31: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       if (!messageArray->Get(i)->IsNumber()) {                               ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:471:60: warning: ‘v8::Local<v8::Value> v8::Object::Get(uint32_t)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       message.push_back((unsigned char) messageArray->Get(i)->Int32Value());                                                            ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3557:51: note: declared here   V8_DEPRECATED("Use maybe version", Local<Value> Get(uint32_t index));                                                   ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:471:74: error: no matching function for call to ‘v8::Value::Int32Value()’       message.push_back((unsigned char) messageArray->Get(i)->Int32Value());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::getDeviceInfo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:505:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:509:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:513:62: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       Nan::New<String>(narrow(wstr).c_str()).ToLocalChecked());                                                              ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc: In static member function ‘static Nan::NAN_METHOD_RETURN_TYPE HID::devices(Nan::NAN_METHOD_ARGS_TYPE)’:../src/HID.cc:535:38: error: no matching function for call to ‘v8::Value::Int32Value()’       vendorId = info[0]->Int32Value();                                      ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note: candidate: ‘v8::Maybe<int> v8::Value::Int32Value(v8::Local<v8::Context>) const’   V8_WARN_UNUSED_RESULT Maybe<int32_t> Int32Value(Local<Context> context) const;                                        ^~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:2709:40: note:   candidate expects 1 argument, 0 provided../src/HID.cc:536:39: error: no matching function for call to ‘v8::Value::Int32Value()’       productId = info[1]->Int32Value();                                       ^
    ../src/HID.cc:551:101: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("vendorId").ToLocalChecked(), Nan::New<Integer>(dev->vendor_id));        ^
    ../src/HID.cc:552:103: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("productId").ToLocalChecked(), Nan::New<Integer>(dev->product_id));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:554:110: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("path").ToLocalChecked(), Nan::New<String>(dev->path).ToLocalChecked());        ^
    ../src/HID.cc:557:143: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("serialNumber").ToLocalChecked(), Nan::New<String>(narrow(dev->serial_number).c_str()).ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:560:149: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("manufacturer").ToLocalChecked(), Nan::New<String>(narrow(dev->manufacturer_string).c_str()).ToLocalChecked());        ^
    ../src/HID.cc:563:139: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]       deviceInfo->Set(Nan::New<String>("product").ToLocalChecked(), Nan::New<String>(narrow(dev->product_string).c_str()).ToLocalChecked());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:565:105: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("release").ToLocalChecked(), Nan::New<Integer>(dev->release_number));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:566:109: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     deviceInfo->Set(Nan::New<String>("interface").ToLocalChecked(), Nan::New<Integer>(dev->interface_number));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~../src/HID.cc:568:107: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         deviceInfo->Set(Nan::New<String>("usagePage").ToLocalChecked(), Nan::New<Integer>(dev->usage_page));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:571:98: warning: ‘bool v8::Object::Set(v8::Local<v8::Value>, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]         deviceInfo->Set(Nan::New<String>("usage").ToLocalChecked(), Nan::New<Integer>(dev->usage));        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3499:22: note: declared here                 bool Set(Local<Value> key, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc:573:36: warning: ‘bool v8::Object::Set(uint32_t, v8::Local<v8::Value>)’ is deprecated: Use maybe version [-Wdeprecated-declarations]     retval->Set(count++, deviceInfo);                                    ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8-internal.h:14,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:27,                 from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:3508:22: note: declared here                 bool Set(uint32_t index, Local<Value> value));                      ^~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8config.h:328:3: note: in definition of macro ‘V8_DEPRECATED’   declarator __attribute__((deprecated(message)))   ^~~~~~~~~~
    ../src/HID.cc: In static member function ‘static void HID::Initialize(v8::Local<v8::Object>)’:../src/HID.cc:596:31: warning: ‘void node::AtExit(void (*)(void*), void*)’ is deprecated: Use the three-argument variant of AtExit() or AddEnvironmentCleanupHook() [-Wdeprecated-declarations]   node::AtExit(deinitialize, 0);                               ^
    In file included from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:702:22: note: declared here     NODE_EXTERN void AtExit(void (*cb)(void* arg), void* arg = nullptr));                      ^~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~../src/HID.cc:596:31: warning: ‘void node::AtExit(void (*)(void*), void*)’ is deprecated: Use the three-argument variant of AtExit() or AddEnvironmentCleanupHook() [-Wdeprecated-declarations]   node::AtExit(deinitialize, 0);                               ^In file included from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:702:22: note: declared here     NODE_EXTERN void AtExit(void (*cb)(void* arg), void* arg = nullptr));                      ^~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:101:42: note: in definition of macro ‘NODE_DEPRECATED’     __attribute__((deprecated(message))) declarator                                          ^~~~~~~~~~
    ../src/HID.cc:614:82: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New<String>("HID").ToLocalChecked(), hidTemplate->GetFunction());        ^
    In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
    ../src/HID.cc:616:115: error: no matching function for call to ‘v8::FunctionTemplate::GetFunction()’   target->Set(Nan::New<String>("devices").ToLocalChecked(), Nan::New<FunctionTemplate>(HID::devices)->GetFunction());        ^In file included from /home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:67,                 from ../src/HID.cc:30:/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note: candidate: ‘v8::MaybeLocal<v8::Function> v8::FunctionTemplate::GetFunction(v8::Local<v8::Context>)’   V8_WARN_UNUSED_RESULT MaybeLocal<Function> GetFunction(                                              ^~~~~~~~~~~/home/iobroker/.cache/node-gyp/12.17.0/include/node/v8.h:6126:46: note:   candidate expects 1 argument, 0 provided
    In file included from ../src/HID.cc:30:../src/HID.cc: At global scope:/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:608:43: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]       (node::addon_register_func) (regfunc),                          \                                           ^/home/iobroker/.cache/node-gyp/12.17.0/include/node/node.h:642:3: note: in expansion of macro ‘NODE_MODULE_X’   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)   ^~~~~~~~~~~~~../src/HID.cc:629:3: note: in expansion of macro ‘NODE_MODULE’   NODE_MODULE(HID, init);   ^~~~~~~~~~~
    make: *** [HID.target.mk:120: Release/obj.target/HID/src/HID.o] Error 1
    gyp ERR! build error
    gyp ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:194:23)gyp ERR! stack     at ChildProcess.emit (events.js:315:20)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)gyp ERR! System Linux 4.19.118-v7l+gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/node-hidgyp ERR! node -v v12.17.0
    gyp ERR! node-gyp -v v5.1.0gyp ERR! not ok
    npm
     ERR! code ELIFECYCLEnpm ERR! errno 1npm ERR! node-hid@0.5.7 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1npm ERR! npm ERR! Failed at the node-hid@0.5.7 install script.npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
    npm ERR! A complete log of this run can be found in:npm ERR!     /home/iobroker/.npm/_logs/2020-05-31T09_31_49_013Z-debug.log
    ERROR: host.raspberrypi4 Cannot install iobroker.hid@0.1.17: 1
    Vielen Dank schonmal für eure Hilfe.
    • F Offline
      FrenkyIO
      Der Adapter wird wahrscheinlich nicht mehr gewartet, oder?
      Kennt jemand denn vielleicht eine andere Idee wie ich meine Funkfernbedienung einbinde.
      Habe diese hier: https://www.amazon.de/Andoer®-Tragbare-Drahtlose-Fernbedienung-Tastatursteuerung-Type-2/dp/B00WDSCTR4
      Möchte damit nicht nur Kodi steuern können, sondern optional auch den Strom am Fernseher einschalten können (über einen Datenpunkt). Bin für jede Hilfe dankbar.
