  4. material adapter update auf 0.13.8 error
material uiupdate error
1 Beiträge 1 Kommentatoren 166 Aufrufe 1 Beobachtet
  • Q Offline
    Q Offline
    Qlink
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Hyper-V VM
    Arbeitsspeicher: 4GB
    Festplattenart: SSD
    Betriebssystem: Windows
    Node-Version: 1.5.14
    Nodejs-Version: 10.15.3
    NPM-Version: 6.9.0
    Installationsart: Manuell
    Hi Leute,
    ich hätte gerade versucht den Material Adapter von 0.12.1 auf die neue 0.13.8 Version hochzuziehen.
    Dabei kommen einige Fehlermeldungen beim Update:
    C:\ioBroker>npm install iobroker.material
    > mdns@2.5.1 install C:\ioBroker\node_modules\mdns
    > node-gyp rebuild
    C:\ioBroker\node_modules\mdns>if not defined npm_config_node_gyp (node "C:\Users\admin\AppData\Roaming\npm\node_modules\npm\node_modules\npm-lifecycle\node-gyp-bin\\..\..\node_modules\node-gyp\bin\node-gyp.js" rebuild )  else (node "C:\Users\admin\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" rebuild )
    Building the projects in this solution one at a time. To enable parallel build, please add the "/m" switch.
      dns_sd.cpp
      dns_service_browse.cpp
    c:\iobroker\node_modules\mdns\src\mdns.hpp(32): fatal error C1083: Cannot open include file: 'dns_sd.h': No such file o
    r directory (compiling source file ..\src\dns_service_browse.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.
    vcxproj]
    r directory (compiling source file ..\src\dns_sd.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.vcxproj]
      dns_service_enumerate_domains.cpp
      dns_service_get_addr_info.cpp
    r directory (compiling source file ..\src\dns_service_enumerate_domains.cpp) [C:\ioBroker\node_modules\mdns\build\dns_s
    d_bindings.vcxproj]
      dns_service_process_result.cpp
    r directory (compiling source file ..\src\dns_service_get_addr_info.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bi
    ndings.vcxproj]
      dns_service_ref.cpp
    r directory (compiling source file ..\src\dns_service_process_result.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_b
    indings.vcxproj]
    r directory (compiling source file ..\src\dns_service_ref.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.vcx
    proj]
      dns_service_ref_deallocate.cpp
      dns_service_ref_sock_fd.cpp
    r directory (compiling source file ..\src\dns_service_ref_sock_fd.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bind
    ings.vcxproj]
      dns_service_register.cpp
    r directory (compiling source file ..\src\dns_service_ref_deallocate.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_b
    indings.vcxproj]
      dns_service_resolve.cpp
    r directory (compiling source file ..\src\dns_service_register.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_binding
    s.vcxproj]
      dns_service_update_record.cpp
    r directory (compiling source file ..\src\dns_service_resolve.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings
    .vcxproj]
      mdns_utils.cpp
    r directory (compiling source file ..\src\dns_service_update_record.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bi
    ndings.vcxproj]
      network_interface.cpp
    r directory (compiling source file ..\src\mdns_utils.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.vcxproj]
      socket_watcher.cpp
    r directory (compiling source file ..\src\socket_watcher.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.vcxp
    roj]
      txt_record_ref.cpp
    r directory (compiling source file ..\src\network_interface.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.v
    cxproj]
      txt_record_create.cpp
    r directory (compiling source file ..\src\txt_record_ref.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.vcxp
    roj]
      txt_record_deallocate.cpp
    r directory (compiling source file ..\src\txt_record_create.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindings.v
    cxproj]
      txt_record_set_value.cpp
    r directory (compiling source file ..\src\txt_record_deallocate.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindin
    gs.vcxproj]
      txt_record_get_length.cpp
    r directory (compiling source file ..\src\txt_record_set_value.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_binding
    s.vcxproj]
      txt_record_buffer_to_object.cpp
    r directory (compiling source file ..\src\txt_record_get_length.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_bindin
    gs.vcxproj]
      win_delay_load_hook.cc
    r directory (compiling source file ..\src\txt_record_buffer_to_object.cpp) [C:\ioBroker\node_modules\mdns\build\dns_sd_
    bindings.vcxproj]
    gyp ERR! build error
    gyp ERR! stack Error: `C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools\MSBuild\15.0\Bin\MSBuild.exe` failed with exit code: 1
    gyp ERR! stack     at ChildProcess.onExit (C:\Users\admin\AppData\Roaming\npm\node_modules\npm\node_modules\node-gyp\lib\build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:189:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Windows_NT 10.0.14393
    gyp ERR! command "C:\\Program Files\\nodejs\\node.exe" "C:\\Users\\admin\\AppData\\Roaming\\npm\\node_modules\\npm\\node_modules\\node-gyp\\bin\\node-gyp.js" "rebuild"
    gyp ERR! cwd C:\ioBroker\node_modules\mdns
    gyp ERR! node -v v10.15.3
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@^1.0.4 (node_modules\iobroker.info\node_modules\osx-temperature-sensor):
    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.5: wanted {"os":"darwin","arch":"any"} (current: {"os":"win32","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.5.1 (node_modules\mdns):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: mdns@2.5.1 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    + iobroker.material@0.13.8
    added 3 packages from 2 contributors, removed 27 packages, updated 16 packages and audited 2442 packages in 76.036s
    found 165 vulnerabilities (79 low, 19 moderate, 67 high)
      run `npm audit fix` to fix them, or `npm audit` for details
    C:\ioBroker>
    Der Material Adapter wird jetzt unter Update verfügbar in der admin Oberfläche nicht mehr angezeigt, wenn ich die Material UI aber aufrufe erscheint nach wie vor die alte 0.12.1er Version ...
    Hat jemand eine Idee wo das Problem liegt, bzw. wie ich das Lösen kann ?
    Beste Grüße
