  4. SQL Adapter starte nicht mehr
sql-adapter
4 Beiträge 2 Kommentatoren 463 Aufrufe 2 Beobachtet
  • heinhanH Offline
    heinhanH Offline
    heinhan
    Systemdata Bitte Ausfüllen
    Hardwaresystem: PI 4
    Arbeitsspeicher: 4GB
    Festplattenart: SD-Karte
    Betriebssystem: Debian
    Node-Version: 12.16.3
    Nodejs-Version: 12.16.3
    NPM-Version: 6.14.4
    Seit heute läuft der SQL-Adapter auf meinem IoBroker nicht mehr . Hier die LOG Meldung dazu:
    host.raspberrypi 2020-05-01 11:42:41.596 info Restart adapter system.adapter.sql.0 because enabled
    host.raspberrypi 2020-05-01 11:42:41.596 error instance system.adapter.sql.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
    host.raspberrypi 2020-05-01 11:42:41.595 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
    host.raspberrypi 2020-05-01 11:42:41.593 error Caught by controller[0]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/mmmagic/lib/index.js:1:13)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at require (internal/modules/cjs/helpers.js:77:18)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Module.require (internal/modules/cjs/loader.js:1019:19)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Module.load (internal/modules/cjs/loader.js:977:32)
    host.raspberrypi 2020-05-01 11:42:41.592 error Caught by controller[0]: at Object.Module._extensions..node (internal/modules/cjs/loader.js:1183:18)
    host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: the module (for instance, using npm rebuild or npm install).
    host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
    host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: NODE_MODULE_VERSION 64. This version of Node.js requires
    host.raspberrypi 2020-05-01 11:42:41.591 error Caught by controller[0]: was compiled against a different Node.js version using
    host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: Error: The module '/opt/iobroker/node_modules/mmmagic/build/Release/magic.node'
    host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: ^
    host.raspberrypi 2020-05-01 11:42:41.590 error Caught by controller[0]: return process.dlopen(module, path.toNamespacedPath(filename));
    host.raspberrypi 2020-05-01 11:42:41.589 error Caught by controller[0]: internal/modules/cjs/loader.js:1183
    Über Windwos (HeidiSQL) läuft alles wie gewohnt.
    Wenn es an dem Fehler liegt NODE_MODULE_VERSION 72 , wie kann ich den aktualisieren, npm install ergibt folgendes Ergebnis:
    pi@raspberrypi:~ $ npm -v
    6.14.4
    pi@raspberrypi:~ $ sudo npm install
    npm WARN saveError ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN enoent ENOENT: no such file or directory, open '/home/pi/package.json'
    npm WARN pi No description
    npm WARN pi No repository field.
    npm WARN pi No README data
    npm WARN pi No license field.
    up to date in 1.072s
    found 0 vulnerabilities
    • heinhanH heinhan
      NPM-Version: 6.14.4
      6.14.4
      GlasfaserG Offline
      GlasfaserG Offline
      Glasfaser
      @heinhan
      Den Log bitte in Code Tags </> setzen !
      Nach einem Update von Node..... 😎
      cd /opt/iobroker
      npm rebuild
      heinhanH 1 Antwort Letzte Antwort
      • GlasfaserG Glasfaser
        @heinhan
        cd /opt/iobroker
        npm rebuild
        heinhanH Offline
        heinhanH Offline
        heinhan
        @Glasfaser Danke, Fehler behoben. Werde zukünftig den Code einbetten
        • heinhanH heinhan
          GlasfaserG Offline
          GlasfaserG Offline
          Glasfaser
          @heinhan sagte in SQL Adapter starte nicht mehr:
          Fehler behoben.
          Dann setze den Thread auf gelöst !
