  4. Problemen mit Typ
    5.7k
Problemen mit Typ
javascript
5 Beiträge 3 Kommentatoren 1.0k Aufrufe 1 Beobachtet
  • a200A Offline
    a200A Offline
    a200
    javascript.0	2020-04-26 15:02:11.625	warn	(30281) at script.js.DEV.a2:40:13
    javascript.0	2020-04-26 15:02:11.625	warn	(30281) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1354:20)
    javascript.0	2020-04-26 15:02:11.625	warn	(30281) You are assigning a string to the state "javascript.0.Devices.ebus.currenterror.1.ErrorText" which expects a String. Please fix your code to use a String or change the state type to string. T
    javascript.0	2020-04-26 15:02:11.624	warn	(30281) at script.js.DEV.a2:39:13
    javascript.0	2020-04-26 15:02:11.624	warn	(30281) at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1354:20)
    javascript.0	2020-04-26 15:02:11.624	warn	(30281) You are assigning a number to the state "javascript.0.Devices.ebus.currenterror.1.ErrorCode" which expects a Number. Please fix your code to use a Number or change the state type to number. T
    Was soll ich noch machen? Die gleiche Warnung erhalte ich bei number. Dabei spielt es keine Rolle ob ich ein number gebe oder sogar nach number konvertiere.
    Was mache ich falsch?
    for(var i=0; i<5; i++) {
        if (!getObject(storeDP + "." + i + ".ErrorCode")) {
            createState(storeDP + "." + i + ".ErrorCode", "", {
                "desc": "ErrorCode",
                "name": "ErrorCode",
                "type": "number",
                "role": "",
                "unit": ""
        if (!getObject(storeDP + "." + i + ".ErrorText")) {
            createState(storeDP + "." + i + ".ErrorText", "", {
                "desc": "ErrorText",
                "name": "ErrorText",
                "type": "string",
                "role": "",
                "unit": ""
        for(i=0;i<5;i++) {
            stat = getState(id+"."+i+".value").val;
            if(stat){
                setState(storeDP+"."+i+".ErrorCode", Number(stat));
                setState(storeDP+"."+i+".ErrorText", meldungen.get(stat));
                log(stat);
                log(meldungen.get(stat));
    HomoranH paul53P 3 Antworten Letzte Antwort
    • a200A a200
                  "type": "number",
                  "role": "",
                  "unit": ""
                  "type": "string",
                  "role": "",
                  "unit": ""
          for(i=0;i<5;i++) {
              if(stat){
                  log(stat);
      @a200 sagte in Problemen mit Typ:
      ich habe da irgendwie den Verdacht, dass die bisherige sehr kryptische Fehlermeldung jetzt zwar länger ist, aber so nicht passt.
      Welchen Typ hat denn der Datenpunkt?
      • a200A a200
                    "type": "number",
                    "role": "",
                    "unit": ""
                    "type": "string",
                    "role": "",
                    "unit": ""
            for(i=0;i<5;i++) {
                if(stat){
                    log(stat);
        @a200 sagte:
        Groß-/Kleinschreibung: "Number" und "String" sind unzulässig.
        a200A 1 Antwort Letzte Antwort
          @a200 sagte:
          a200A Offline
          a200A Offline
          a200
          @paul53 wie man in der Datenpunktdefinition sieht nutze ich klein-geschriebenes string und number.
          bei der Javascriptfunktion dachte ich immer das sie Number() heißt. Aber die Änderung auf number() hat geholfen. Danke.
          • a200A a200
                        "type": "number",
                        "role": "",
                        "unit": ""
                        "type": "string",
                        "role": "",
                        "unit": ""
                for(i=0;i<5;i++) {
                    if(stat){
                        log(stat);
            @a200 sagte:
            Diese beiden Datenpunkte enthalten offenbar einen falsch geschriebenen common.type.
