  4. Licht geht allein aus !!
    5.7k
javascript
7 Beiträge 4 Kommentatoren 838 Aufrufe 4 Beobachtet
    bele2000
    Hallo
    habe ein BlocklyScript mit Bewegungsmelder laufen.
      <variables>
        <variable type="undefined" id="timeout">timeout</variable>
      </variables>
      <block type="on" id="gNt!/9v50#T}LQmVt5*;" x="38" y="-87">
        <field name="OID">hm-rpc.0.NEQ1702336.1.MOTION</field>
        <statement name="STATEMENT">
          <block type="controls_if" id="0CMf9(7F7#SON]1?)~0o">
            <value name="IF0">
              <block type="logic_operation" id="6bIT0/BuihM/Q;!ph;7p">
                <field name="OP">AND</field>
                <value name="A">
                  <block type="logic_compare" id="E6PavZ=eZ)vNu:=ES=B}">
                    <field name="OP">EQ</field>
                    <value name="A">
                      <block type="get_value" id="pwFkf)[n[pC1@n=43TUz">
                        <field name="OID">shelly.0.SHSW-1#B8C714#1.Relay0.Switch</field>
                      </block>
                    </value>
                    <value name="B">
                      <block type="logic_boolean" id="ZEu,CyGR-$A`oA?{,*dM">
                      </block>
                    </value>
                  </block>
                </value>
                <value name="B">
                  <block type="time_compare_ex" id="5.Jax##)CH:~UZcS5n9k">
                    <mutation end_time="true" actual_time="true"></mutation>
                    <field name="USE_ACTUAL_TIME">TRUE</field>
                    <field name="OPTION">between</field>
                    <value name="START_TIME">
                      <shadow type="text" id="{ikSrKzK=8yWZ/wDCj|j">
                        <field name="TEXT">19:00</field>
                      </shadow>
                    </value>
                    <value name="END_TIME">
                      <shadow type="text" id="sTDwW6^Cw8Un?DMOEir~">
                        <field name="TEXT">07:00</field>
                      </shadow>
                    </value>
                  </block>
                </value>
              </block>
            </value>
            <statement name="DO0">
              <block type="control" id="58BF~TPF+}c?Y9Pa{0.K">
                <value name="VALUE">
                  <block type="logic_boolean" id="2R`c*;Z[NV/X(ER`6gU]">
                  </block>
                </value>
              </block>
            </statement>
            <next>
              <block type="timeouts_cleartimeout" id="}v~LX.~es]^Lls6o|AU9">
                <next>
                  <block type="timeouts_settimeout" id="gTD@2k%eI?NOkK3y#3CG">
                    <field name="DELAY">20</field>
                      <block type="control" id="GUqGc4l0Y-Z:Bhg,FiXb">
                        <mutation delay_input="true"></mutation>
                        <field name="DELAY_MS">20</field>
                        <field name="CLEAR_RUNNING">TRUE</field>
                          <block type="logic_boolean" id="FsQjOF3tQjJFn(P,qgsC">
                          </block>
                        </value>
                      </block>
                    </statement>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </statement>
      </block>
    </xml>
    Leider funktioniert es nicht wie es soll.
    es soll per Bewegungsmelder ab 19:00Uhr bis 7:00Uhr für 20 sec schalten
    und wenn ich es tagsüber per Schalter schalte soll es an bleiben bis ich es ausschalte.
    aber es geht nach 20 sec aus auch beim schalten über manuellen Schalter
    Zur Info:
    Bewegungsmelder ist Homematic und Schlater ein Shelly1.
    Wo ist mein Fehler ?
    • B bele2000
      Hallo
        <variables>
        </variables>
              <value name="IF0">
                  <value name="A">
                      <value name="A">
                        </block>
                      </value>
                      <value name="B">
                        </block>
                      </value>
                    </block>
                  </value>
                  <value name="B">
                        </shadow>
                      </value>
                        </shadow>
                      </value>
                    </block>
                  </value>
                </block>
              </value>
                    </block>
                  </value>
                </block>
              </statement>
              <next>
                  <next>
                            </block>
                          </value>
                        </block>
                      </statement>
                    </block>
                  </next>
                </block>
              </next>
            </block>
          </statement>
        </block>
      </xml>
      Zur Info:
      @bele2000 sagte:
       <variables>
       </variables>
       <block type="on" id="gNt!/9v50#T}LQmVt5*;" x="-13" y="-187">
             <value name="IF0">
                   </shadow>
                 </value>
                   </shadow>
                 </value>
               </block>
             </value>
               <block type="controls_if" id="1?G405q4KS{_M_2AR+-T">
                 <value name="IF0">
                   <block type="on_source" id="}#9zq:fq1xqVgAk)gA.u">
                   </block>
                 </value>
                     <next>
                           </block>
                         </value>
                       </block>
                     </next>
                   </block>
                 </statement>
                 <statement name="ELSE">
                           </block>
                         </value>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
             </statement>
           </block>
         </statement>
       </block>
      </xml>
        bele2000
        Danke scheint zu klappen !
          bele2000
          habe jetzt festgestellt das es ab 19:00 Uhr doch wieder allein ausgeht wenn ich den Lichtschalter betätige !
          S T 2 Antworten Letzte Antwort
          • B bele2000
            smarthome2020
            @bele2000
            Also du willst folgendes:
            1. Tagsüber soll das Licht nur durch dich angeschaltet werden und dann so lange an bleiben bis du es ausschaltest; keine Triggerung durch Bewegungsmelder?
            2. Ab 19 Uhr bis 7 Uhr soll es hingegen nur durch den Bewegungsmelder gesteuert werden für 20 Sekunden? Oder willst du hier auch noch die Option zum selber schalten und abschalten durch den Schalter?
            • B bele2000
              T Nicht stören
              T Nicht stören
              ticaki
              @bele2000
              Du must im Objekt ID Feld noch deinen Schalterpunkt einfügen. Der Bewegungsmelder schaltet nur noch in der vorgegebenen Zeit und wenn der Schalter auf aus steht.
              EDIT: Ach ne das funktioniert nicht mit shellys denke ich.
                <variables>
                </variables>
                      <value name="IF0">
                        <block type="logic_operation" id="x2?nQqLE@+i7dUBI_ZmL">
                          <value name="A">
                                </shadow>
                              </value>
                                </shadow>
                              </value>
                            </block>
                          </value>
                          <value name="B">
                            <block type="logic_negate" id="7P)PQNLq%zo?OKb8R1UF">
                              <value name="BOOL">
                                <block type="get_value" id="+dOk8]qh3/z_#jRHL3oV">
                                  <field name="OID">ID auswählen</field>
                                </block>
                              </value>
                            </block>
                          </value>
                        </block>
                      </value>
                          <value name="IF0">
                            </block>
                          </value>
                              <next>
                                    </block>
                                  </value>
                                </block>
                              </next>
                            </block>
                          </statement>
                                    </block>
                                  </value>
                                </block>
                              </statement>
                            </block>
                          </statement>
                        </block>
                      </statement>
                    </block>
                  </statement>
                </block>
              </xml>
              Mit shellys sollte das hier funktionieren. Mußt aber ebenfalls den Schalterpunkt noch einfügen. Bekannter Fehler: Wenn die Lampe an ist, während iobroker/Adapter/Script neugestartet wird, bleibt das Licht an.
               <variables>
                 <variable type="" id="(/r7QN5y5M`.Zx)f!Sc-">auto</variable>
               </variables>
               <block type="on" id="gNt!/9v50#T}LQmVt5*;" x="-38" y="-238">
                     <value name="IF0">
                         <value name="A">
                               </shadow>
                             </value>
                               </shadow>
                             </value>
                           </block>
                         </value>
                         <value name="B">
                           <block type="logic_compare" id="VjodfKPBdu[S/RsFUWlz">
                             <value name="A">
                               <block type="logic_negate" id="+yAfku(n0ylct0#Wgx@s">
                                 <value name="BOOL">
                                   <block type="variables_get" id="SI}ws7RFckw%[5xCec|p">
                                     <field name="VAR" id="(/r7QN5y5M`.Zx)f!Sc-" variabletype="">auto</field>
                                   </block>
                                 </value>
                               </block>
                             </value>
                             <value name="B">
                               <block type="logic_negate" id="Op%22kc+=FfHmBQ:6?Tc">
                                 <value name="BOOL">
                                   </block>
                                 </value>
                               </block>
                             </value>
                           </block>
                         </value>
                       </block>
                     </value>
                         <value name="IF0">
                           </block>
                         </value>
                             <next>
                               <block type="variables_set" id="!vb/Nbhhj{v(L%grbn#3">
                                   <block type="logic_boolean" id="/{fE/_-gj/3Sv6wH?-(y">
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </next>
                           </block>
                         </statement>
                               <block type="variables_set" id="A2(TwbZpTV/Kpvl}JY{/">
                                   <block type="logic_boolean" id="r*w@rI?im}`LZ?ZEVY;[">
                                   </block>
                                 </value>
                                 <next>
                                       </block>
                                     </value>
                                   </block>
                                 </next>
                               </block>
                             </statement>
                           </block>
                         </statement>
                       </block>
                     </statement>
                   </block>
                 </statement>
               </block>
              </xml>
              Spenden
                bele2000
                @smarthome2020
                Danke Dir
                nach 19:00 Uhr will ich auch die Option mit schalter schalten solange bis ich aussschalte !
                @ticaki
                Danke Dir
                teste das 2te script mal weil Shelly
