  4. Fehler bei start des web adapters....
web adapter
1 Beiträge 1 Kommentatoren 302 Aufrufe 1 Beobachtet
    andyb
    schrieb am zuletzt editiert von andyb
    beim start des web adapters bekomme ich folgende Logeinträge. Vis etc lassen sich auch nicht mehr aufrufen.
    host.iob2	2020-03-30 12:05:28.699	info	Restart adapter system.adapter.web.0 because enabled
    host.iob2	2020-03-30 12:05:28.699	info	instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at Zlib.processCallback (zlib.js:557:8)
    host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at InflateRaw.afterTransform (_stream_transform.js:94:3)
    host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at onwrite (_stream_writable.js:476:7)
    host.iob2	2020-03-30 12:05:28.697	error	Caught by controller[0]: at afterWrite (_stream_writable.js:485:3)
    host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
    host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
    host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    host.iob2	2020-03-30 12:05:28.696	error	Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    web.0	2020-03-30 12:05:28.168	info	(10228) Terminated (NO_ERROR): Without reason
    web.0	2020-03-30 12:05:28.167	info	(10228) terminating
    web.0	2020-03-30 12:05:28.115	info	(10228) terminated http server on port 8082
    web.0	2020-03-30 12:05:28.113	error	(10228) TypeError: Cannot read property 'isValidUTF8' of undefined at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29 at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7 at /opt/io
    web.0	2020-03-30 12:05:28.113	error	(10228) uncaught exception: Cannot read property 'isValidUTF8' of undefined
    web.0	2020-03-30 12:05:28.071	info	(10228) ==>Connected system.user.admin from ::ffff:192.168.1.3
    web.0	2020-03-30 12:05:27.281	info	(10228) <==Disconnect system.user.admin from ::ffff:192.168.1.3 vis.0
    web.0	2020-03-30 12:05:27.237	info	(10228) ==>Connected system.user.admin from ::ffff:192.168.1.3
    web.0	2020-03-30 12:05:27.006	info	(10228) http server listening on port 8082
    web.0	2020-03-30 12:05:27.002	info	(10228) socket.io server listening on port 8082
    web.0	2020-03-30 12:05:26.627	info	(10228) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.19.0
    host.iob2	2020-03-30 12:05:24.763	info	instance system.adapter.web.0 started with pid 10228
    host.iob2	2020-03-30 12:04:54.742	info	Restart adapter system.adapter.web.0 because enabled
    host.iob2	2020-03-30 12:04:54.741	info	instance system.adapter.web.0 terminated with code 0 (NO_ERROR)
    host.iob2	2020-03-30 12:04:54.741	error	Caught by controller[0]: at Zlib.processCallback (zlib.js:557:8)
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at InflateRaw.afterTransform (_stream_transform.js:94:3)
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at onwrite (_stream_writable.js:476:7)
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at afterWrite (_stream_writable.js:485:3)
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/PerMessageDeflate.js:249:5
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7
    host.iob2	2020-03-30 12:04:54.740	error	Caught by controller[0]: at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29
    host.iob2	2020-03-30 12:04:54.739	error	Caught by controller[0]: TypeError: Cannot read property 'isValidUTF8' of undefined
    web.0	2020-03-30 12:04:54.098	info	(10198) Terminated (NO_ERROR): Without reason
    web.0	2020-03-30 12:04:54.097	info	(10198) terminating
    web.0	2020-03-30 12:04:54.044	info	(10198) terminated http server on port 8082
    web.0	2020-03-30 12:04:54.042	error	(10198) TypeError: Cannot read property 'isValidUTF8' of undefined at /opt/iobroker/node_modules/ws/lib/Receiver.js:532:29 at /opt/iobroker/node_modules/ws/lib/Receiver.js:368:7 at /opt/io
    web.0	2020-03-30 12:04:54.042	error	(10198) uncaught exception: Cannot read property 'isValidUTF8' of undefined
    web.0	2020-03-30 12:04:54.000	info	(10198) ==>Connected system.user.admin from ::ffff:192.168.1.3
    web.0	2020-03-30 12:04:41.297	info	(10198) http server listening on port 8082
    web.0	2020-03-30 12:04:41.293	info	(10198) socket.io server listening on port 8082
    web.0	2020-03-30 12:04:40.924	info	(10198) starting. Version 2.4.10 in /opt/iobroker/node_modules/iobroker.web, node: v10.19.0
    host.iob2	2020-03-30 12:04:38.785	info	instance system.adapter.web.0 started with pid 10198
    host.iob2	2020-03-30 12:04:38.764	info	"system.adapter.web.0" enabled
    Edit: die Fehler kommen nicht beim Start des web adapters, erst beim Aufrufen von Vis!?:man-shrugging:
