  4. Fehler: Cannot install iobroker.vis@1.2.4: 1 error 25
    2.8k
    4.9k
    4.1k
vis
3 Beiträge 2 Kommentatoren 1.3k Aufrufe 2 Beobachtet
  • Francis HartmannF Offline
    Francis Hartmann
    Ich bekomme folgende Fehlermeldung beim installieren von Vis Adapter
    $ ./iobroker add vis  --host DESKTOP*
    NPM version: 6.13.4
    npm install iobroker.vis@1.2.4 --loglevel error --prefix "C:/iobroker" (System call)
    npm
     ERR! code EEXISTnpm ERR! path C:\iobroker\node_modules\semver\bin\semvernpm ERR! dest C:\iobroker\semver
    npm
    ERR! EEXIST: file already exists, cmd shim 'C:\iobroker\node_modules\semver\bin\semver' -> 'C:\iobroker\semver'npm ERR! File exists: C:\iobroker\semvernpm ERR! Remove the existing file and try again, or run npmnpm ERR! with --force to overwrite files recklessly.
    npm ERR! A complete log of this run can be found in:npm ERR!     C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_logs\2020-03-26T09_53_24_450Z-debug.log
    ERROR: host.DESKTOP* Cannot install iobroker.vis@1.2.4: 1
    Im Explorer
    C:\iobroker\node_modules existiert kein directory \semver\bin\semver
    Wie soll ich da vorgehen um dieses problem zu lösen?
    Hier ein auszug aus dem log:
    1388 verbose linkBins [ { semver: 'bin/semver' }, 'C:\\iobroker', true ]
    1389 timing action:build Completed in 13ms
    1390 verbose unlock done using C:\WINDOWS\system32\config\systemprofile\AppData\Roaming\npm-cache\_locks\staging-75c4853d5d99f16b.lock for C:\iobroker\node_modules\.staging
    1391 timing stage:rollbackFailedOptional Completed in 167ms
    1392 timing stage:runTopLevelLifecycles Completed in 5083ms
    1393 verbose stack Error: EEXIST: file already exists, cmd shim 'C:\iobroker\node_modules\semver\bin\semver' -> 'C:\iobroker\semver'
    1393 verbose stack     at simulateEEXIST (C:\Program Files\nodejs\node_modules\npm\node_modules\gentle-fs\lib\bin-link.js:87:15)
    1393 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\gentle-fs\lib\bin-link.js:78:17
    1393 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\read-cmd-shim\index.js:51:29
    1393 verbose stack     at C:\Program Files\nodejs\node_modules\npm\node_modules\graceful-fs\graceful-fs.js:115:16
    1393 verbose stack     at FSReqCallback.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:63:3)
    1394 verbose cwd C:\iobroker
    1395 verbose Windows_NT 10.0.18362
    1396 verbose argv "C:\\Program Files\\nodejs\\node.exe" "C:\\Program Files\\nodejs\\node_modules\\npm\\bin\\npm-cli.js" "install" "iobroker.vis@1.2.4" "--loglevel" "error" "--prefix" "C:/iobroker"
    1397 verbose node v12.16.1
    1398 verbose npm  v6.13.4
    1399 error code EEXIST
    1400 error path C:\iobroker\node_modules\semver\bin\semver
    1401 error dest C:\iobroker\semver
    1402 error EEXIST: file already exists, cmd shim 'C:\iobroker\node_modules\semver\bin\semver' -> 'C:\iobroker\semver'
    1403 error File exists: C:\iobroker\semver
    1404 error Remove the existing file and try again, or run npm
    1405 error with --force to overwrite files recklessly.
    1406 verbose exit [ 1, true ]
    • L Offline
      littleBastard
      @Francis-Hartmann Ich hatte das selbe Problem. Habe dann ein bisschen gesucht im Forum und habe mit folgenden Aktionen den Vis Adapter installieren können:
      • Im Verzeichnis C:\iobroker die "semver" Files auf den Desktop verschoben, können auch gelöscht werden
      Danach lief die Installation zwar weiter aber es kam wieder ein ähnlicher Error, jedoch mit einem anderen File. Somit das selbe mit den Dateien gemacht.
      • Im Verzeichnis C:\iobroker die "mime" Files auf den Desktop verschoben, können auch gelöscht werden
      Es waren jeweils 3 Files.
      Danach lief die Installation bei mir durch. Hoffe es klappt bei Dir auch.
        Francis Hartmann
        @littleBastard Genial, das hat auf anhieb geklappt.
        Vielen herzlichen Dank
