  4. Homematic Regensensor
2 Beiträge 2 Kommentatoren 1.0k Aufrufe
  • F Offline
    Fugazzy
    Hallo, ich habe gerade einmal den HM Regensensor in Betrieb genommen,
    aber gibt es folgende Meldung im Log:
    ! hm-rpc-0 2016-07-28 21:24:09.061 warn xmlrpc <- undefined method readdedDevice ["hm-rpc.0",["KEQ0117178","KEQ0117178:0","KEQ0117178:1","KEQ0117178:2"]]
    ! hm-rpc-0 2016-07-28 21:23:48.714 warn xmlrpc <- undefined method readdedDevice ["hm-rpc.0",["KEQ0117178","KEQ0117178:0","KEQ0117178:1","KEQ0117178:2"]]
    ! hm-rpc-0 2016-07-28 21:23:42.031 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INHIBIT":{"CONTROL":"NONE","DEFAULT":false,"FLAGS":1,"ID":"INHIBIT","MAX":t
    ! hm-rpc-0 2016-07-28 21:23:42.029 info Send this info to developer: setObject hm-rpc.meta.VALUES.HM-Sen-RD-O.RAINDETECTOR_HEAT.21
    ! hm-rpc-0 2016-07-28 21:23:41.960 info xmlrpc -> getParamsetDescription ["KEQ0117178:2","VALUES"]
    ! hm-rpc-0 2016-07-28 21:23:41.766 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"INSTALL_TEST":{"DEFAULT":false,"FLAGS":3,"ID":"INSTALL_TEST","MAX":true,"MI
    ! hm-rpc-0 2016-07-28 21:23:41.764 info Send this info to developer: setObject hm-rpc.meta.VALUES.HM-Sen-RD-O.RAINDETECTOR.21
    ! hm-rpc-0 2016-07-28 21:23:41.717 info xmlrpc -> getParamsetDescription ["KEQ0117178:1","VALUES"]
    ! hm-rpc-0 2016-07-28 21:23:41.302 warn Send this info to developer: {"type":"meta","meta":{"adapter":"hm-rpc","type":"paramsetDescription"},"common":{},"native":{"AES_KEY":{"DEFAULT":0,"FLAGS":0,"ID":"AES_KEY","MAX":127,"MIN":0,"OPERATION
    ! hm-rpc-0 2016-07-28 21:23:41.299 info Send this info to developer: setObject hm-rpc.meta.VALUES.HM-Sen-RD-O.MAINTENANCE.21
    ! hm-rpc-0 2016-07-28 21:23:38.755 info xmlrpc -> getParamsetDescription ["KEQ0117178:0","VALUES"]
    ! hm-rpc-0 2016-07-28 21:23:38.555 info xmlrpc <- newDevices 4
    • F Offline
      Fitti
      ich habe ständig solche Meldungen, wenn ich ein Gerät neu in der CCU anlege. In den letzten Tagen hatte ich einige Rolladen und Heizungsthermostaten hinzugefügt.
      Ich vermute, dass es beim Anlernen und Umbenennen in der CCU einfach refresh Themen gibt. Denn das Gerät taucht sehr schnell in ioBroker mit seinem Anlernnamen auf.
      Starte einfach mal ioBroker neu. Zwar sollte eigentlich nur das Neustarten des HM-Rega-Adapter helfen, bei mir wurden dann aber nicht alle Kanäle richtig angelegt - selbst nicht nach einer Nacht warten.
      Nachdem ich aber das gesamte Gerät rebootete, war alles da - nach einiger Zeit.
      Versuchs mal. Vielelciht hat ja jemand anderes noch eine Idee?
      So long,
      Fitti
      "Es wird die Zeit kommen, da ihr euch entscheiden müsst zwischen dem, was richtig ist, und dem, was bequem ist."
      Plural von Status ist auch Status!
