  4. Sunny Webbox direkt auslesen auch einzelne Geräte (GetProcessData + GetPlantOverview)
1 Beiträge 1 Kommentatoren 1.7k Aufrufe
  • W Offline
    W Offline
    wobo
    Ich habe eine Lösung wie man direkt alle Daten auslesen kann.
    "id": "f3f362c6.7083d",
    "type": "inject",
    "z": "cf838eb3.2423c8",
    "name": "",
    "topic": "",
    "payload": "",
    "payloadType": "date",
    "repeat": "5",
    "crontab": "",
    "once": false,
    "x": 134.14987182617187,
    "y": 194.030029296875,
    "wires": [
    "1b87043a.fbbf6",
    "afd0a28b.1f2c6",
    "f09d259f.a79f38"
    "id": "1b87043a.fbbf6",
    "type": "http request",
    "name": "SMA WEBBOX Wechselrichter",
    "method": "GET",
    "ret": "obj",
    "url": "http://192.168.10.253/rpc?RPC={%22versi … %22JSON%22}",
    "tls": "",
    "x": 396.8999328613281,
    "y": 136.8699951171875,
    "wires": [
    "2c5dbb84.78d7d4"
    "id": "2c5dbb84.78d7d4",
    "type": "function",
    "name": "Strom auslesen",
    "func": "// Script von Wolfgang Boldt\n// Aktueller Leistung\nmsg1 = {};\nmsg1.payload = msg.payload.result.overview[0].value + " " + msg.payload.result.overview[0].unit;\n// Tagesertrag\nmsg2 = {};\nmsg2.payload = msg.payload.result.overview[1].value + " " + msg.payload.result.overview[1].unit;\n// Gesamtertrag der Anlage\nmsg3 = {};\nmsg3.payload = msg.payload.result.overview[2].value + " " + msg.payload.result.overview[2].unit ;\n//Aktuelle Leistung ohne Maßeinheit\nmsg4 = {};\nmsg4.payload = msg.payload.result.overview[0].value; \nreturn [msg1,msg2,msg3,msg4];",
    "outputs": "4",
    "noerr": 0,
    "x": 637.1698913574219,
    "y": 126.69003295898437,
    "wires": [
    "8a1b5dd0.6b3c"
    "9eace255.2e9bf"
    "97268ca0.9440a"
    "id": "8a1b5dd0.6b3c",
    "type": "ioBroker out",
    "name": "SMA Webbox Leistung",
    "topic": "hm-rega.0.5942",
    "ack": "false",
    "autoCreate": "false",
    "x": 1270.8800048828125,
    "y": 35.900001525878906,
    "wires": []
    "id": "9eace255.2e9bf",
    "name": "SMA Webbox Tagesertrag",
    "topic": "hm-rega.0.5941",
    "ack": "false",
    "x": 1289.0499267578125,
    "y": 86.2000732421875,
    "wires": []
    "id": "97268ca0.9440a",
    "name": "SMA Webbox Gesamtertrag",
    "topic": "hm-rega.0.5943",
    "ack": "false",
    "x": 1288.4599609375,
    "y": 137.1200408935547,
    "wires": []
    "id": "afd0a28b.1f2c6",
    "name": "SMA Webbox Sensorbox ( Wert eines einzelnen Gerätes Auslesen )",
    "method": "GET",
    "ret": "obj",
    "url": "http://192.168.10.253/rpc?RPC={%22versi … devices%22:[{%22key%22:%220088:0000725b%22,%22channels%22:null}]}}}",
    "tls": "",
    "x": 502.4698791503906,
    "y": 263.40997314453125,
    "wires": [
    "faa4bb62.eff298"
    "id": "faa4bb62.eff298",
    "type": "function",
    "name": "Sensoren auslesen",
    "func": "// Script von Wolfgang Boldt\n// Aktueller Windgeschwindigkeit\nmsg1 = {};\nmsg1.payload = msg.payload.result.devices[0].channels [2].value; + " " + msg.payload.result.devices[0].channels [2].unit;\n// Aussen Temperatur\nmsg2 = {};\nmsg2.payload = msg.payload.result.devices[0].channels [3].value; + " " + msg.payload.result.devices[0].channels [3].unit;\n// Einstrahlung\nmsg3 = {};\nmsg3.payload = msg.payload.result.devices[0].channels [4].value + " " + msg.payload.result.devices[0].channels [4].unit;\n// Modultemperatur\nmsg4 = {};\nmsg4.payload = msg.payload.result.devices[0].channels [9].value; + " " + msg.payload.result.devices[0].channels [9].unit;\nreturn [msg1,msg2,msg3,msg4];",
    "outputs": "4",
    "noerr": 0,
    "x": 877.0500793457031,
    "y": 263.3901062011719,
    "wires": [
    "2376655c.a82c66"
    "7ddd2192.c4c274"
    "49e80443.6f49d8"
    "860f21bf.5c1108"
    "id": "7ddd2192.c4c274",
    "name": "SMA Aussentemperatur",
    "topic": "hm-rega.0.5944",
    "ack": "false",
    "x": 1275.9500732421875,
    "y": 271.0299987792969,
    "wires": []
    "id": "2376655c.a82c66",
    "name": "SMA Windgeschwindigkeit",
    "topic": "hm-rega.0.5945",
    "ack": "false",
    "x": 1287.7598876953125,
    "y": 223.1500244140625,
    "wires": []
    "id": "49e80443.6f49d8",
    "name": "SMA Einstrahlung",
    "topic": "hm-rega.0.5947",
    "ack": "false",
    "x": 1255.93994140625,
    "y": 324.57000732421875,
    "wires": []
    "id": "860f21bf.5c1108",
    "name": "SMA Modultemperatur",
    "topic": "hm-rega.0.5946",
    "ack": "false",
    "x": 1264.7200927734375,
    "y": 374.8700256347656,
    "wires": []
    "id": "f09d259f.a79f38",
    "name": "SMA WEBBOX Wechselrichter Geräte auslesen",
    "method": "GET",
    "ret": "obj",
    "url": "[http://192.168.10.253/rpc?RPC={\](http://192.168.10.253/rpc?RPC={\"version\":\"1.0\",\"proc\":\"GetDevices\",\"id\":\"1\",\"format\":\"JSON)\"}}",
    "tls": "",
    "x": 442.9698791503906,
    "y": 346.0899963378906,
    "wires": [
    "edfe99b4.8a0048"
    "id": "edfe99b4.8a0048",
    "type": "function",
    "name": "Key auslesen",
    "func": "// Script von Wolfgang Boldt\n// Anzahl der Geräte\nmsg1 = {};\nmsg1.payload = msg.payload.result.totalDevicesReturned;\n// Key Gerät eins\nmsg2 = {};\nmsg2.payload = msg.payload.result.devices[0].key;\n// Key Gerät zwei\nmsg3 = {};\nmsg3.payload = msg.payload.result.devices[1].key;\n// Key Gerät drei\nmsg4 = {};\nmsg4.payload = msg.payload.result.devices[2].key;\nreturn [msg1,msg2,msg3,msg4,];",
    "outputs": "4",
    "noerr": 0,
    "x": 756.6199645996094,
    "y": 345.4900207519531,
    "wires": [
    "id": "c9f47099.5dd5a",
    "type": "comment",
    "name": "Kommentar für einzelne Geräte aus der Webbox ",
    "info": "in den html Strin muss der jeweilige Key eingetragen werden.\nhttp://192.168.10.253 == IP Adresse der SMA Webbox\n0088:0000725 == Key des Gerätes in diesen Fall eine Sensorbox\n\nhttp://192.168.10.253/rpc?RPC={"version":"1.0","proc":"GetProcessData","id":"1","format":"JSON","params":{"devices":[{"key":"0088:0000725b","channels":null}]}}}",
    "x": 442.1498718261719,
    "y": 225.47998046875,
    "wires": []
