  3. Entwicklung
  4. npm test failed
npm test failed
npmnpm errornpm test
12 Beiträge 3 Kommentatoren 1.3k Aufrufe 3 Beobachtet
  • GrizzelbeeG Offline
    GrizzelbeeG Offline
    Grizzelbee
    Guten Morgen zusammen,
    ich habe meinen Miele@Home Adapter endlich umgeschrieben und möchte ihn nun in Kürze veröffentlichen. dazu will ich habe das "npm test" und "npm ci" beides läuft .. soll ja alles sauber sein. :)
    Ich bekomme aber bei "npm test" noch einen Fehler angezeigt, den ich nicht deuten kann. Hier mal das komplette log:
    C:\Users\hanjo\WebstormProjects\ioBroker.mieleathome>npm test
    > iobroker.mieleathome@1.0.0 test C:\Users\hanjo\WebstormProjects\ioBroker.mieleathome
    > node node_modules/mocha/bin/mocha --exit
    Running tests in C:\Users\hanjo\AppData\Local\Temp\test-iobroker.mieleathome
      Test the adapter (in a live environment)
        1) "before all" hook for "The adapter starts"
      Validate the package files
        Ensure they are readable
          package.json
            √ exists
            √ contains valid JSON
            √ is an object
          io-package.json
            √ exists
            √ is an object
        Check contents of package.json
          √ The property "name" exists
          √ The property "version" exists
          √ The property "description" exists
          √ The property "author" exists
          √ The property "license" exists
          √ The property "main" exists
          √ The property "repository" exists
          √ The property "repository.type" exists
          √ The package name is correct
          √ The repository type is "git"
        Check contents of io-package.json
          √ The property "common.name" exists
          √ The property "common.title" exists
          √ The property "common.version" exists
          √ The property "common.news" exists
          √ The property "common.desc" exists
          √ The property "common.icon" exists
          √ The property "common.extIcon" exists
          √ The property "common.license" exists
          √ The property "common.type" exists
          √ The property "common.authors" exists
          √ The property "native" exists
          √ The title does not contain "adapter" or "iobroker"
          √ The description is an object to support multiple languages
          √ common.authors is an array that is not empty
          √ common.news is an object that contains maximum 20 entries
          √ Materialize is supported
        Compare contents of package.json and io-package.json
          √ The name matches
          √ The version matches
          √ The license matches
      Test the adapter (in a mocked environment)
        2) The adapter starts in normal mode
        √ The adapter starts in compact mode (83ms)
      36 passing (1s)
      2 failing
      1) Test the adapter (in a live environment)
           "before all" hook for "The adapter starts":
         Error: JS-Controller is already running! Stop it for the first test run and try again!
          at Context.<anonymous> (node_modules\@iobroker\testing\build\tests\integration\index.js:48:27)
          at Generator.next (<anonymous>)
          at fulfilled (node_modules\@iobroker\testing\build\tests\integration\index.js:6:58)
          at process._tickCallback (internal/process/next_tick.js:68:7)
      2) Test the adapter (in a mocked environment)
           The adapter starts in normal mode:
         AssertionError: process.exit was called with the unexpected exit code 11!: expected [] to include 11
          at assertValidExitCode (node_modules\@iobroker\testing\build\tests\unit\index.js:32:41)
          at Context.<anonymous> (node_modules\@iobroker\testing\build\tests\unit\index.js:67:17)
          at fulfilled (node_modules\@iobroker\testing\build\tests\unit\index.js:7:58)
    npm ERR! Test failed.  See above for more details.
    Ich verstehe nur einfach nicht, was npm mir da sagen will. Googlen nach den Fehlern hat auch nichts vernünftiges zutage gebracht.
    der komplette code des Adapters findet sich unter: https://github.com/Grizzelbee/ioBroker.mieleathome/tree/Development_V1.0.0
    Kann mir vielleicht jemand helfen?
    viele Grüße
    Grizeelbee
    • GrizzelbeeG Grizzelbee
            package.json
              √ exists
              √ is an object
            io-package.json
              √ exists
              √ is an object
            √ The name matches
        36 passing (1s)
        2 failing
      viele Grüße
      Grizeelbee
      AlCalzoneA Offline
      AlCalzoneA Offline
      AlCalzone
      schrieb am zuletzt editiert von AlCalzone
      @Grizzelbee sagte in npm test failed:
      Was ist daran denn nicht verständlich?
      Während deinem Start wird die Konfiguration geprüft und wegen nicht vorhandener Konfiguration der Adapter mit Code 11 beendet (terminate).
      Hierfür musst du die Unit-Test-Datei anpassen (test/unit.js)
      ==> https://github.com/ioBroker/testing#adapter-startup-unit-test
      Entweder du ergänzt die nötigen Objekte, damit die Prüfung erfolgreich ist (overwriteAdapterConfig, oder du fügst Exit code 11 den erlaubten Exit codes (allowedExitCodes) hinzu.
      • OliverIOO Offline
        OliverIOO Offline
        OliverIO
        hm, da ich die tests bei mir alle einzeln anstosse:
        npm run test:package
        npm run test:unit
        npm run test:integration
        ist das der fehler, der bei mir beim 3.Test (integration) kommt, wenn ich vergesse
        vorher den iobroker zu stoppen. die anderen beiden können mit laufendem iobroker durchgeführt werden.
        Beim integration-test wird ein zusätzlicher iobroker gestartet und das funktioniert natürlich nicht, weil da die selben ports schon alle belegt sind.
        also einfach vor dem test
        iobroker stop eingeben
        ein anpassen meiner testdateien war bei mir nie nötig. sind alle noch standard
        Meine Adapter und Widgets
        Links im Profil
          GrizzelbeeG Offline
          Grizzelbee
          Hallo !
          vielen dank für eure Antworten.
          @OliverIO: das bloße stoppen von ioBroker reicht in meinem Fall offenbar nicht aus. npm test failed immer noch auf die selbe Art.
          @AlCalzone: Eine echte Config kann ich leider nicht hinterlegen, weil da creadentials drin sind. Aber ich gucke mir das Thema Unit-Tets jetzt auf jeden Fall mal genauer an - wollte ich eh.
          viele Grüße
          Grizzelbee
          • OliverIOO OliverIO
            npm run test:unit
            AlCalzoneA Offline
            AlCalzoneA Offline
            AlCalzone
            @OliverIO sagte in npm test failed:
            Je Adapter sollte das nur einmal nötig sein, da für die Tests ein temporärer JS-Controller in einem temporären Verzeichnis installiert wird. Fürs einmalige Einrichten müssen die Standard-Ports (9000, 9001) frei sein. Danach laufen die Tests mit dem umkonfigurierten Controller auf einem anderen Port.
              GrizzelbeeG Offline
              Grizzelbee
              Guten Morgen!
              Ich brauche bitte noch einmal Hilfe mit diesem Thema. :(
              Ich habe das Problem mit dem Exitcode 11 schon wieder:
                  √ The adapter starts in normal mode (112ms)
                  1) The adapter starts in normal mode
                37 passing (28s)
                1 failing
                1) Test the adapter (in a mocked environment)
                   Uncaught Error: Adapter.terminate was called (exit code 11): Invalid Configuration.
                    at AdapterConstructor.terminate (node_modules\@iobroker\testing\build\tests\unit\mocks\mockAdapter.js:359:25)
                    at Object.invoke (node_modules\sinon\lib\sinon\behavior.js:163:32)
                    at AdapterConstructor.functionStub (node_modules\sinon\lib\sinon\stub.js:39:43)
                    at Function.invoke (node_modules\sinon\lib\sinon\proxy-invoke.js:47:47)
                    at AdapterConstructor.functionStub [as terminate] (node_modules\sinon\lib\sinon\proxy.js:214:26)
                    at main (main.js:722:17)
                    at adapter.getForeignObject (main.js:102:17)
                    at AdapterConstructor.getForeignObject (node_modules\@iobroker\testing\build\tests\unit\mocks\mockAdapter.js:170:17)
                    at AdapterConstructor.functionStub [as getForeignObject] (node_modules\sinon\lib\sinon\proxy.js:214:26)
                    at AdapterConstructor.ready (main.js:91:21)
                    at Object.<anonymous> (node_modules\@iobroker\testing\build\tests\unit\harness\startMockAdapter.js:97:45)
                    at C:\Users\hanjo\WebstormProjects\ioBroker.mielecloudservice\node_modules\@iobroker\testing\build\tests\unit\harness\startMockAdapter.js:9:71
                    at new Promise (<anonymous>)
                    at __awaiter (node_modules\@iobroker\testing\build\tests\unit\harness\startMockAdapter.js:5:12)
                    at Object.startMockAdapter (node_modules\@iobroker\testing\build\tests\unit\harness\startMockAdapter.js:37:12)
                    at Context.<anonymous> (node_modules\@iobroker\testing\build\tests\unit\index.js:66:83)
                    at C:\Users\hanjo\WebstormProjects\ioBroker.mielecloudservice\node_modules\@iobroker\testing\build\tests\unit\index.js:10:71
                    at __awaiter (node_modules\@iobroker\testing\build\tests\unit\index.js:6:12)
                    at Context.<anonymous> (node_modules\@iobroker\testing\build\tests\unit\index.js:62:20)
              Ich verstehe aber nicht warum!
              Sowohl in der Integration.js als auch in der unit.js habe den exitcode explizit erlaubt. Das hat ja auch eine ganze Zeit lang problemlos funktioniert.
              Kann da bitte noch einmal jemand drüber gucken und mir einen Tipp geben? Ich stehe gerade echt auf dem Schlauch.
              Vielen Dank im Voraus und viele Grüße
              Grizzelbee
                Guten Morgen!
                  37 passing (28s)
                  1 failing
                Grizzelbee
                AlCalzoneA Offline
                AlCalzoneA Offline
                AlCalzone
                @Grizzelbee Hast du mal einen Link zu nem Repo, wo ich das testen könnte?
                GrizzelbeeG 1 Antwort Letzte Antwort
                • AlCalzoneA AlCalzone
                  GrizzelbeeG Offline
                  GrizzelbeeG Offline
                  Grizzelbee
                  @AlCalzone
                  Natürlich! Gerne. :)
                  https://github.com/Grizzelbee/ioBroker.mielecloudservice/tree/Development_V1.2.2
                  Am besten tatsächlich den 1.2.2 Branch. Dann könnte ich den Fix dort unterbringen und anschließend mergen. Am Ende ist mir aber jede Lösung recht.
                    @AlCalzone
                    AlCalzoneA Offline
                    AlCalzoneA Offline
                    AlCalzone
                    @Grizzelbee Ehrliche Antwort: Lass den Unit-Test weg, also nicht npm run test:unit als Teil des Testings ausführen.
                    Das Problem ist folgendes: deine on("ready")-Methode ruft eine Funktion mit callback auf, und darin wird der Prozess beendet (terminate aufgerufen). In Unit-Tests wird ein beendeter Prozess über Errors abgebildet, das geht im vorliegenden Fall einfach nicht sauber, weil der Error erst nach dem durchgelaufenen Test aufschlägt.
                      GrizzelbeeG Offline
                      GrizzelbeeG Offline
                      Grizzelbee
                      @AlCalzone
                      Herzlichen Dank für deine Mühe und vor allem die ausführliche Anrtwort - sie hat mich in die Lage versetzt die Lösung zu finden, die ich jetzt implementiert habe:
                      Da es mir nicht richtig behagt die Unittests einfach zu entsorgen (ich möchte die ja schon noch implementieren) und Du gesagt hast, das das eigentliche Problem die Callback in der main() ist (die ich allerdings nicht als solche erkenne) habe ich jetzt die
                      Prüfung der Config, die ja das terminate auslöst aus der main() herausgenommen und in die on(Ready) verlagert.
                      Das bestätigt deine Aussage und die Tests funktierien. :)
                      Danke noch einmal und viele Grüße
                      Grizzelbee
                        @AlCalzone
                        Grizzelbee
                        AlCalzoneA Offline
                        AlCalzoneA Offline
                        AlCalzone
                        @Grizzelbee wichtiger sind die Integration tests, die einen echten js-controller verwenden. Code verbiegen, um den speziellen Anforderungen der unit tests gerecht zu werden ist imo unnötig.
                          GrizzelbeeG Offline
                          GrizzelbeeG Offline
                          Grizzelbee
                          @AlCalzone
                          Da gebe ich dir grundsätzlich recht.
                          Im vorliegenden Fall finde ich den Umbau aber sogar besser, weil ich jetzt vor dem Aufruf von Main() prüfe ob überhaupt die Voraussetzungen dafür erfüllt sind. Meiner Meinung nach ist der Code dadurch besser geworden.
                          Viele Grüße
                          Grizzelbee
