  4. iobroker.mqtt kill every 3 mins
    2.8k
    4.9k
    4.1k
iobroker.mqttrestartskill
2 Beiträge 2 Kommentatoren 516 Aufrufe 2 Beobachtet
    ManuelW
    Systemdata Bitte Ausfüllen
    Hardwaresystem: Linux PC
    Arbeitsspeicher: 8GB
    Festplattenart: SSD
    Betriebssystem: Ubuntu 18.x LTS
    Node-Version: 10.18.1
    Nodejs-Version: 10.18.1
    NPM-Version: 6.13.4
    Installationsart: Adapter Admin
    Image genutzt: Nein
    seit meinem Update von node 8.x auf 10.x wird der iobroker.mqtt Adapter regelmäßig alle ca. 3min gekillt. Ich habe keine cron eingerichtet die das machen.
    2020-01-18 08:32:30.351  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:36:01.402  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:39:32.456  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:43:03.497  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:46:34.538  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:50:05.601  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:53:36.723  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 08:57:07.771  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:00:38.887  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:04:09.936  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:07:40.980  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:11:12.023  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:14:43.067  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-18 09:18:14.124  - error: host.zeus instance system.adapter.mqtt.0 terminated with code 156 (156)
    2020-01-16 13:29:06.642  - info: mqtt.0 (19331) send2Server system.adapter.admin.0.sigKill[undefined]
    2020-01-16 13:29:06.642  - info: mqtt.0 (19331) send2Server system.adapter.admin.0.sigKill[system/adapter/admin/0/sigKill]
    2020-01-16 13:29:06.645  - warn: admin.0 (18309) Got terminate signal. Checking desired PID:  vs own PID 18309
    2020-01-16 13:29:06.650  - info: admin.0 (18309) terminating http server on port 8081
    2020-01-16 13:29:06.651  - info: admin.0 (18309) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
    2020-01-16 13:29:07.165  - error: host.zeus instance system.adapter.admin.0 terminated with code 156 (156)
    2020-01-16 13:29:07.166  - info: host.zeus Restart adapter system.adapter.admin.0 because enabled
    Ich habe mich an die node Upgradeanleitung aus dem Forum gehalten und bereits alles mögliche versucht, bis hin zur Neuinstallation von iobroker (mit Altdatenübernahme iobroker-data), jedoch bekomme ich es nicht gelöst.
    • PrRuP Offline
      PrRuP Offline
      PrRu
      Do not use pattern '*' on field 'Mask to publish own states'. It causes an error
