Adapter mihome-vacuum anpassungen
Du sollst es ja auch nicht installieren sondern aktuell halten. Den Rest von der Kiste dann auch...
Aktuell wärenodejs -v v22.23.2 -
node -v
root@iobroker:/opt/iobroker# node -v
v22.22.0Ich probiere mal ein update durchzuführen, das alles aktuell ist
UND HAMPEL NICHT ALS ROOT HERUM!!!!!!!!!
Geht bei mir auch nicht.
NPM version: 10.9.8 Installing xXBJXx/ioBroker.mihome-vacuum#fix/xiaomi-cloud-qr-login... (System call) npm error code 2 npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/opt/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > canvas@3.2.3 installnpm error > prebuild-install -r napi || node-gyp rebuildnpm errornpm errornpm error > diskusage@1.2.0 installnpm error > node-gyp rebuild npm errornpm errornpm error make: Entering directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build'npm error CXX(target) Release/obj.target/diskusage/src/main.onpm error CXX(target) Release/obj.target/diskusage/src/diskusage_posix.onpm error SOLINK_MODULE(target) Release/obj.target/diskusage.nodenpm error COPY Release/diskusage.nodenpm error make: Leaving directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build'npm errornpm error > unix-dgram@2.0.6 installnpm error > node-gyp rebuildnpm errornpm errornpm error make: Entering directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build'npm error CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.onpm error SOLINK_MODULE(target) Release/obj.target/unix_dgram.nodenpm error COPY Release/unix_dgram.nodenpm error make: Leaving directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build'npm errornpm error > esbuild@0.11.23 postinstallnpm error > node install.jsnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 preparenpm error > npm run buildnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 buildnpm error > npm run build:backend && npm run build:adminnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 build:backendnpm error > tsc -p tsconfig.build.jsonnpm errornpm error ../../../../node_modules/@types/cacheable-request/index.d.ts(26,42): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(77,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(81,69): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(84,71): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(89,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(95,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(104,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(108,70): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(112,73): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(115,76): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(118,60): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error npm warn using --force Recommended protections disabled.npm error npm warn deprecated glob@10.5.0: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.menpm error npm warn deprecated cronstrue@2.61.0: Non-backwards compatible Breaking changesnpm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.5.0npm error gyp info using node@22.23.2 | linux | x64npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.cache/node-gyp/22.23.2/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/22.23.2',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/22.23.2/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm error <command-line>: note: this is the location of the previous definitionnpm error In file included from ../../nan/nan.h:67,npm error from ../src/main.cpp:3:npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1243:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm error 1243 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1277:3: note: in expansion of macro ‘NODE_MODULE_X’npm error 1277 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’npm error 42 | NODE_MODULE(diskusage, Init)npm error | ^~~~~~~~~~~npm error <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm error <command-line>: note: this is the location of the previous definitionnpm error gyp info ok npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.5.0npm error gyp info using node@22.23.2 | linux | x64npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.cache/node-gyp/22.23.2/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/22.23.2',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/22.23.2/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error In file included from ../../nan/nan.h:67,npm error from ../src/unix_dgram.cc:5:npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1243:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm error 1243 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1277:3: note: in expansion of macro ‘NODE_MODULE_X’npm error 1277 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’npm error 404 | NODE_MODULE(unix_dgram, Initialize)npm error | ^~~~~~~~~~~npm error gyp info ok npm error npm warn using --force Recommended protections disabled.npm error npm warn using --force Recommended protections disabled.npm error npm error code 2npm error npm error path /opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OHnpm error npm error command failednpm error npm error command sh -c npm run buildnpm error npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-08-17T17_59_47_830Z-debug-0.log npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-08-17T17_59_39_609Z-debug-0.log npm error code 2npm error git dep preparation failednpm error command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/opt/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-runnpm error > canvas@3.2.3 installnpm error > prebuild-install -r napi || node-gyp rebuildnpm errornpm errornpm error > diskusage@1.2.0 installnpm error > node-gyp rebuildnpm errornpm errornpm error make: Entering directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build'npm error CXX(target) Release/obj.target/diskusage/src/main.onpm error CXX(target) Release/obj.target/diskusage/src/diskusage_posix.onpm error SOLINK_MODULE(target) Release/obj.target/diskusage.nodenpm error COPY Release/diskusage.nodenpm error make: Leaving directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build'npm errornpm error > unix-dgram@2.0.6 installnpm error > node-gyp rebuildnpm errornpm errornpm error make: Entering directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build'npm error CXX(target) Release/obj.target/unix_dgram/src/unix_dgram.onpm error SOLINK_MODULE(target) Release/obj.target/unix_dgram.nodenpm error COPY Release/unix_dgram.nodenpm error make: Leaving directory '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build'npm errornpm error > esbuild@0.11.23 postinstallnpm error > node install.jsnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 preparenpm error > npm run buildnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 buildnpm error > npm run build:backend && npm run build:adminnpm errornpm errornpm error > iobroker.mihome-vacuum@5.3.0 build:backendnpm error > tsc -p tsconfig.build.jsonnpm errornpm error ../../../../node_modules/@types/cacheable-request/index.d.ts(26,42): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(77,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(81,69): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(84,71): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(89,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(95,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(104,51): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(108,70): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(112,73): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(115,76): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error ../../../../node_modules/@types/cacheable-request/index.d.ts(118,60): error TS2709: Cannot use namespace 'ResponseLike' as a type.npm error npm warn using --force Recommended protections disabled.npm error npm warn deprecated glob@10.5.0: Old versions of glob are not supported, and contain widely publicized security vulnerabilities, which have been fixed in the current version. Please update. Support for old versions may be purchased (at exorbitant rates) by contacting i@izs.menpm error npm warn deprecated cronstrue@2.61.0: Non-backwards compatible Breaking changesnpm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.5.0npm error gyp info using node@22.23.2 | linux | x64npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.cache/node-gyp/22.23.2/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/22.23.2',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/22.23.2/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/diskusage',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm error <command-line>: note: this is the location of the previous definitionnpm error In file included from ../../nan/nan.h:67,npm error from ../src/main.cpp:3:npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1243:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm error 1243 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1277:3: note: in expansion of macro ‘NODE_MODULE_X’npm error 1277 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/main.cpp:42:1: note: in expansion of macro ‘NODE_MODULE’npm error 42 | NODE_MODULE(diskusage, Init)npm error | ^~~~~~~~~~~npm error <command-line>: warning: "_GLIBCXX_USE_CXX11_ABI" redefinednpm error <command-line>: note: this is the location of the previous definitionnpm error gyp info ok npm error gyp info it worked if it ends with oknpm error gyp info using node-gyp@11.5.0npm error gyp info using node@22.23.2 | linux | x64npm error gyp info find Python using Python version 3.11.2 found at "/usr/bin/python3"npm error gyp info spawn /usr/bin/python3npm error gyp info spawn args [npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',npm error gyp info spawn args 'binding.gyp',npm error gyp info spawn args '-f',npm error gyp info spawn args 'make',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram/build/config.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',npm error gyp info spawn args '-I',npm error gyp info spawn args '/opt/iobroker/.cache/node-gyp/22.23.2/include/node/common.gypi',npm error gyp info spawn args '-Dlibrary=shared_library',npm error gyp info spawn args '-Dvisibility=default',npm error gyp info spawn args '-Dnode_root_dir=/opt/iobroker/.cache/node-gyp/22.23.2',npm error gyp info spawn args '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',npm error gyp info spawn args '-Dnode_lib_file=/opt/iobroker/.cache/node-gyp/22.23.2/<(target_arch)/node.lib',npm error gyp info spawn args '-Dmodule_root_dir=/opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OH/node_modules/unix-dgram',npm error gyp info spawn args '-Dnode_engine=v8',npm error gyp info spawn args '--depth=.',npm error gyp info spawn args '--no-parallel',npm error gyp info spawn args '--generator-output',npm error gyp info spawn args 'build',npm error gyp info spawn args '-Goutput_dir=.'npm error gyp info spawn args ]npm error gyp info spawn makenpm error gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]npm error In file included from ../../nan/nan.h:67,npm error from ../src/unix_dgram.cc:5:npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1243:7: warning: cast between incompatible function types from ‘void (*)(v8::Local<v8::Object>)’ to ‘node::addon_register_func’ {aka ‘void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)’} [-Wcast-function-type]npm error 1243 | (node::addon_register_func) (regfunc), \npm error | ^~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~npm error /opt/iobroker/.cache/node-gyp/22.23.2/include/node/node.h:1277:3: note: in expansion of macro ‘NODE_MODULE_X’npm error 1277 | NODE_MODULE_X(modname, regfunc, NULL, 0) // NOLINT (readability/null_usage)npm error | ^~~~~~~~~~~~~npm error ../src/unix_dgram.cc:404:1: note: in expansion of macro ‘NODE_MODULE’npm error 404 | NODE_MODULE(unix_dgram, Initialize)npm error | ^~~~~~~~~~~npm error gyp info ok npm error npm warn using --force Recommended protections disabled.npm error npm warn using --force Recommended protections disabled.npm error npm error code 2npm error npm error path /opt/iobroker/.npm/_cacache/tmp/git-cloneYAP0OHnpm error npm error command failednpm error npm error command sh -c npm run buildnpm error npm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-08-17T17_59_47_830Z-debug-0.lognpm error A complete log of this run can be found in: /opt/iobroker/.npm/_logs/2026-08-17T17_59_39_609Z-debug-0.log host.6cf6d49071ea Cannot install xXBJXx/ioBroker.mihome-vacuum#fix/xiaomi-cloud-qr-login: 2 ERROR: Process exited with code 25 -
node ist nun v22.23.2, geht trotzdem nicht zu installieren. ich werde wohl eine neue docker image installieren müssen
Hier 'geht es'. Allerdings auf einem "richtigen" System.
thomas@testpi:~ $ iobroker url https://github.com/xXBJXx/ioBroker.mihome-vacuum/tree/fix/xiaomi-cloud-qr-login --host testpi --debug install xXBJXx/ioBroker.mihome-vacuum#fix/xiaomi-cloud-qr-login NPM version: 10.9.8 Installing xXBJXx/ioBroker.mihome-vacuum#fix/xiaomi-cloud-qr-login... (System call) npm warn deprecated prebuild-install@7.1.3: No longer maintained. Please contact the author of the relevant native addon; alternatives are available. > iobroker.mihome-vacuum@5.3.0 prepare > npm run build > iobroker.mihome-vacuum@5.3.0 build > npm run build:backend && npm run build:admin > iobroker.mihome-vacuum@5.3.0 build:backend > tsc -p tsconfig.build.json > iobroker.mihome-vacuum@5.3.0 build:admin > vite build --config src-admin/vite.config.ts vite v8.2.0 building client environment for production... transforming...✓ 11885 modules transformed. rendering chunks... computing gzip size... admin/index.html 0.41 kB │ gzip: 0.25 kB admin/assets/index.css 1.63 kB │ gzip: 0.73 kB admin/assets/index.js 927.28 kB │ gzip: 259.40 kB ✓ built in 3.48s [plugin builtin:vite-reporter] (!) Some chunks are larger than 900 kB after minification. Consider: - Using dynamic import() to code-split the application - Use build.rolldownOptions.output.codeSplitting to improve chunking: https://rolldown.rs/reference/OutputOptions.codeSplitting - Adjust chunk size limit for this warning via build.chunkSizeWarningLimit. > canvas@3.2.3 install > prebuild-install -r napi || node-gyp rebuild added 2 packages, and changed 16 packages in 3m 113 packages are looking for funding run `npm fund` for details upload [22] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/S5.png S5.png image/png upload [20] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/assets/index.js assets/index.js application/javascript upload [19] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/de/translations.json i18n/de/translations.json application/json upload [18] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/en/translations.json i18n/en/translations.json application/json upload [17] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/es/translations.json i18n/es/translations.json application/json upload [16] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/fr/translations.json i18n/fr/translations.json application/json upload [15] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/it/translations.json i18n/it/translations.json application/json upload [14] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/nl/translations.json i18n/nl/translations.json application/json upload [13] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pl/translations.json i18n/pl/translations.json application/json upload [12] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/pt/translations.json i18n/pt/translations.json application/json upload [11] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/ru/translations.json i18n/ru/translations.json application/json upload [10] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json upload [9] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index.html index.html text/html upload [8] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/index_m.html index_m.html text/html upload [7] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/mihome-vacuum.png mihome-vacuum.png image/png upload [6] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot.png robot.png image/png upload [5] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/robot1.png robot1.png image/png upload [4] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/spaceship.png spaceship.png image/png upload [3] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/tank.png tank.png image/png upload [2] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_conf.png valetudo_conf.png image/png upload [1] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/valetudo_logo_small.svg valetudo_logo_small.svg image/svg+xml upload [0] mihome-vacuum.admin /opt/iobroker/node_modules/iobroker.mihome-vacuum/admin/words.js words.js application/javascript Updating objects from io-package.json for adapter "mihome-vacuum" with version "5.3.0" thomas@testpi:~ $
