  4. Raspberry Pi 4 aktiven Lüfter steuern
    2.8k
    2.9k
raspberry pi 4lüftersteuerungkühlung
23 Beiträge 7 Kommentatoren 20.8k Aufrufe 7 Beobachtet
    R0bRakete
    Habs jetzt hinbekommen. Allerdings nicht mit iobroker, sondern über putty direkt in der bash mit einem Skript. Die Schaltung hab ich so gelassen wie sie war.
    Danke nochmals
    • H haiperf
      Hier noch mal ein simples Beispiel in node-red, lässt sich natürlich noch beliebig tunen und erweitern:
      [{"id":"c7158ecf.0f68e8","type":"tab","label":"Alexa","disabled":false,"info":""},{"id":"67a8eac.f8a9d94","type":"exec","z":"c7158ecf.0f68e8","command":"gpio mode 26 pwm","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"gpio mode 26 pwm","x":310,"y":60,"wires":[[],[],[]]},{"id":"94bd570c.1fd9a8","type":"inject","z":"c7158ecf.0f68e8","name":"","topic":"","payload":"Init","payloadType":"str","repeat":"","crontab":"","once":true,"onceDelay":0.1,"x":110,"y":60,"wires":[["67a8eac.f8a9d94"]]},{"id":"7e6cfa44.02931c","type":"inject","z":"c7158ecf.0f68e8","name":"Trigger 15s","topic":"","payload":"","payloadType":"date","repeat":"15","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":140,"wires":[["8d985057.29349"]]},{"id":"8d985057.29349","type":"ioBroker get","z":"c7158ecf.0f68e8","name":"SOC Temperature","topic":"rpi2.0.temperature.soc_temp","attrname":"payload","payloadType":"value","x":150,"y":200,"wires":[["8d2e7103.1c215","f4acf8b3.bb47a","3b8d0070.e0237"]]},{"id":"8d2e7103.1c215","type":"hysteresis","z":"c7158ecf.0f68e8","name":"","ThresholdType":"fixed","ThresholdRising":"42","ThresholdFalling":"38","TopicThreshold":"","TopicCurrent":"","ThresholdDeltaRising":"","ThresholdDeltaFalling":"","InitialMessage":false,"OutRisingType":"pay","OutRisingValue":"","OutFallingType":"pay","OutFallingValue":"","OutTopicType":"top","OutTopicValue":"","x":380,"y":140,"wires":[["ef7a5a42.234278"]]},{"id":"f4acf8b3.bb47a","type":"hysteresis","z":"c7158ecf.0f68e8","name":"","ThresholdType":"fixed","ThresholdRising":"47","ThresholdFalling":"42","TopicThreshold":"","TopicCurrent":"","ThresholdDeltaRising":"","ThresholdDeltaFalling":"","InitialMessage":false,"OutRisingType":"pay","OutRisingValue":"","OutFallingType":"pay","OutFallingValue":"","OutTopicType":"top","OutTopicValue":"","x":380,"y":200,"wires":[["fa2a280f.aef118"]]},{"id":"3b8d0070.e0237","type":"hysteresis","z":"c7158ecf.0f68e8","name":"","ThresholdType":"fixed","ThresholdRising":"53","ThresholdFalling":"47","TopicThreshold":"","TopicCurrent":"","ThresholdDeltaRising":"","ThresholdDeltaFalling":"","InitialMessage":false,"OutRisingType":"pay","OutRisingValue":"","OutFallingType":"pay","OutFallingValue":"","OutTopicType":"top","OutTopicValue":"","x":380,"y":260,"wires":[["2df765b6.1838a2"]]},{"id":"ef7a5a42.234278","type":"switch","z":"c7158ecf.0f68e8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"40","vt":"str"},{"t":"gte","v":"40","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":510,"y":140,"wires":[["3a715a7d.030ace"],["2f5be40b.a559dc"]]},{"id":"fa2a280f.aef118","type":"switch","z":"c7158ecf.0f68e8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"45","vt":"str"},{"t":"gte","v":"45","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":510,"y":200,"wires":[["2f5be40b.a559dc"],["38678327.732de4"]]},{"id":"2df765b6.1838a2","type":"switch","z":"c7158ecf.0f68e8","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"50","vt":"str"},{"t":"gte","v":"50","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":510,"y":260,"wires":[["38678327.732de4"],["fed32a3.d9981d8"]]},{"id":"3a715a7d.030ace","type":"exec","z":"c7158ecf.0f68e8","command":"gpio pwm 26 0","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"gpio pwm 26 0","x":680,"y":100,"wires":[[],[],[]]},{"id":"2f5be40b.a559dc","type":"exec","z":"c7158ecf.0f68e8","command":"gpio pwm 26 280","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"gpio pwm 26 280","x":690,"y":160,"wires":[[],[],[]]},{"id":"38678327.732de4","type":"exec","z":"c7158ecf.0f68e8","command":"gpio pwm 26 500","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"gpio pwm 26 500","x":690,"y":220,"wires":[[],[],[]]},{"id":"fed32a3.d9981d8","type":"exec","z":"c7158ecf.0f68e8","command":"gpio pwm 26 1023","addpay":false,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"gpio pwm 26 1023","x":690,"y":280,"wires":[[],[],[]]}]
      Flying-Bolt
      schrieb am zuletzt editiert von Flying-Bolt
      @haiperf Hi, die histeresis lässt sich nicht importieren!
      U 1 Antwort Letzte Antwort
      • F Flying-Bolt
        U Offline
        U Offline
        Uli
        @flying-bolt ich weiß das Thema ist schon sehr alt aber gibt es einen Adapter um die GPIOś des Raspi aus IObroker zu steuern. Ich möchte mein PV Überschuss Leistungsabhängig steuern. Über einen zusätzlichen ESP mit Tasmota funktioniert das. Leider ist das Ganze nicht fail save. Sobald die Kommunikation abbricht bleibt der ESP in der Einstellung hängen.
