  4. [Install] Synology DS412+ # add sql
    5.4k
1 Beiträge 1 Kommentatoren 774 Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    Da das Grundgerüst bereits auf der DS läuft, habe ich heute versucht den SQL-Adapter hinzu zu fügen
    Es kamen einige Fehlermeldungen im LOG:
    sql-0	28 11:51:25.664	info	Connected to sqlite
    sql-0	28 11:51:25.343	info	starting. Version 1.0.3 in /volume2/ioBroker/Master/node_modules/iobroker.sql
    iobroker	28 11:51:20.762	info	exit 0
    iobroker	28 11:51:20.727	info	host.DS object system.adapter.sql.0 created
    host-DS	28 11:51:20.723	info	instance system.adapter.sql.0 started with pid 11166
    host-DS	28 11:51:20.648	info	object change system.adapter.sql.0
    iobroker	28 11:51:20.613	info	host.DS object system.adapter.sql.0.alive created
    iobroker	28 11:51:20.580	info	host.DS object system.adapter.sql.0.connected created
    iobroker	28 11:51:20.538	info	host.DS object system.adapter.sql.0.memHeapUsed created
    iobroker	28 11:51:20.498	info	host.DS object system.adapter.sql.0.memHeapTotal created
    TypeError:	28 11:51:20.408	error	at TCP.onread (net.js:523:20)
    TypeError:	28 11:51:20.408	error	at Socket.Readable.push (_stream_readable.js:110:10)
    TypeError:	28 11:51:20.408	error	at readableAddChunk (_stream_readable.js:146:16)
    TypeError:	28 11:51:20.408	error	at Socket.emit (events.js:169:7)
    TypeError:	28 11:51:20.408	error	at emitOne (events.js:77:13)
    TypeError:	28 11:51:20.408	error	at Socket.realHandler (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:800:20)
    TypeError:	28 11:51:20.408	error	at Receiver.add (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:95:24)
    TypeError:	28 11:51:20.408	error	at Receiver.expectHandler (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:457:31)
    TypeError:	28 11:51:20.408	error	at Receiver.opcodes.1.finish (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:482:12)
    TypeError:	28 11:51:20.408	error	at Receiver.flush (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:340:3)
    TypeError:	28 11:51:20.408	error	at /volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:466:14
    TypeError:	28 11:51:20.408	error	at Receiver.applyExtensions (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:364:5)
    TypeError:	28 11:51:20.408	error	at /volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:477:18
    TypeError:	28 11:51:20.408	error	at Receiver.ontext (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:816:10)
    TypeError:	28 11:51:20.408	error	at WebSocket.emit (events.js:172:7)
    TypeError:	28 11:51:20.408	error	at emitTwo (events.js:87:13)
    TypeError:	28 11:51:20.408	error	at WebSocket.onMessage (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:418:14)
    TypeError:	28 11:51:20.408	error	at WebSocket.ws.onmessage (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:132:10)
    TypeError:	28 11:51:20.408	error	at WS.Transport.onData (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8)
    TypeError:	28 11:51:20.408	error	at WS.Transport.onPacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8)
    TypeError:	28 11:51:20.408	error	at WS.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	28 11:51:20.408	error	at WS. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10)
    TypeError:	28 11:51:20.408	error	at Socket.onPacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14)
    TypeError:	28 11:51:20.408	error	at Socket.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
    TypeError:	28 11:51:20.408	error	at Socket. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	28 11:51:20.408	error	at Manager.ondata (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16)
    TypeError:	28 11:51:20.408	error	at Decoder.add (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12)
    TypeError:	28 11:51:20.408	error	at Decoder.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    TypeError:	28 11:51:20.408	error	at Decoder. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	28 11:51:20.408	error	at Manager.ondecoded (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8)
    TypeError:	28 11:51:20.408	error	at Manager.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError:	28 11:51:20.408	error	at Manager. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    TypeError:	28 11:51:20.408	error	at Socket.onpacket (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12)
    TypeError:	28 11:51:20.408	error	at Socket.onevent (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10)
    TypeError:	28 11:51:20.408	error	at Socket.Emitter.emit (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20)
    TypeError:	28 11:51:20.408	error	at Socket. (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/lib/objects/objectsInMemClient.js:74:30)
    TypeError:	28 11:51:20.408	error	at Object.that.objects.Objects.change (/volume2/ioBroker/Master/node_modules/iobroker.js-controller/lib/adapter.js:382:77)
    TypeError:	28 11:51:20.408	error	at Object.utils.adapter.objectChange (/volume2/ioBroker/Master/node_modules/iobroker.javascript/javascript.js:94:44)
    TypeError:	28 11:51:20.408	error	Cannot read property 'name' of undefined
    message	28 11:51:20.309	error	_design/history [object Object] Cannot read property 'name' of undefined
    iobroker	28 11:51:20.448	info	host.DS object system.adapter.sql.0.memRss created
    iobroker	28 11:51:20.361	info	host.DS object system.adapter.sql.0.uptime created
    iobroker	28 11:51:20.346	info	host.DS create instance sql
    iobroker	28 11:51:20.224	info	host.DS object _design/history created
    iobroker	28 11:51:20.115	info	host.DS object system.adapter.sql created
    iobroker	28 11:51:19.578	info	upload [0] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/index.html index.html text/html
    iobroker	28 11:51:19.360	info	upload [1] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/sql.png sql.png image/png
    iobroker	28 11:51:19.008	info	upload [2] sql.admin /volume2/ioBroker/Master/node_modules/iobroker.sql/admin/storage.html storage.html text/html
    iobroker	28 11:51:18.953	info	got /volume2/ioBroker/Master/node_modules/iobroker.sql/admin
    iobroker	28 11:51:18.657	info	host.DS install adapter sql
    iobroker	28 11:50:04.835	info	npm install iobroker.sql --production --prefix "/volume2/ioBroker/Master" (System call)
    iobroker	28 11:50:03.331	info	add sql
    Später soll er die History in einer mySQL DB speichenrn.
    Gibt es Grund zur Sorge? (Aufgrund der Fehlermeldungen)
    Jürgen
