  4. Info Adapter crash loop
    6.0k
adapterneustartsinfo error
1 Beiträge 1 Kommentatoren 370 Aufrufe 3 Beobachtet
    MrBubbles
    Heute ist mir aufgefallen, das der Info Adpater im 30 Sekundentakt immer wieder neu gestartet wird um sofort wieder abzustürzen. Leider hilft mein Googel foo mit bei den Fehlermeldungen nicht weiter:
    host.iobroker	2019-10-13 16:47:10.760	info	Restart adapter system.adapter.info.0 because enabled
    host.iobroker	2019-10-13 16:47:10.760	error	instance system.adapter.info.0 terminated with code 0 (OK)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Array.forEach (<anonymous>)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
    Caught	2019-10-13 16:47:10.760	error	by controller[0]: TypeError: Cannot read property 'split' of undefined
    info.0	2019-10-13 16:47:10.754	info	cleaned everything up...
    info.0	2019-10-13 16:47:10.753	error	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    info.0	2019-10-13 16:47:10.753	error	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:236:12)
    info.0	2019-10-13 16:47:10.753	error	at Socket.onack (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:312:9)
    info.0	2019-10-13 16:47:10.753	error	at Socket.adapter.objects.getObjectView (/opt/iobroker/node_modules/iobroker.info/main.js:191:21)
    info.0	2019-10-13 16:47:10.753	error	at instances (/opt/iobroker/node_modules/iobroker.info/main.js:92:26)
    info.0	2019-10-13 16:47:10.753	error	at Array.forEach (<anonymous>)
    info.0	2019-10-13 16:47:10.753	error	at messages.forEach.message (/opt/iobroker/node_modules/iobroker.info/main.js:103:57)
    info.0	2019-10-13 16:47:10.753	error	at Object.keys.forEach.key (/opt/iobroker/node_modules/iobroker.info/main.js:124:49)
    info.0	2019-10-13 16:47:10.753	error	at checkVersion (/opt/iobroker/node_modules/iobroker.info/main.js:150:23)
    info.0	2019-10-13 16:47:10.753	error	TypeError: Cannot read property 'split' of undefined
    info.0	2019-10-13 16:47:10.753	error	uncaught exception: Cannot read property 'split' of undefined
    info.0	2019-10-13 16:47:10.727	info	Popup news was read...
    info.0	2019-10-13 16:47:09.951	info	starting. Version 1.4.3 in /opt/iobroker/node_modules/iobroker.info, node: v10.16.3
    host.iobroker	2019-10-13 16:47:09.505	info	instance system.adapter.info.0 started with pid 22590
    Kann es sein das er sich beim Lesen von Daten aus dem Internet verschluckt?
    Systemdata
    Hardwaresystem: Intel Core i5-2500
    Arbeitsspeicher: 4GB
    Festplattenart: SSD 32GB
    Betriebssystem: Debian 10
    Node-Version: 10.16.3
    Nodejs-Version: 10.16.3
    NPM-Version: 6.9.x
    Installationsart: Skript
    Image genutzt: Nein
    Ort/Name der Imagedatei: NN
