  2. English
  3. ioBroker general
  4. Aruidno LED discovery failed
    6.0k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
arduino iobroker discovery
6 Beiträge 2 Kommentatoren 773 Aufrufe 2 Beobachtet
  • باسل basselب Offline
    باسل bassel
    schrieb am zuletzt editiert von باسل bassel
    I have connected Arduino UNO to my PC through USB cable, but I wasn't able to discover it nor the LED built in it. I used serial option for that, the same way we use in Arduino IDE.
    I want to control the LED in order to learn how to use the ioBroker platform.
    I was able to run programs on arduino using the Arduino IDE so there is no problem in connectivity to my PC
    Could you please provide me with instructions of how to discover the device or the LED
    More info
    Machine: PC
    OS: Windows 10
    Browser: Chrome
    NodeJS: v10.15.0
    Thanks
    • باسل basselب باسل bassel
      More info
      Machine: PC
      OS: Windows 10
      Browser: Chrome
      NodeJS: v10.15.0
      Thanks
      Jey CeeJ Offline
      Jey CeeJ Offline
      Jey Cee
      @باسل-bassel can you give a bit more information how you have tried it?
      I am not sure if you want to write an adapter or only write scripts with the javascript adapter.
      These are two complete different ways.
      Persönlicher Support
      Spenden -> paypal.me/J3YC33
        باسل bassel
        @Jey-Cee When the dashboard is opened in the browser, I selected instances from the navigation bar, then clicked on discovery.0 option
        After that, I checked the Serial checkbox and clicked the DISCOVER button. The only result shown is web.0 instance. However; this result is shown even if my Arduino is not connected to my PC.
        Please look at the pictures below.
        Regarding your question, in Arduino IDE, I can write code to switch the Arduino builtin LED off or on.
        I wonder if I can do the same in ioBroker platform, maybe without writing a code, or if necessary, with code.
          Jey CeeJ Offline
          Jey CeeJ Offline
          Jey Cee
          @باسل-bassel ah you missed something, the discovery searches only for devices that are available with an adapter.
          You have to write your own code for communication with your Arduino.
          Short intro how you get there:
          1. Install Javascript Adapter
          2. Enter "serial" in the adapter config at "Add module"
          3. Create a new JS script and include the serial modul
            باسل bassel
            Thank you for the reply @Jey-Cee
            Is there some documentation or blog that explains how to do that?
            Moreover, is there a device that I can use without writing script or complex stuff?
            I have just installed the iobroker and don't know and how to learn or start as some parts of the docuemntation are missing.
            I wanna try the platform with simple device and simple stuff such as turn off and on the device.
              Jey CeeJ Offline
              Jey CeeJ Offline
              Jey Cee
              @باسل-bassel sagte in Aruidno LED discovery failed:
              Yes a lot, look at the Adapter section of the ioBroker Admin. Or you can use discovery to find your devices that can be used with ioBroker. Hint: discovery will not find all devices that can be controlled with ioBroker.
              If yout tell me what devices are you own, we will find one that is useable with iobroker. So we can go together step by step.
              Unfrotunately i dont know a english blog and our own documentation isnt that good.
