  4. Iobroker.js-controller version 0.9.0 js-controller starting
    5.4k
8 Beiträge 5 Kommentatoren 2.2k Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    2016-05-23 09:03:15.646  - info: iobroker upgrade self
    2016-05-23 09:03:17.122  - info: iobroker npm install iobroker.js-controller --production --prefix "/volume2/ioBroker/Master" (System call)
    2016-05-23 09:03:59.948  - info: iobroker npm
    2016-05-23 09:03:59.953  - info: iobroker  WARN deprecated jade@0.26.3: Jade has been renamed to pug, please install the latest version of pug instead of jade
    2016-05-23 09:04:04.167  - info: iobroker npm
    2016-05-23 09:04:04.168  - info: iobroker  WARN
    2016-05-23 09:04:04.170  - info: iobroker  deprecated
    2016-05-23 09:04:04.171  - info: iobroker  graceful-fs@2.0.3: graceful-fs v3.0.0 and before will fail on node releases >= v7.0\. Please update to graceful-fs@^4.0.0 as soon as possible. Use 'npm ls graceful-fs' to find it in the tree.
    2016-05-23 09:04:45.740  - info: iobroker Host "DS" (linux) updated
    2016-05-23 09:04:45.743  - info: iobroker Execute: chmod 777 -R /volume2/ioBroker/Master
    2016-05-23 09:04:45.913  - info: iobroker chmod: changing permissions of ‘/volume2/ioBroker/Master’
    2016-05-23 09:04:45.918  - info: iobroker : Operation not permitted
    2016-05-23 09:04:47.575  - info: iobroker chmod: changing permissions of ‘/volume2/ioBroker/Master/iobroker-data/files/vis.admin/Thumbs.db’: Operation not permitted
    2016-05-23 09:04:47.586  - info: iobroker chmod: changing permissions of ‘/volume2/ioBroker/Master/iobroker-data/files/vis.admin/@eaDir/Thumbs.db@SynoEAStream’
    2016-05-23 09:04:47.588  - info: iobroker : Operation not permitted
    2016-05-23 09:04:47.639  - info: iobroker Chmod finished. Restart controller
    2016-05-23 09:04:47.641  - info: iobroker Starting node restart.js
    2016-05-23 09:04:47.805  - info: iobroker exit 0
    2016-05-23 09:05:45.764  - info: iobroker _restart
    2016-05-23 09:05:46.582  - info: iobroker Starting node restart.js
    2016-05-23 09:05:46.603  - info: iobroker exit 0
    Der Button [restart] scheint nicht zu greifen. Der Controller wird nicht neu gestartet
    Auch nach "F5" im Browser ändert sich nichts
    Nun logge ich mich auf der Console ein und restarte ioBroker von Hand:
    admin@DS:/volume2/ioBroker/Master$ ./iobroker restart
    iobroker controller daemon is not running
    Starting iobroker controller daemon...
    iobroker controller daemon failed to start:  2
    Error: 2
    kommt zwar eine Fehlermeldung, Controller wird jedoch neu gestartet
    2016-05-23 09:10:06.010  - info: host.DS iobroker.js-controller version 0.9.0 js-controller starting
    2016-05-23 09:10:06.022  - info: host.DS Copyright (c) 2014-2016 bluefox, hobbyquaker
    2016-05-23 09:10:06.023  - info: host.DS hostname: DS
    2016-05-23 09:10:06.025  - info: host.DS ip addresses: 192.168.28.24 172.17.0.1 fe80::42:96ff:fe5d:fd92 fe80::1 10.28.60.1 fe80::98bd:2cff:fe46:b533
    2016-05-23 09:10:06.078  - info: inMem-states listening on port 9000
    2016-05-23 09:10:06.146  - info: inMem-objects listening on port 9001
    2016-05-23 09:10:06.158  - info: host.DS InMemoryDB connected
    2016-05-23 09:10:06.175  - info: host.DS 14 instances found
    2016-05-23 09:10:06.177  - info: host.DS starting 10 instances
    2016-05-23 09:10:09.783  - info: admin.0 starting. Version 1.1.1 in /volume2/ioBroker/Master/node_modules/iobroker.admin
    2016-05-23 09:10:09.865  - info: admin.0 requesting all states
    2016-05-23 09:10:09.869  - info: admin.0 requesting all objects
    2016-05-23 09:10:09.870  - info: admin.0 Request actual repository...
    2016-05-23 09:10:09.873  - info: admin.0 http server listening on port 8081
    2016-05-23 09:10:09.876  - info: admin.0 Use link "http://localhost:8081" to configure.
    2016-05-23 09:10:10.151  - info: admin.0 received all states
    2016-05-23 09:10:10.189  - info: host.DS instance system.adapter.web.0 started with pid 31115
    2016-05-23 09:10:10.242  - info: admin.0 received all objects
    2016-05-23 09:10:10.368  - info: host.DS Update repository "default" under "http://download.iobroker.net/sources-dist.json"
    2016-05-23 09:10:11.735  - info: admin.0 Repository received successfully.
    2016-05-23 09:10:12.361  - info: web.0 starting. Version 1.4.5 in /volume2/ioBroker/Master/node_modules/iobroker.web
    2016-05-23 09:10:13.127  - info: web.0 socket.io server listening on port 8082
    2016-05-23 09:10:13.133  - info: web.0 http server listening on port 8082
    2016-05-23 09:10:15.546  - info: vis.0 starting. Version 0.10.0 in /volume2/ioBroker/Master/node_modules/iobroker.vis
    2016-05-23 09:10:16.942  - info: host.DS instance system.adapter.vis.0 terminated while should be started once
    2016-05-23 09:10:18.201  - info: host.DS instance scheduled system.adapter.dwd.0 3 * * * *
    2016-05-23 09:10:18.211  - info: host.DS instance system.adapter.dwd.0 started with pid 31137
    2016-05-23 09:10:20.323  - info: dwd.0 starting. Version 2.0.3 in /volume2/ioBroker/Master/node_modules/iobroker.dwd
    2016-05-23 09:10:21.088  - info: host.DS instance system.adapter.dwd.0 terminated with code 0 (OK)
    2016-05-23 09:10:22.189  - info: host.DS instance system.adapter.javascript.0 started with pid 31147
    2016-05-23 09:10:24.466  - info: javascript.0 starting. Version 2.1.1 in /volume2/ioBroker/Master/node_modules/iobroker.javascript
    2016-05-23 09:10:24.489  - info: javascript.0 requesting all states
    2016-05-23 09:10:24.493  - info: javascript.0 requesting all objects
    2016-05-23 09:10:24.770  - info: javascript.0 received all states
    2016-05-23 09:10:24.878  - info: javascript.0 received all objects
    2016-05-23 09:10:30.190  - info: host.DS instance scheduled system.adapter.yr.0 6 * * * *
    2016-05-23 09:10:30.201  - info: host.DS instance system.adapter.yr.0 started with pid 31161
    2016-05-23 09:10:31.894  - info: yr.0 starting. Version 1.0.3 in /volume2/ioBroker/Master/node_modules/iobroker.yr
    2016-05-23 09:10:32.306  - info: yr.0 got weather data from yr.no
    2016-05-23 09:10:37.462  - info: host.DS instance system.adapter.yr.0 terminated with code 0 (OK)
    Jürgen
    • BluefoxB Offline
      BluefoxB Offline
      Was ist das?
      Windows oder OSX?
        Sieht aus wie Synology.
        > Thumbs.db@****Syno****EAStream’
        Rainer
        • derAugeD Offline
          derAugeD Offline
          derAuge
          @Bluefox:
          Was ist das?
          Windows oder OSX? `
          Das ist auf einer DS412+ Synology
          admin@DS:~$ uname -a
          Linux DS 3.10.77 #7321 SMP Thu Apr 21 14:34:36 CST 2016 x86_64 GNU/Linux synology_cedarview_412+
          admin@DS:~$ node -v
          v4.2.6
          admin@DS:~$ npm -v
          2.14.12
          admin@DS:~$
          Soll mein neues Produktiv-System werden
          Jürgen
          • BluefoxB Offline
            BluefoxB Offline
            Synology liegt hier /volume2/ioBroker/Master/iobroker-data/files/vis.admin/Thumbs.db die Daten ab, die nicht gelöscht werden können. Damit kommen beim Update die Warnings. Falls alles läuft, dann kann man die ignorieren.
            • F Offline
              Fugazzy
              Edit3: mit node 0.12.6 scheint es jetzt zu laufen
              Edit 2: Fehler ist wieder da
              Edit 1:
              Erledigt, es gab neue Updates (web?) und ein folgender Neustart, es läuft wieder
              ich habe gestern über die Kommandozeile meine Installation auf den aktuellen Stand gebracht, seit dem bekomme ich folgende Fehler:
              (raspi2, wheezy, node 0.10.22)
              2016-05-24 11:59:27.703  - info: javascript.0 received all states
              2016-05-24 11:59:45.285  - error: xhr poll error
              2016-05-24 11:59:45.295  - error: xhr poll error
              2016-05-24 11:59:45.398  - error: xhr poll error
              2016-05-24 11:59:45.127  - error: xhr poll error
              2016-05-24 11:59:45.179  - error: Error: xhr poll error
                  at XHR.Transport.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:62:13)
                  at Request. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:127:10)
                  at Request.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)
                  at Request.onError (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:296:8)
                  at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/polling-xhr.js:243:18)
                  at Timer.listOnTimeout [as ontimeout] (timers.js:110:15)
              2016-05-24 11:59:45.556  - error: xhr poll error
              2016-05-24 11:59:45.354  - error: Error: xhr poll error
                  at Request.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20)</anonymous></anonymous>
              • N Offline
                N Offline
                nobse
                Hallo zusammen
                ich habe auf die 0.9.0 das Update gemacht. Danach kann ich den Editor nicht mehr starten. Beim Start bleibt der Ladebalken dann einfach stehen.
                Im Log sind folgende Fehlermeldungen
                host-server	25 20:48:33.390	warn	warning: Timeout by read all package.json (87) seconds
                ping-0	25 20:48:16.606	info	starting. Version 1.1.1 in C:/ioBroker/node_modules/iobroker.ping
                host-server	25 20:48:15.873	info	instance system.adapter.ping.0 started with pid 8076
                host-server	25 20:47:37.161	info	instance system.adapter.vis.0 terminated while should be started once
                ReferenceError:	25 20:47:36.630	error	at Manager. (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\node_modules\component-bind\index.js:21:15)
                ReferenceError:	25 20:47:36.630	error	at Socket.onpacket (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:229:12)
                ReferenceError:	25 20:47:36.630	error	at Socket.onack (C:\ioBroker\node_modules\iobroker.js-controller\node_modules\socket.io-client\lib\socket.js:305:9)
                ReferenceError:	25 20:47:36.630	error	at Socket. (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:330:29)
                ReferenceError:	25 20:47:36.630	error	at initAdapter (C:\ioBroker\node_modules\iobroker.js-controller\lib\adapter.js:2866:14)
                ReferenceError:	25 20:47:36.630	error	at Adapter.emit (events.js:166:7)
                ReferenceError:	25 20:47:36.630	error	at emitNone (events.js:67:13)
                ReferenceError:	25 20:47:36.630	error	at Adapter. (C:\ioBroker\node_modules\iobroker.vis\main.js:21:5)
                ReferenceError:	25 20:47:36.630	error	at main (C:\ioBroker\node_modules\iobroker.vis\main.js:121:19)
                ReferenceError:	25 20:47:36.630	error	at syncWidgetSets (C:\ioBroker\node_modules\iobroker.vis\lib\install.js:98:17)
                ReferenceError:	25 20:47:36.630	error	adapter is not defined
                uncaught	25 20:47:36.630	error	exception: adapter is not defined
                vis-0	25 20:47:36.614	info	starting. Version 0.10.1 in C:/ioBroker/node_modules/iobroker.vis
                node-red-0	25 20:47:36.552	warn
                node-red-0	25 20:47:36.552	warn	25 May 20:47:36 - [warn] ------------------------------------------
                node-red-0	25 20:47:36.552	warn	25 May 20:47:36 - [warn] [serialport] Error: Module did not self-register.
                node-red-0	25 20:47:36.552	warn	25 May 20:47:36 - [warn] [tail] Not currently supported on Windows.
                node-red-0	25 20:47:36.552	warn	25 May 20:47:36 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
                Das ganze läuft schon mehrere Monate auf einem Windows Server 2012 R2 ohne Üprobleme.
                Hat jemand einen Rat für mich.
                Gruß Norbert
                CCU2 • Raspberry für Wetterstation • CMS http://www.exv2.de • HP ProLiant MicroServer Gen8 12GB RAM, 2x3TB, Windows Essentials Server 2016 mit ioBroker
                • BluefoxB Offline
                  BluefoxB Offline
                  @nobse:
                  Hallo zusammen
                  Hat jemand einen Rat für mich. `
                  http://forum.iobroker.net/viewtopic.php … 895#p26231
