  4. require("request") ergibt EHOSTUNREACH
    5.7k
javascriptcommunication
3 Beiträge 2 Kommentatoren 742 Aufrufe 2 Beobachtet
  • etvE Offline
    etvE Offline
    etv
    Liebe Leute,
    mir ist heute im Log aufgefallen, dass dieser Fehler den Restart des Adapters auslöst...
    2019-09-17 12:26:15.764 - error: Caught by controller[0]: { Error: connect EHOSTUNREACH 192.168.68.220:50000
    2019-09-17 12:26:15.774 - error: Caught by controller[0]: at Object.exports._errnoException (util.js:1020:11)
    2019-09-17 12:26:15.775 - error: Caught by controller[0]: at exports._exceptionWithHostPort (util.js:1043:20)
    2019-09-17 12:26:15.775 - error: Caught by controller[0]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1090:14)
    2019-09-17 12:26:15.775 - error: Caught by controller[0]: code: 'EHOSTUNREACH',
    2019-09-17 12:26:15.776 - error: Caught by controller[0]: errno: 'EHOSTUNREACH',
    2019-09-17 12:26:15.776 - error: Caught by controller[0]: syscall: 'connect',
    2019-09-17 12:26:15.776 - error: Caught by controller[0]: address: '192.168.68.220',
    2019-09-17 12:26:15.776 - error: Caught by controller[0]: port: 50000 }
    2019-09-17 12:26:15.776 - error: Caught by controller[1]: { Error: connect EHOSTUNREACH 192.168.68.220:50000
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: at Object.exports._errnoException (util.js:1020:11)
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: at exports._exceptionWithHostPort (util.js:1043:20)
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1090:14)
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: code: 'EHOSTUNREACH',
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: errno: 'EHOSTUNREACH',
    2019-09-17 12:26:15.777 - error: Caught by controller[1]: syscall: 'connect',
    2019-09-17 12:26:15.778 - error: Caught by controller[1]: address: '192.168.68.220',
    2019-09-17 12:26:15.778 - error: Caught by controller[1]: port: 50000 }
    2019-09-17 12:26:15.778 - error: Caught by controller[2]: { Error: socket hang up
    2019-09-17 12:26:15.778 - error: Caught by controller[2]: at createHangUpError (_http_client.js:254:15)
    2019-09-17 12:26:15.778 - error: Caught by controller[2]: at Socket.socketCloseListener (_http_client.js:286:23)
    2019-09-17 12:26:15.778 - error: Caught by controller[2]: at emitOne (events.js:101:20)
    2019-09-17 12:26:15.779 - error: Caught by controller[2]: at Socket.emit (events.js:188:7)
    2019-09-17 12:26:15.779 - error: Caught by controller[2]: at TCP._handle.close [as _onclose] (net.js:497:12)
    2019-09-17 12:26:15.779 - error: Caught by controller[2]: code: 'ECONNRESET' }
    2019-09-17 12:26:15.779 - error: Caught by controller[3]: { Error: socket hang up
    2019-09-17 12:26:15.779 - error: Caught by controller[3]: at createHangUpError (_http_client.js:254:15)
    2019-09-17 12:26:15.780 - error: Caught by controller[3]: at Socket.socketCloseListener (_http_client.js:286:23)
    2019-09-17 12:26:15.780 - error: Caught by controller[3]: at emitOne (events.js:101:20)
    2019-09-17 12:26:15.780 - error: Caught by controller[3]: at Socket.emit (events.js:188:7)
    2019-09-17 12:26:15.780 - error: Caught by controller[3]: at TCP._handle.close [as _onclose] (net.js:497:12)
    2019-09-17 12:26:15.780 - error: Caught by controller[3]: code: 'ECONNRESET' }
    2019-09-17 12:26:15.780 - error: host.etv-nas-1 instance system.adapter.javascript.0 terminated with code 0 (OK)
    2019-09-17 12:26:15.781 - info: host.etv-nas-1 Restart adapter system.adapter.javascript.0 because enabled
    Wie kann man das verhindern?
    Liebe Grüße
    Tom
    …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
    U 1 Antwort Letzte Antwort
    • etvE etv
      Liebe Leute,
      Liebe Grüße
      Tom
      U Offline
      U Offline
      uschi08
      @etv
      Hi.
      hattest du es noch rausbekommen? Hat das was mit dem Netzwerk zuntun?
      Habe nämlich das gleiche Phänomen und glaube auch das nicht mehr alles sauer übertragen wird.
      Grüße
      Ole
      etvE 1 Antwort Letzte Antwort
      • U uschi08
        @etv
        Hi.
        Grüße
        Ole
        etvE Offline
        etvE Offline
        etv
        Servus @uschi08 ,
        leider bis jetzt noch nicht! Ich hab nun mal genauer geschaut und eine Adresse ausgemacht, die eigentlich immer da zu sein scheint - ist aber nix bei uns im Haus und soll angeblich ein Samsung Gerät sein.
        Das hab ich als zu überwachendes Gerät angelegt und lasse mitloggen, ob es irgendwann auch weg ist.....
        Sonst hab ich nun auch den restart des Adapters um 0:05 Uhr eingestellt, damit es wenigstens nicht eine endlose Loste wird, sondern jeden Tag auf's Neue erstellt wird....ist aber leider rein kosmetisch.
        Das Spannende ist, dass diese Einträge eigentlich alle nur eine MAC Adresse haben, aber keinen Bluetooth Namen oder Vendor eingetragen haben....
        Liebe Grüße
        Tom
