  4. [erledigt] Adapter startet obwohl deaktiviert (adapter.weatherunderground.0)
3 Beiträge 2 Kommentatoren 768 Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    Habe adapter.weatherunderground.0 installiert
    Nach der Installation ist er sofort aktiv. (ist das so gewollt?)
    Habe den Adapter dann deaktiviert. Trotzdem wird versucht ihn zu starten
    2016-05-03 15:00:00.703  - info: host.RPi3-1 instance system.adapter.weatherunderground.0 started with pid 26288
    2016-05-03 15:00:04.299  - error: adapter disabled
    2016-05-03 15:00:05.364  - error: host.RPi3-1 instance system.adapter.weatherunderground.0 terminated with code 3 (Adapter disabled or invalid config)
    2016-05-03 15:45:00.699  - info: host.RPi3-1 instance system.adapter.weatherunderground.0 started with pid 28472
    2016-05-03 15:45:04.636  - error: adapter disabled
    2016-05-03 15:45:05.719  - error: host.RPi3-1 instance system.adapter.weatherunderground.0 terminated with code 3 (Adapter disabled or invalid config)
    Jürgen
    • derAugeD Offline
      derAugeD Offline
      derAuge
      heute wollte ich das Update auf 0.0.5 durchführen
      Adapter war nicht aktiv
      im LOG kam Fehlermeldung.
      iobroker	2016-05-04 08:10:48	info	npm ERR! syscall rename
      iobroker	2016-05-04 08:10:48	info	code ENOENTnpm ERR! errno -2
      iobroker	2016-05-04 08:10:49	info	exit 25
      iobroker	2016-05-04 08:10:49	info	Cannot install iobroker.weatherunderground: 254
      iobroker	2016-05-04 08:10:49	info	npm ERR! /npm-debug.log
      iobroker	2016-05-04 08:10:49	info	npm ERR! Please include the following file with any support request:
      iobroker	2016-05-04 08:10:48	info	npm ERR! enoent
      iobroker	2016-05-04 08:10:48	info	ERR! enoent This is most likely not a problem with npm itselfnpm ERR! enoent and is related to npm not being able to find a file.
      iobroker	2016-05-04 08:10:48	info	ERR! enoent ENOENT: no such file or directory, rename '/opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.staging/iobroker.weatherunderground-99ce02da' -> '/opt/iobroker/node_modul
      iobroker	2016-05-04 08:10:48	info	npm ERR! path /opt/iobroker/node_modules/iobroker.weatherunderground/node_modules/.staging/iobroker.weatherunderground-99ce02da
      iobroker	2016-05-04 08:10:48	info	npm ERR! node v4.4.3npm ERR! npm v3.8.8
      iobroker	2016-05-04 08:10:48	info	"/usr/bin/nodejs" "/usr/bin/npm" "install" "--production" "--prefix" "/opt/iobroker/node_modules/iobroker.weatherunderground"
      iobroker	2016-05-04 08:10:48	info	npm ERR! argv
      iobroker	2016-05-04 08:10:48	info	npm ERR! Linux 4.1.19-v7+
      iobroker	2016-05-04 08:09:48	info	npm WARN iobroker No README datanpm WARN iobroker No license field.
      iobroker	2016-05-04 08:09:49	info	npm install --production --prefix "/opt/iobroker/node_modules/iobroker.weatherunderground" (System call)
      iobroker	2016-05-04 08:09:48	info	npm WARN iobroker No repository field.
      iobroker	2016-05-04 08:09:48	info	WARN enoent ENOENT: no such file or directory, open '/opt/iobroker/package.json'npm WARN iobroker No description
      iobroker	2016-05-04 08:06:56	info	npm install iobroker.weatherunderground --production --prefix "/opt/iobroker" (System call)
      iobroker	2016-05-04 08:06:53	info	upgrade weatherunderground
      Beim zweiten versuch ist der Adapter gelöscht
      iobroker	2016-05-04 09:47:58	info	exit 0
      iobroker	2016-05-04 09:47:58	info	Adapter "weatherunderground" is not installed.
      iobroker	2016-05-04 09:47:55	info	upgrade weatherunderground
      Jürgen
      • BluefoxB Offline
        BluefoxB Offline
        @derAuge:
        Jürgen `
        Danke fürs Fehlermeldung. Problem gefunden.
        Mit dem Update kann ich nicht reproduzieren.
        82.9k
