  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер KODI
    5.3k
Драйвер KODI
41 Beiträge 7 Kommentatoren 11.6k Aufrufe
  • Alex1808A Offline
    Alex1808A Offline
    Alex1808
    #41
    Последнее обновление ставится с ошибками в логе
    2017-01-08 10:48:27.191 - [32minfo[39m: iobroker del kodi.0 2017-01-08 10:48:27.967 - [32minfo[39m: iobroker host.iobroker Counted 1 instances of kodi.0 2017-01-08 10:48:27.976 - [32minfo[39m: iobroker host.iobroker Counted 6 states "system.adapter.kodi.0*" from states 2017-01-08 10:48:28.718 - [32minfo[39m: iobroker host.iobroker Counted 71 states "io.kodi.0*" from states 2017-01-08 10:48:28.734 - [32minfo[39m: iobroker host.iobroker Counted 71 states "kodi.0*" from states 2017-01-08 10:48:29.222 - [32minfo[39m: iobroker host.iobroker Counted 104 objects of kodi.0 2017-01-08 10:48:29.459 - [32minfo[39m: iobroker host.iobroker Counted 103 objects of states of kodi.0 2017-01-08 10:48:29.465 - [32minfo[39m: iobroker host.iobroker Deleting 104 object(s). 2017-01-08 10:48:31.125 - [32minfo[39m: host.iobroker object change system.adapter.kodi.0 2017-01-08 10:48:31.127 - [32minfo[39m: host.iobroker object deleted system.adapter.kodi.0 2017-01-08 10:48:32.452 - [32minfo[39m: iobroker exit 0 2017-01-08 10:48:44.537 - [32minfo[39m: iobroker del kodi 2017-01-08 10:48:45.203 - [32minfo[39m: iobroker host.iobroker delete /opt/iobroker/node_modules/iobroker.kodi 2017-01-08 10:48:45.844 - [32minfo[39m: iobroker host.iobroker no instances of adapter kodi found 2017-01-08 10:48:45.884 - [32minfo[39m: iobroker host.iobroker Counted 1 adapters for kodihost.iobroker Counted 1 states (system.adapter.kodi.*) from states ! 2017-01-08 10:48:46.066 - [32minfo[39m: iobroker host.iobroker Counted 1 states of kodi 2017-01-08 10:48:46.076 - [32minfo[39m: iobroker host.iobroker Deleting 2 object(s). 2017-01-08 10:48:46.164 - [31merror[39m: iobroker Not exists 2017-01-08 10:48:46.252 - [32minfo[39m: iobroker exit 0 2017-01-08 10:48:46.840 - [31merror[39m: Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi/_data.json' 2017-01-08 10:48:46.841 - [31merror[39m: Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/_data.json' 2017-01-08 10:48:55.540 - [32minfo[39m: iobroker add kodi 2017-01-08 10:48:56.529 - [32minfo[39m: iobroker npm install iobroker.kodi --production --prefix "/opt/iobroker" (System call) 2017-01-08 10:49:00.250 - [32minfo[39m: iobroker npm 2017-01-08 10:49:00.259 - [32minfo[39m: iobroker 2017-01-08 10:49:00.280 - [32minfo[39m: iobroker WARN peerDependencies The peer dependency eslint@<2.3.0 included from babel-eslint will nonpm WARN peerDependencies longer be automatically installed to fulfill the peerDependency npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly. ! 2017-01-08 10:49:11.658 - [32minfo[39m: iobroker In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’ NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) { ^ ! 2017-01-08 10:49:11.684 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) { ^ ! 2017-01-08 10:49:11.831 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:11.845 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’ , node::smalloc::FreeCallback callback ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(char*, size_t, int)’: ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(const char*, uint32_t)’: ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous return node::Buffer::New(v8::Isolate::GetCurrent(), data, size); ^ ../node_modules/nan/nan.h:672:67: note: candidates are: In file included from ../src/validation.cc:10:0: /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, v8::Local<v8::string>, node::encoding) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, char*, size_t) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’ In file included from ../src/validation.cc:15:0: ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(uint32_t)’: ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::object>’ to ‘v8::Local<v8::object>’ return node::Buffer::New(v8::Isolate::GetCurrent(), size); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanBufferUse(char*, uint32_t)’: ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’ return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:12.281 - [32minfo[39m: iobroker make: *** [Release/obj.target/validation/src/validation.o] Error 1gyp 2017-01-08 10:49:12.299 - [32minfo[39m: iobroker ERR! build error gyp 2017-01-08 10:49:12.346 - [32minfo[39m: iobroker ERR! stack Error: makefailed with exit code: 2 2017-01-08 10:49:12.407 - [32minfo[39m: iobroker gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12) gyp 2017-01-08 10:49:12.415 - [32minfo[39m: iobroker ERR! System Linux 3.16.0-4-amd64gyp 2017-01-08 10:49:12.421 - [32minfo[39m: iobroker ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp 2017-01-08 10:49:12.429 - [32minfo[39m: iobroker ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validategyp ERR! node -v v4.7.2 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok 2017-01-08 10:49:12.442 - [32minfo[39m: iobroker 2017-01-08 10:49:17.395 - [32minfo[39m: iobroker In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’ NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) { ^ ! 2017-01-08 10:49:17.413 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) { ^ ! 2017-01-08 10:49:17.469 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:17.474 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’ , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:17.478 - [32minfo[39m: iobroker ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ! 2017-01-08 10:49:17.484 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(const char*, uint32_t)’: ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous return node::Buffer::New(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:17.486 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:672:67: note: candidates are:In file included from ../src/bufferutil.cc:10:0: /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, v8::Local<v8::string>, node::encoding) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ ! 2017-01-08 10:49:17.489 - [32minfo[39m: iobroker /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’/root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, char*, size_t) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’ In file included from ../src/bufferutil.cc:16:0: ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(uint32_t)’: ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::object>’ to ‘v8::Local<v8::object>’ return node::Buffer::New(v8::Isolate::GetCurrent(), size); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanBufferUse(char*, uint32_t)’: ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’ return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:17.751 - [32minfo[39m: iobroker make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1 2017-01-08 10:49:17.777 - [32minfo[39m: iobroker gyp ERR! build error 2017-01-08 10:49:17.795 - [32minfo[39m: iobroker gyp 2017-01-08 10:49:17.799 - [32minfo[39m: iobroker 2017-01-08 10:49:17.806 - [32minfo[39m: iobroker ERR! stack Error:make failed with exit code: 2gyp 2017-01-08 10:49:17.818 - [32minfo[39m: iobroker ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) 2017-01-08 10:49:17.821 - [32minfo[39m: iobroker gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12) gyp ERR! System Linux 3.16.0-4-amd64 gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil gyp 2017-01-08 10:49:17.835 - [32minfo[39m: iobroker ERR! 2017-01-08 10:49:17.854 - [32minfo[39m: iobroker node -v v4.7.2gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok ! 2017-01-08 10:49:17.871 - [32minfo[39m: iobroker npm 2017-01-08 10:49:17.875 - [32minfo[39m: iobroker WARN optional dep failed, continuing 2017-01-08 10:49:17.880 - [32minfo[39m: iobroker utf-8-validate@1.1.0 2017-01-08 10:49:17.884 - [32minfo[39m: iobroker npm WARN 2017-01-08 10:49:17.886 - [32minfo[39m: iobroker optional dep failed, continuing bufferutil@1.1.0 2017-01-08 10:49:42.906 - [32minfo[39m: iobroker host.iobroker install adapter kodi 2017-01-08 10:49:42.965 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.kodi/admin 2017-01-08 10:49:42.998 - [32minfo[39m: iobroker upload [3] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/web.jpg web.jpg image/jpeg 2017-01-08 10:49:43.131 - [32minfo[39m: iobroker upload [2] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/remote.jpg remote.jpg image/jpeg 2017-01-08 10:49:43.361 - [32minfo[39m: iobroker upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png 2017-01-08 10:49:43.431 - [32minfo[39m: iobroker upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html 2017-01-08 10:49:43.713 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:43.716 - [32minfo[39m: host.iobroker "system.adapter.vis.0" disabled 2017-01-08 10:49:43.770 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:43.770 - [32minfo[39m: host.iobroker "system.adapter.vis.0" enabled 2017-01-08 10:49:43.891 - [32minfo[39m: iobroker Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.kodi/www ! 2017-01-08 10:49:43.924 - [32minfo[39m: iobroker upload [2] kodi /opt/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png 2017-01-08 10:49:44.038 - [32minfo[39m: iobroker upload [1] kodi /opt/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html 2017-01-08 10:49:44.115 - [32minfo[39m: iobroker upload [0] kodi /opt/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown 2017-01-08 10:49:44.298 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi created 2017-01-08 10:49:44.402 - [32minfo[39m: iobroker host.iobroker create instance kodi 2017-01-08 10:49:44.519 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.subtitle_language created 2017-01-08 10:49:44.570 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_width created 2017-01-08 10:49:44.737 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_stereomode created 2017-01-08 10:49:44.811 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_height created 2017-01-08 10:49:44.877 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_duration created 2017-01-08 10:49:44.928 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_codec created 2017-01-08 10:49:44.975 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_aspect created 2017-01-08 10:49:45.035 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_language created 2017-01-08 10:49:45.090 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_codec created 2017-01-08 10:49:45.145 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_channels created 2017-01-08 10:49:45.214 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.tagline created 2017-01-08 10:49:45.275 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video created 2017-01-08 10:49:45.397 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.subtitle created 2017-01-08 10:49:45.435 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio created 2017-01-08 10:49:45.493 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.showtitle created 2017-01-08 10:49:45.553 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.season created 2017-01-08 10:49:45.673 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.plot created 2017-01-08 10:49:45.722 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.originaltitle created 2017-01-08 10:49:45.769 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.imdbnumber created 2017-01-08 10:49:45.827 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.episode created 2017-01-08 10:49:45.877 - [32minfo[39m: iobroker host.iobroker object kodi.0.pause created 2017-01-08 10:49:45.944 - [32minfo[39m: iobroker host.iobroker object kodi.0.play created 2017-01-08 10:49:46.015 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.albumartist created 2017-01-08 10:49:46.170 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.id created 2017-01-08 10:49:46.303 - [32minfo[39m: iobroker host.iobroker object kodi.0.audiostream created 2017-01-08 10:49:46.367 - [32minfo[39m: iobroker host.iobroker object kodi.0.language created 2017-01-08 10:49:46.441 - [32minfo[39m: iobroker host.iobroker object kodi.0.channels created 2017-01-08 10:49:46.493 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.kernel created 2017-01-08 10:49:46.538 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.system created 2017-01-08 10:49:46.590 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.version created 2017-01-08 10:49:46.708 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.name created 2017-01-08 10:49:46.782 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlist created 2017-01-08 10:49:46.830 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.year created 2017-01-08 10:49:46.901 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.type created 2017-01-08 10:49:46.966 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.track created 2017-01-08 10:49:47.036 - [32minfo[39m: iobroker host.iobroker object kodi.0.clear created 2017-01-08 10:49:47.108 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.title created 2017-01-08 10:49:47.182 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.thumbnail created 2017-01-08 10:49:47.237 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.rating created 2017-01-08 10:49:47.298 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.playcount created 2017-01-08 10:49:47.356 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.label created 2017-01-08 10:49:47.402 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.genre created 2017-01-08 10:49:47.464 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.file created 2017-01-08 10:49:47.525 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.fanart created 2017-01-08 10:49:47.597 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.artist created 2017-01-08 10:49:47.699 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.album created 2017-01-08 10:49:47.749 - [32minfo[39m: iobroker host.iobroker object kodi.0.type created 2017-01-08 10:49:47.820 - [32minfo[39m: iobroker host.iobroker object kodi.0.bitrate created 2017-01-08 10:49:47.891 - [32minfo[39m: iobroker host.iobroker object kodi.0.samplerate created 2017-01-08 10:49:47.931 - [32minfo[39m: iobroker host.iobroker object kodi.0.codec created 2017-01-08 10:49:45.862 - [32minfo[39m: vis.0 starting. Version 0.12.3 in /opt/iobroker/node_modules/iobroker.vis, node: v4.7.2 2017-01-08 10:49:48.393 - [32minfo[39m: iobroker host.iobroker object kodi.0.partymode created 2017-01-08 10:49:48.451 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlistid created 2017-01-08 10:49:48.497 - [32minfo[39m: iobroker host.iobroker object kodi.0.position created 2017-01-08 10:49:48.543 - [32minfo[39m: iobroker host.iobroker object kodi.0.speed created 2017-01-08 10:49:48.595 - [32minfo[39m: iobroker host.iobroker object kodi.0.shuffle created 2017-01-08 10:49:48.834 - [32minfo[39m: iobroker host.iobroker object kodi.0.repeat created 2017-01-08 10:49:48.872 - [32minfo[39m: iobroker host.iobroker object kodi.0.canseek created 2017-01-08 10:49:48.912 - [32minfo[39m: iobroker host.iobroker object kodi.0.playing_time_total created 2017-01-08 10:49:48.988 - [32minfo[39m: iobroker host.iobroker object kodi.0.playing_time created 2017-01-08 10:49:49.055 - [32minfo[39m: iobroker host.iobroker object kodi.0.pvr.playlist_radio created 2017-01-08 10:49:49.112 - [32minfo[39m: iobroker host.iobroker object kodi.0.pvr.playlist_tv created 2017-01-08 10:49:49.170 - [32minfo[39m: iobroker host.iobroker object kodi.0.volume created 2017-01-08 10:49:49.232 - [32minfo[39m: iobroker host.iobroker object kodi.0.playid created 2017-01-08 10:49:49.290 - [32minfo[39m: iobroker host.iobroker object kodi.0.mute created 2017-01-08 10:49:49.343 - [32minfo[39m: iobroker host.iobroker object kodi.0.stop created 2017-01-08 10:49:49.407 - [32minfo[39m: iobroker host.iobroker object kodi.0.previous created 2017-01-08 10:49:49.584 - [32minfo[39m: iobroker host.iobroker object kodi.0.next created 2017-01-08 10:49:49.898 - [32minfo[39m: iobroker host.iobroker object kodi.0.SwitchPVR created 2017-01-08 10:49:50.091 - [32minfo[39m: iobroker host.iobroker object kodi.0.youtube created 2017-01-08 10:49:50.129 - [32minfo[39m: iobroker host.iobroker object kodi.0.open created 2017-01-08 10:49:50.173 - [32minfo[39m: iobroker host.iobroker object kodi.0.seek created 2017-01-08 10:49:50.222 - [32minfo[39m: iobroker host.iobroker object kodi.0.ShowNotif created 2017-01-08 10:49:50.263 - [32minfo[39m: iobroker host.iobroker object kodi.0.ActivateWindow created 2017-01-08 10:49:50.375 - [32minfo[39m: iobroker host.iobroker object kodi.0.add created 2017-01-08 10:49:50.439 - [32minfo[39m: iobroker host.iobroker object kodi.0.ExecuteAction created 2017-01-08 10:49:50.500 - [32minfo[39m: iobroker host.iobroker object kodi.0.zoom created 2017-01-08 10:49:50.549 - [32minfo[39m: iobroker host.iobroker object kodi.0.setsubtitle created 2017-01-08 10:49:50.604 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Up created 2017-01-08 10:49:50.658 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ShowOSD created 2017-01-08 10:49:50.764 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ShowCodec created 2017-01-08 10:49:50.827 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.SendText created 2017-01-08 10:49:50.866 - [32minfo[39m: vis.0 Changes in index.html detected => update cache.manifest 2017-01-08 10:49:51.006 - [32minfo[39m: vis.0 Upload vis anew, while changes detected... 2017-01-08 10:49:51.013 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Select created 2017-01-08 10:49:51.061 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Right created 2017-01-08 10:49:51.121 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Left created 2017-01-08 10:49:51.165 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Info created 2017-01-08 10:49:51.210 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Home created 2017-01-08 10:49:51.271 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Down created 2017-01-08 10:49:51.331 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ContextMenu created 2017-01-08 10:49:51.368 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Back created 2017-01-08 10:49:51.425 - [32minfo[39m: iobroker host.iobroker object kodi.0.currentplay created 2017-01-08 10:49:51.464 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlist created 2017-01-08 10:49:51.511 - [32minfo[39m: iobroker host.iobroker object kodi.0.VideoLibrary created 2017-01-08 10:49:51.558 - [32minfo[39m: iobroker host.iobroker object kodi.0.Directory created 2017-01-08 10:49:51.598 - [32minfo[39m: iobroker host.iobroker object kodi.0.ScanVideoLibrary created 2017-01-08 10:49:51.655 - [32minfo[39m: iobroker host.iobroker object kodi.0.ScanAudioLibrary created 2017-01-08 10:49:51.741 - [32minfo[39m: iobroker host.iobroker object kodi.0.CleanVideoLibrary created 2017-01-08 10:49:51.789 - [32minfo[39m: iobroker host.iobroker object kodi.0.CleanAudioLibrary created 2017-01-08 10:49:51.854 - [32minfo[39m: iobroker host.iobroker object kodi.0.Sources created 2017-01-08 10:49:51.917 - [32minfo[39m: iobroker host.iobroker object kodi.0.OnInputRequested created 2017-01-08 10:49:51.971 - [32minfo[39m: iobroker host.iobroker object kodi.0.state created 2017-01-08 10:49:52.034 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.connection created 2017-01-08 10:49:52.076 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.upload created 2017-01-08 10:49:52.117 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.uptime created 2017-01-08 10:49:52.168 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memRss created 2017-01-08 10:49:52.239 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memHeapTotal created 2017-01-08 10:49:52.299 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memHeapUsed created 2017-01-08 10:49:52.332 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.connected created 2017-01-08 10:49:52.402 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.alive created 2017-01-08 10:49:52.431 - [32minfo[39m: host.iobroker object change system.adapter.kodi.0 2017-01-08 10:49:52.472 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0 created 2017-01-08 10:49:52.483 - [32minfo[39m: iobroker exit 0 2017-01-08 10:49:52.927 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:52.942 - [32minfo[39m: host.iobroker "system.adapter.vis.0" disabled 2017-01-08 10:49:52.955 - [32minfo[39m: host.iobroker stopInstance system.adapter.vis.0 2017-01-08 10:49:53.001 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:53.007 - [32minfo[39m: host.iobroker "system.adapter.vis.0" enabled 2017-01-08 10:49:53.007 - [32minfo[39m: host.iobroker stopInstance system.adapter.vis.0[/code]</v8::object></v8::object></v8::object></v8::object></v8::object></near></v8::object></v8::object></near></v8::string></v8::object></v8::object></v8::object></class></class></v8::object></v8::object></v8::object></v8::object></v8::object></near></v8::object></v8::object></near></v8::string></v8::object></v8::object></v8::object></class></class>
