  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер KODI
    5.3k
Драйвер KODI
Geplant Angeheftet Gesperrt Verschoben ioBroker драйвера
41 Beiträge 7 Kommentatoren 11.6k Aufrufe
    spectrekr
    Не встал.
    ! iobroker 23 11:47:30.692 info upload [0] kodi C:/Home/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html
    ! iobroker 23 11:47:30.333 info upload [1] kodi C:/Home/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png
    ! iobroker 23 11:47:30.224 info upload [2] kodi C:/Home/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown
    ! iobroker 23 11:47:30.198 info got C:/Home/iobroker/node_modules/iobroker.kodi/www
    ! iobroker 23 11:47:30.098 info upload [0] kodi.admin C:/Home/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html
    ! iobroker 23 11:47:29.973 info upload [1] kodi.admin C:/Home/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png
    ! iobroker 23 11:47:29.933 info host.SpectreKr install adapter kodi
    ! iobroker 23 11:45:45.898 info npm WARN optional dep failed, continuing bufferutil@1.1.0
    ! iobroker 23 11:45:45.878 info WARN optional dep failed, continuing utf-8-validate@1.1.0
    ! iobroker 23 11:45:45.877 info npm
    ! iobroker 23 11:45:45.845 info FATAL ERROR: Malloced operator new Allocation failed - process out of memory
    ! iobroker 23 11:45:45.329 info FATAL ERROR: Malloced operator new Allocation failed - process out of memory
    ! iobroker 23 11:45:41.967 info in npm 3+. Your application will need to depend on it explicitly.
    ! iobroker 23 11:45:41.963 info peerDependencies
    ! iobroker 23 11:45:41.960 info
    ! iobroker 23 11:45:41.955 info WARN
    ! iobroker 23 11:45:41.954 info
    ! iobroker 23 11:45:41.920 info npm
    ! iobroker 23 11:45:41.916 info longer be automatically installed to fulfill the peerDependency
    ! iobroker 23 11:45:41.911 info peerDependencies
    ! iobroker 23 11:45:41.909 info
    ! iobroker 23 11:45:41.904 info WARN
    ! iobroker 23 11:45:41.882 info
    ! iobroker 23 11:45:41.881 info npm
    ! iobroker 23 11:45:41.877 info The peer dependency eslint@<2.3.0 included from babel-eslint will no
    ! iobroker 23 11:45:41.872 info peerDependencies
    ! iobroker 23 11:45:41.871 info
    ! iobroker 23 11:45:41.850 info WARN
    ! iobroker 23 11:45:41.845 info
    ! iobroker 23 11:45:41.841 info npm
    ! iobroker 23 11:45:35.081 info npm install iobroker.kodi –production --prefix "C:/Home/iobroker" (System call)
    ! iobroker 23 11:45:34.005 info add kodi
    • V Offline
      V Offline
      vtec
      У меня при установке то же WARN
      ! host-test 24 16:48:42.530 info instance system.adapter.vis.0 terminated while should be started once
      ! vis-0 24 16:48:42.018 info Uploaded.
      ! vis-0 24 16:48:39.988 info 300 files uploaded…
      ! vis-0 24 16:48:34.666 info 200 files uploaded...
      ! vis-0 24 16:48:29.352 info 100 files uploaded...
      ! iobroker 24 16:48:25.481 info exit 0
      ! iobroker 24 16:48:25.479 info host.test object system.adapter.kodi.0 created
      ! host-test 24 16:48:25.471 info object change system.adapter.kodi.0
      ! iobroker 24 16:48:25.443 info host.test object system.adapter.kodi.0.alive created
      ! iobroker 24 16:48:25.409 info host.test object system.adapter.kodi.0.connected created
      ! iobroker 24 16:48:25.381 info host.test object system.adapter.kodi.0.memHeapUsed created
      ! iobroker 24 16:48:25.351 info host.test object system.adapter.kodi.0.memHeapTotal created
      ! iobroker 24 16:48:25.322 info host.test object system.adapter.kodi.0.memRss created
      ! iobroker 24 16:48:25.294 info host.test object system.adapter.kodi.0.uptime created
      ! iobroker 24 16:48:25.271 info host.test object system.adapter.kodi.upload created
      ! iobroker 24 16:48:25.233 info host.test object kodi.0.info.connection created
      ! iobroker 24 16:48:25.205 info host.test object kodi.0.OnInputRequested created
      ! iobroker 24 16:48:25.168 info host.test object kodi.0.Sources created
      ! iobroker 24 16:48:25.139 info host.test object kodi.0.CleanAudioLibrary created
      ! iobroker 24 16:48:25.111 info host.test object kodi.0.CleanVideoLibrary created
      ! iobroker 24 16:48:25.087 info host.test object kodi.0.ScanAudioLibrary created
      ! iobroker 24 16:48:25.055 info host.test object kodi.0.ScanVideoLibrary created
      ! iobroker 24 16:48:25.027 info host.test object kodi.0.Directory created
      ! iobroker 24 16:48:24.993 info host.test object kodi.0.VideoLibrary created
      ! iobroker 24 16:48:24.964 info host.test object kodi.0.playlist created
      ! iobroker 24 16:48:24.933 info host.test object kodi.0.currentplay created
      ! iobroker 24 16:48:24.902 info host.test object kodi.0.input.Back created
      ! iobroker 24 16:48:24.874 info host.test object kodi.0.input.ContextMenu created
      ! iobroker 24 16:48:24.847 info host.test object kodi.0.input.Down created
      ! iobroker 24 16:48:24.813 info host.test object kodi.0.input.Home created
      ! iobroker 24 16:48:24.785 info host.test object kodi.0.input.Info created
      ! iobroker 24 16:48:24.753 info host.test object kodi.0.input.Left created
      ! iobroker 24 16:48:24.724 info host.test object kodi.0.input.Right created
      ! iobroker 24 16:48:24.695 info host.test object kodi.0.input.Select created
      ! iobroker 24 16:48:24.651 info host.test object kodi.0.input.SendText created
      ! iobroker 24 16:48:24.622 info host.test object kodi.0.input.ShowCodec created
      ! iobroker 24 16:48:24.595 info host.test object kodi.0.input.ShowOSD created
      ! iobroker 24 16:48:24.567 info host.test object kodi.0.input.Up created
      ! iobroker 24 16:48:24.538 info host.test object kodi.0.setsubtitle created
      ! iobroker 24 16:48:24.509 info host.test object kodi.0.zoom created
      ! iobroker 24 16:48:24.481 info host.test object kodi.0.ExecuteAction created
      ! iobroker 24 16:48:24.451 info host.test object kodi.0.GoTo created
      ! iobroker 24 16:48:24.421 info host.test object kodi.0.ActivateWindow created
      ! iobroker 24 16:48:24.393 info host.test object kodi.0.ShowNotif created
      ! iobroker 24 16:48:24.365 info host.test object kodi.0.seek created
      ! iobroker 24 16:48:24.336 info host.test object kodi.0.open created
      ! iobroker 24 16:48:24.304 info host.test object kodi.0.youtube created
      ! iobroker 24 16:48:24.273 info host.test object kodi.0.SwitchPVR created
      ! iobroker 24 16:48:24.242 info host.test object kodi.0.next created
      ! iobroker 24 16:48:24.214 info host.test object kodi.0.previous created
      ! iobroker 24 16:48:24.188 info host.test object kodi.0.stop created
      ! iobroker 24 16:48:24.155 info host.test object kodi.0.mute created
      ! iobroker 24 16:48:24.126 info host.test object kodi.0.volume created
      ! iobroker 24 16:48:24.096 info host.test object kodi.0.pvr.playlist_tv created
      ! iobroker 24 16:48:24.069 info host.test object kodi.0.pvr.playlist_radio created
      ! iobroker 24 16:48:24.038 info host.test object kodi.0.playing_time created
      ! iobroker 24 16:48:24.009 info host.test object kodi.0.playing_time_total created
      ! iobroker 24 16:48:23.974 info host.test object kodi.0.canseek created
      ! iobroker 24 16:48:23.944 info host.test object kodi.0.repeat created
      ! iobroker 24 16:48:23.913 info host.test object kodi.0.shuffle created
      ! iobroker 24 16:48:23.883 info host.test object kodi.0.speed created
      ! iobroker 24 16:48:23.852 info host.test object kodi.0.position created
      ! iobroker 24 16:48:23.823 info host.test object kodi.0.playlistid created
      ! iobroker 24 16:48:23.794 info host.test object kodi.0.partymode created
      ! iobroker 24 16:48:23.762 info host.test object kodi.0.codec created
      ! iobroker 24 16:48:23.733 info host.test object kodi.0.samplerate created
      ! iobroker 24 16:48:23.703 info host.test object kodi.0.bitrate created
      ! iobroker 24 16:48:23.673 info host.test object kodi.0.type created
      ! host-test 24 16:48:23.658 info stopInstance system.adapter.vis.0
      ! host-test 24 16:48:23.658 info 'system.adapter.vis.0' enabled
      ! host-test 24 16:48:23.657 info object change system.adapter.vis.0
      ! iobroker 24 16:48:23.648 info host.test object kodi.0.info.album created
      ! host-test 24 16:48:23.643 info stopInstance system.adapter.vis.0
      ! host-test 24 16:48:23.642 info 'system.adapter.vis.0' disabled
      ! host-test 24 16:48:23.642 info object change system.adapter.vis.0
      ! iobroker 24 16:48:23.616 info host.test object kodi.0.info.artist created
      ! iobroker 24 16:48:23.588 info host.test object kodi.0.info.fanart created
      ! iobroker 24 16:48:23.559 info host.test object kodi.0.info.file created
      ! iobroker 24 16:48:23.530 info host.test object kodi.0.info.genre created
      ! iobroker 24 16:48:23.499 info host.test object kodi.0.info.label created
      ! iobroker 24 16:48:23.468 info host.test object kodi.0.info.playcount created
      ! iobroker 24 16:48:23.438 info host.test object kodi.0.info.rating created
      ! iobroker 24 16:48:23.406 info host.test object kodi.0.info.thumbnail created
      ! iobroker 24 16:48:23.370 info host.test object kodi.0.info.title created
      ! iobroker 24 16:48:23.342 info host.test object kodi.0.info.track created
      ! iobroker 24 16:48:23.312 info host.test object kodi.0.info.type created
      ! iobroker 24 16:48:23.284 info host.test object kodi.0.info.year created
      ! iobroker 24 16:48:23.256 info host.test object kodi.0.playlist created
      ! iobroker 24 16:48:23.228 info host.test object kodi.0.systeminfo.name created
      ! iobroker 24 16:48:23.200 info host.test object kodi.0.systeminfo.version created
      ! iobroker 24 16:48:23.172 info host.test object kodi.0.systeminfo.system created
      ! vis-0 24 16:48:23.165 info Upload vis anew, while changes detected...
      ! vis-0 24 16:48:23.160 info Changes in index.html detected => update cache.manifest
      ! iobroker 24 16:48:23.123 info host.test object kodi.0.systeminfo.kernel created
      ! iobroker 24 16:48:23.089 info host.test object kodi.0.channels created
      ! iobroker 24 16:48:23.061 info host.test object kodi.0.language created
      ! iobroker 24 16:48:23.034 info host.test object kodi.0.audiostream created
      ! iobroker 24 16:48:22.920 info host.test object kodi.0.info.id created
      ! iobroker 24 16:48:22.891 info host.test object kodi.0.info.albumartist created
      ! iobroker 24 16:48:22.864 info host.test object kodi.0.play created
      ! iobroker 24 16:48:22.835 info host.test object kodi.0.pause created
      ! vis-0 24 16:48:22.772 info config.js changed. Upload.
      ! vis-0 24 16:48:22.648 info starting. Version 0.10.1 in /opt/iobroker/node_modules/iobroker.vis
      ! iobroker 24 16:48:22.777 info host.test object kodi.0.info.episode created
      ! iobroker 24 16:48:22.747 info host.test object kodi.0.info.imdbnumber created
      ! iobroker 24 16:48:22.719 info host.test object kodi.0.info.originaltitle created
      ! iobroker 24 16:48:22.687 info host.test object kodi.0.info.plot created
      ! iobroker 24 16:48:22.659 info host.test object kodi.0.info.season created
      ! iobroker 24 16:48:22.631 info host.test object kodi.0.info.showtitle created
      ! iobroker 24 16:48:22.600 info host.test object kodi.0.info.audio created
      ! iobroker 24 16:48:22.571 info host.test object kodi.0.info.subtitle created
      ! iobroker 24 16:48:22.542 info host.test object kodi.0.info.video created
      ! iobroker 24 16:48:22.516 info host.test object kodi.0.info.tagline created
      ! iobroker 24 16:48:22.488 info host.test object kodi.0.info.audio_channels created
      ! iobroker 24 16:48:22.461 info host.test object kodi.0.info.audio_codec created
      ! iobroker 24 16:48:22.433 info host.test object kodi.0.info.audio_language created
      ! iobroker 24 16:48:22.406 info host.test object kodi.0.info.video_aspect created
      ! iobroker 24 16:48:22.378 info host.test object kodi.0.info.video_codec created
      ! iobroker 24 16:48:22.350 info host.test object kodi.0.info.video_duration created
      ! iobroker 24 16:48:22.321 info host.test object kodi.0.info.video_height created
      ! iobroker 24 16:48:22.293 info host.test object kodi.0.info.video_stereomode created
      ! iobroker 24 16:48:22.264 info host.test object kodi.0.info.video_width created
      ! iobroker 24 16:48:22.233 info host.test object kodi.0.info.subtitle_language created
      ! iobroker 24 16:48:22.224 info host.test create instance kodi
      ! iobroker 24 16:48:22.165 info host.test object system.adapter.kodi created
      ! iobroker 24 16:48:22.097 info upload [0] kodi /opt/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown
      ! iobroker 24 16:48:22.042 info upload [1] kodi /opt/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html
      ! iobroker 24 16:48:21.978 info upload [2] kodi /opt/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png
      ! iobroker 24 16:48:21.953 info Adapter 'system.adapter.vis.0' restarted.got /opt/iobroker/node_modules/iobroker.kodi/www
      ! host-test 24 16:48:21.930 info 'system.adapter.vis.0' enabled
      ! host-test 24 16:48:21.929 info object change system.adapter.vis.0
      ! host-test 24 16:48:21.917 info 'system.adapter.vis.0' disabled
      ! host-test 24 16:48:21.916 info object change system.adapter.vis.0
      ! iobroker 24 16:48:21.816 info upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html
      ! iobroker 24 16:48:21.744 info upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png
      ! iobroker 24 16:48:21.716 info got /opt/iobroker/node_modules/iobroker.kodi/admin
      ! iobroker 24 16:48:21.703 info host.test install adapter kodi
      ! iobroker 24 16:48:15.876 info npm WARN optional dep failed, continuing bufferutil@1.1.0
      ! iobroker 24 16:48:15.869 info npm WARN optional dep failed, continuing utf-8-validate@1.1.0
      ! iobroker 24 16:48:15.831 info node-gyp -v v3.3.1gyp ERR! not ok
      ! iobroker 24 16:48:15.824 info gyp ERR!
      ! iobroker 24 16:48:15.824 info ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutilgyp ERR! node -v v4.4.3
      ! iobroker 24 16:48:15.822 info gyp
      ! iobroker 24 16:48:15.822 info ERR! System Linux 3.13.0-85-genericgyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
      ! iobroker 24 16:48:15.820 info stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)gyp
      ! iobroker 24 16:48:15.817 info gyp ERR! stack at ChildProcess.emit (events.js:172:7)gyp ERR!
      ! iobroker 24 16:48:15.814 info at emitTwo (events.js:87:13)
      ! iobroker 24 16:48:15.813 info stack
      ! iobroker 24 16:48:15.811 info ERR!
      ! iobroker 24 16:48:15.808 info
      ! iobroker 24 16:48:15.803 info gyp
      ! iobroker 24 16:48:15.793 info gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! iobroker 24 16:48:15.793 info gyp ERR! build error gyp ERR! stack Error: make failed with exit code: 2
      ! iobroker 24 16:48:15.785 info make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Ошибка 1
      ! iobroker 24 16:48:15.665 info ^
      ! iobroker 24 16:48:15.665 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
      ! iobroker 24 16:48:15.665 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal’ to ‘v8::Local’
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
      ! iobroker 24 16:48:15.665 info In file included from ../src/bufferutil.cc:16:0:
      ! iobroker 24 16:48:15.665 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
      ! iobroker 24 16:48:15.665 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      ! iobroker 24 16:48:15.665 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
      ! iobroker 24 16:48:15.665 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
      ! iobroker 24 16:48:15.665 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
      ! iobroker 24 16:48:15.665 info In file included from ../src/bufferutil.cc:10:0:
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h:672:67: note: candidates are:
      ! iobroker 24 16:48:15.665 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 24 16:48:15.665 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
      ! iobroker 24 16:48:15.664 info ^
      ! iobroker 24 16:48:15.664 info v8::Isolate::GetCurrent(), data, length, callback, hint);
      ! iobroker 24 16:48:15.664 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
      ! iobroker 24 16:48:15.664 info ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
      ! iobroker 24 16:48:15.664 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:
      ! iobroker 24 16:48:15.664 info , node::smalloc::FreeCallback callback
      ! iobroker 24 16:48:15.664 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’
      ! iobroker 24 16:48:15.664 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
      ! iobroker 24 16:48:15.634 info ^
      ! iobroker 24 16:48:15.634 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      ! iobroker 24 16:48:15.634 info ../node_modules/nan/nan.h:256:25: error: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here
      ! iobroker 24 16:48:15.634 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      ! iobroker 24 16:48:15.634 info In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
      ! iobroker 24 16:48:14.661 info gyp ERR! not ok
      ! iobroker 24 16:48:14.661 info gyp ERR! node-gyp -v v3.3.1
      ! iobroker 24 16:48:14.661 info gyp ERR! node -v v4.4.3
      ! iobroker 24 16:48:14.661 info gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validate
      ! iobroker 24 16:48:14.661 info gyp ERR! command '/usr/bin/nodejs' '/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js' 'rebuild'
      ! iobroker 24 16:48:14.661 info gyp ERR! System Linux 3.13.0-85-generic
      ! iobroker 24 16:48:14.661 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
      ! iobroker 24 16:48:14.661 info gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      ! iobroker 24 16:48:14.661 info gyp ERR! stack at emitTwo (events.js:87:13)
      ! iobroker 24 16:48:14.661 info gyp ERR! stack Error: make failed with exit code: 2gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
      ! iobroker 24 16:48:14.654 info gyp ERR! build error
      ! iobroker 24 16:48:14.651 info make: *** [Release/obj.target/validation/src/validation.o] Ошибка 1
      ! iobroker 24 16:48:14.536 info ^
      ! iobroker 24 16:48:14.536 info return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h: In function ‘v8::Local NanBufferUse(char*, uint32_t)’:
      ! iobroker 24 16:48:14.536 info return node::Buffer::New(v8::Isolate::GetCurrent(), size);
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal’ to ‘v8::Local’
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(uint32_t)’:
      ! iobroker 24 16:48:14.536 info In file included from ../src/validation.cc:15:0:
      ! iobroker 24 16:48:14.536 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’
      ! iobroker 24 16:48:14.536 info NODE_EXTERN v8::MaybeLocal New(v8::Isolate* isolate,
      ! iobroker 24 16:48:14.536 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:43:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, char*, size_t)
      ! iobroker 24 16:48:14.536 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’
      ! iobroker 24 16:48:14.536 info /home/ryzhov/.node-gyp/4.4.3/include/node/node_buffer.h:31:40: note: v8::MaybeLocal node::Buffer::New(v8::Isolate*, v8::Local, node::encoding)
      ! iobroker 24 16:48:14.536 info In file included from ../src/validation.cc:10:0:
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:672:67: note: candidates are:
      ! iobroker 24 16:48:14.536 info return node::Buffer::New(v8::Isolate::GetCurrent(), data, size);
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(const char*, uint32_t)’:
      ! iobroker 24 16:48:14.536 info v8::Isolate::GetCurrent(), data, length, callback, hint);
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h: In function ‘v8::Local NanNewBufferHandle(char*, size_t, int)’:
      ! iobroker 24 16:48:14.536 info , node::smalloc::FreeCallback callback
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘…’ before ‘callback’
      ! iobroker 24 16:48:14.536 info ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback
      ! iobroker 24 16:48:14.528 info ^
      ! iobroker 24 16:48:14.528 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) {
      ! iobroker 24 16:48:14.528 info ../node_modules/nan/nan.h:256:25: error: ‘template v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here
      ! iobroker 24 16:48:14.528 info NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) {
      ! iobroker 24 16:48:14.528 info In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template v8::Local _NanEnsureLocal(v8::Local)’
      ! iobroker 24 16:48:07.135 info in npm 3+. Your application will need to depend on it explicitly.
      ! iobroker 24 16:48:07.135 info peerDependencies
      ! iobroker 24 16:48:07.134 info
      ! iobroker 24 16:48:07.134 info WARN
      ! iobroker 24 16:48:07.133 info
      ! iobroker 24 16:48:07.133 info npm
      ! iobroker 24 16:48:07.132 info longer be automatically installed to fulfill the peerDependency
      ! iobroker 24 16:48:07.130 info peerDependencies
      ! iobroker 24 16:48:07.128 info
      ! iobroker 24 16:48:07.127 info WARN
      ! iobroker 24 16:48:07.124 info
      ! iobroker 24 16:48:07.122 info npm
      ! iobroker 24 16:48:07.115 info WARN peerDependencies The peer dependency eslint@<2.3.0 included from babel-eslint will no
      ! iobroker 24 16:48:07.114 info npm
      ! iobroker 24 16:48:00.557 info npm install iobroker.kodi --production --prefix '/opt/iobroker' (System call)
      ! iobroker 24 16:48:00.254 info add kodi
      После установки и запуска KODI в логе
      kodi-0	24 17:00:01.138	error	TypeError: Cannot read property 'playerid' of undefined
      Сделал импорт элементов, на белом фоне не видно клавиш управления
      У меня вешается коди или просто перестает управляться, если в списке выбрать фильм, а потом нажать кнопку стоп, потом нет возможности включить из списка что либо.
      Еще хотелось бы увидеть виджет пульта управления. :oops:
      • I Offline
        I Offline
        instalator
        На варнинги можно не обращать внимания.
        А в ятси как кнопка стоп в плейлисте работает?
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
          DAndre
          Объясните пож-та.
          запускаю````
          sendTo("kodi.0", {
          message: 'Возможно протечка воды ', //Текст сообщения
          title: 'ВНИМАНИЕ!!!', //Заголовок сообщения
          //image: 'https://raw.githubusercontent.com/instalator/ioBroker.kodi/master/admin/kodi.png', //Ссылка на иконку
          delay: '7000' //Время отображения сообщения милисекундах (минимум 1500 макс 30000 мс)
          а в ответ тишина ( в логе–--kodi-0 2016-07-31 10:31:03.209 info KODI connected
          kodi-0 2016-07-31 10:31:03.165 error Error: Server responded with error: Invalid params.
          kodi-0 2016-07-31 10:31:03.162 info sending in KODI: GUI.ShowNotification - {"title":"ВНИМАНИЕ!!!","message":"Возможно протечка воды ","image":"info","displaytime":"7000"}
          javascript-0 2016-07-31 10:31:03.159 info script.js.Kodi: registered 0 subscriptions and 0 schedules
          javascript-0 2016-07-31 10:31:03.156 info Start javascript script.js.Kodi )
          :shock:
          <size size="50">Ubuntu 14.04 trusty DISTRIB_DESCRIPTION="Ubuntu 14.04.3 LTS, Android v4.4.2"
          Ubuntu 16.04.1 LTS (GNU/Linux 4.4.0-31-generic x86_64)</size>
            spectrekr
            Проверил, проблема именно во второй инстанции. Поменял IP местами и первая отработала, а вторая все также в ошибку упала.
            ! host-Cubian 2016-09-30 08:04:08.114 error instance system.adapter.kodi.1 terminated with code 0 (OK)
            ! kodi-1 2016-09-30 08:04:07.889 info terminating
            ! kodi-1 2016-09-30 08:04:07.599 info sending in KODI: Playlist.Add - {"playlistid":0,"item":{"file":"smb:\\192.168.1.200\hlam\PlayList\mult.m3u"}}
            ! kodi-1 2016-09-30 08:04:07.519 info cleaned everything up…
            ! TypeError: 2016-09-30 08:04:07.513 error at Timer.listOnTimeout (timers.js:92:15)
            ! TypeError: 2016-09-30 08:04:07.513 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2124:38)
            ! TypeError: 2016-09-30 08:04:07.513 error at Adapter.emit (events.js:172:7)
            ! TypeError: 2016-09-30 08:04:07.513 error at emitTwo (events.js:87:13)
            ! TypeError: 2016-09-30 08:04:07.513 error at Adapter. (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:85:9)
            ! TypeError: 2016-09-30 08:04:07.513 error at ConstructorCmd (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:239:5)
            ! TypeError: 2016-09-30 08:04:07.513 error at sendCommand (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:244:9)
            ! TypeError: 2016-09-30 08:04:07.513 error at getConnection (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:615:15)
            ! TypeError: 2016-09-30 08:04:07.513 error at /opt/iobroker/node_modules/iobroker.kodi/kodi.js:247:29
            ! TypeError: 2016-09-30 08:04:07.513 error at Connection.run (/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/lib/Connection.js:105:24)
            ! TypeError: 2016-09-30 08:04:07.513 error Cannot read property 'apply' of undefined
            ! uncaught 2016-09-30 08:04:07.456 error exception: Cannot read property 'apply' of undefined
            ! kodi-1 2016-09-30 08:04:07.361 info sending in KODI: 1 - "smb:\\192.168.1.200\hlam\PlayList\mult.m3u"
            ! kodi-1 2016-09-30 08:04:07.350 info sending in KODI: Playlist.Clear - {"playlistid":0}
            ! kodi-1 2016-09-30 08:04:07.210 info stateChange kodi.1.open {"val":"smb:\\192.168.1.200\hlam\PlayList\mult.m3u","ack":false,"ts":1475211847169,"q":0,"from":"system.adapter.javascript.0","lc":1475157076643}
            • I Offline
              I Offline
              instalator
              @spectrekr:
              ! kodi-1 2016-09-30 08:04:07.210 info stateChange kodi.1.open {"val":"smb:\\192.168.1.200\hlam\PlayList\mult.m3u","ack":false,"ts":1475211847169,"q":0,"from":"system.adapter.javascript.0","lc":1475157076643} `
              Порты менял в коди?
                spectrekr
                Замена портов не решает, как и предполагалось. В режиме дебаг
                ! host-Cubian 2016-09-30 09:49:33.327 info Restart adapter system.adapter.kodi.1 because enabled
                ! host-Cubian 2016-09-30 09:49:33.317 error instance system.adapter.kodi.1 terminated with code 0 (OK)
                ! kodi-1 2016-09-30 09:49:33.036 debug Response GetPlayerId: [{"playerid":1,"type":"video"}]
                ! kodi-1 2016-09-30 09:49:33.032 info sending in KODI: Playlist.Add - {"playlistid":0,"item":{"file":"smb:\\192.168.1.200\hlam\PlayList\mult.m3u"}}
                ! kodi-1 2016-09-30 09:49:33.030 debug response from KODI: "OK"
                ! kodi-1 2016-09-30 09:49:32.995 info cleaned everything up…
                ! TypeError: 2016-09-30 09:49:32.989 error at Timer.listOnTimeout (timers.js:92:15)
                ! TypeError: 2016-09-30 09:49:32.989 error at null._onTimeout (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:2124:38)
                ! TypeError: 2016-09-30 09:49:32.989 error at Adapter.emit (events.js:172:7)
                ! TypeError: 2016-09-30 09:49:32.989 error at emitTwo (events.js:87:13)
                ! TypeError: 2016-09-30 09:49:32.989 error at Adapter. (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:85:9)
                ! TypeError: 2016-09-30 09:49:32.989 error at ConstructorCmd (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:239:5)
                ! TypeError: 2016-09-30 09:49:32.989 error at sendCommand (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:244:9)
                ! TypeError: 2016-09-30 09:49:32.989 error at getConnection (/opt/iobroker/node_modules/iobroker.kodi/kodi.js:615:15)
                ! TypeError: 2016-09-30 09:49:32.989 error at /opt/iobroker/node_modules/iobroker.kodi/kodi.js:247:29
                ! TypeError: 2016-09-30 09:49:32.989 error at Connection.run (/opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/lib/Connection.js:105:24)
                ! TypeError: 2016-09-30 09:49:32.989 error Cannot read property 'apply' of undefined
                ! uncaught 2016-09-30 09:49:32.960 error exception: Cannot read property 'apply' of undefined
                ! kodi-1 2016-09-30 09:49:32.915 info sending in KODI: 1 - "smb:\\192.168.1.200\hlam\PlayList\mult.m3u"
                ! kodi-1 2016-09-30 09:49:32.901 info sending in KODI: Playlist.Clear - {"playlistid":0}
                ! kodi-1 2016-09-30 09:49:32.867 info stateChange kodi.1.open {"val":"smb:\\192.168.1.200\hlam\PlayList\mult.m3u","ack":false,"ts":1475218172842,"q":0,"from":"system.adapter.javascript.0","lc":1475157076643}
                • V Offline
                  V Offline
                  vtec
                  Последние дороботки
                  kodi.0	2016-12-25 16:31:45.648	info	sending in KODI: GUI.SetFullscreen - {"fullscreen":true}
                  kodi.0	2016-12-25 16:31:44.675	info	sending in KODI: Player.Open - {"item":{"playlistid":1,"position":0}}
                  kodi.0	2016-12-25 16:31:44.672	warn	It does not specify commands or invalid value!
                  kodi.0	2016-12-25 16:31:44.671	info	sending in KODI: Input.ExecuteAction - {"action":"select"}
                  kodi.0	2016-12-25 16:31:44.671	info	stateChange kodi.0.youtube {"val":"https://www.youtube.com/watch?v=mHGbA7I5HZY&list=PL3916F42A7EE0DEF0","ack":false,"ts":1482658304666,"q":0,"from":"system.adapter.web.0","lc":1482655832426}
                  • I Offline
                    I Offline
                    instalator
                    @vtec:
                    Последние дороботки
                    ! ` > case "youtube":
                    method = null;
                    if (param){
                    if (~param.indexOf('http')){
                    param = param.toString().split('=');
                    if (param.length > 2){
                    param = param[param.length - 1];
                    param = {'item': {'file': 'plugin://plugin.video.youtube/?path=/root/video&action=play_all&playlist=' + param.toString()}};
                    } else if (param.length === 2){
                    param = param[1];
                    param = {'item': {'file': 'plugin://plugin.video.youtube/?action=play_video&videoid=' + param.toString()}};
                    } else {
                    if (param.toString().length > 12){
                    } else {
                    sendCommand('Player.Open', param, function (){
                    sendCommand('Input.ExecuteAction', { "action": "select" }, function (){
                    sendCommand('Player.Open', {'item': {'playlistid': 1, 'position': 0}}, function (){
                    sendCommand('GUI.SetFullscreen', {"fullscreen": true});
                    break; `
                    • Alex1808A Offline
                      Alex1808A Offline
                      Alex1808
                      Последнее обновление ставится с ошибками в логе
                      2017-01-08 10:48:27.191 - [32minfo[39m: iobroker del kodi.0 2017-01-08 10:48:27.967 - [32minfo[39m: iobroker host.iobroker Counted 1 instances of kodi.0 2017-01-08 10:48:27.976 - [32minfo[39m: iobroker host.iobroker Counted 6 states "system.adapter.kodi.0*" from states 2017-01-08 10:48:28.718 - [32minfo[39m: iobroker host.iobroker Counted 71 states "io.kodi.0*" from states 2017-01-08 10:48:28.734 - [32minfo[39m: iobroker host.iobroker Counted 71 states "kodi.0*" from states 2017-01-08 10:48:29.222 - [32minfo[39m: iobroker host.iobroker Counted 104 objects of kodi.0 2017-01-08 10:48:29.459 - [32minfo[39m: iobroker host.iobroker Counted 103 objects of states of kodi.0 2017-01-08 10:48:29.465 - [32minfo[39m: iobroker host.iobroker Deleting 104 object(s). 2017-01-08 10:48:31.125 - [32minfo[39m: host.iobroker object change system.adapter.kodi.0 2017-01-08 10:48:31.127 - [32minfo[39m: host.iobroker object deleted system.adapter.kodi.0 2017-01-08 10:48:32.452 - [32minfo[39m: iobroker exit 0 2017-01-08 10:48:44.537 - [32minfo[39m: iobroker del kodi 2017-01-08 10:48:45.203 - [32minfo[39m: iobroker host.iobroker delete /opt/iobroker/node_modules/iobroker.kodi 2017-01-08 10:48:45.844 - [32minfo[39m: iobroker host.iobroker no instances of adapter kodi found 2017-01-08 10:48:45.884 - [32minfo[39m: iobroker host.iobroker Counted 1 adapters for kodihost.iobroker Counted 1 states (system.adapter.kodi.*) from states ! 2017-01-08 10:48:46.066 - [32minfo[39m: iobroker host.iobroker Counted 1 states of kodi 2017-01-08 10:48:46.076 - [32minfo[39m: iobroker host.iobroker Deleting 2 object(s). 2017-01-08 10:48:46.164 - [31merror[39m: iobroker Not exists 2017-01-08 10:48:46.252 - [32minfo[39m: iobroker exit 0 2017-01-08 10:48:46.840 - [31merror[39m: Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi/_data.json' 2017-01-08 10:48:46.841 - [31merror[39m: Cannot write files: /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/_data.json: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/files/kodi.admin/_data.json' 2017-01-08 10:48:55.540 - [32minfo[39m: iobroker add kodi 2017-01-08 10:48:56.529 - [32minfo[39m: iobroker npm install iobroker.kodi --production --prefix "/opt/iobroker" (System call) 2017-01-08 10:49:00.250 - [32minfo[39m: iobroker npm 2017-01-08 10:49:00.259 - [32minfo[39m: iobroker 2017-01-08 10:49:00.280 - [32minfo[39m: iobroker WARN peerDependencies The peer dependency eslint@<2.3.0 included from babel-eslint will nonpm WARN peerDependencies longer be automatically installed to fulfill the peerDependency npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly. ! 2017-01-08 10:49:11.658 - [32minfo[39m: iobroker In file included from ../src/validation.cc:15:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’ NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) { ^ ! 2017-01-08 10:49:11.684 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) { ^ ! 2017-01-08 10:49:11.831 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:11.845 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’ , node::smalloc::FreeCallback callback ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(char*, size_t, int)’: ../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(const char*, uint32_t)’: ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous return node::Buffer::New(v8::Isolate::GetCurrent(), data, size); ^ ../node_modules/nan/nan.h:672:67: note: candidates are: In file included from ../src/validation.cc:10:0: /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, v8::Local<v8::string>, node::encoding) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, char*, size_t) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’ In file included from ../src/validation.cc:15:0: ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(uint32_t)’: ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::object>’ to ‘v8::Local<v8::object>’ return node::Buffer::New(v8::Isolate::GetCurrent(), size); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanBufferUse(char*, uint32_t)’: ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’ return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:12.281 - [32minfo[39m: iobroker make: *** [Release/obj.target/validation/src/validation.o] Error 1gyp 2017-01-08 10:49:12.299 - [32minfo[39m: iobroker ERR! build error gyp 2017-01-08 10:49:12.346 - [32minfo[39m: iobroker ERR! stack Error: makefailed with exit code: 2 2017-01-08 10:49:12.407 - [32minfo[39m: iobroker gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13) gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12) gyp 2017-01-08 10:49:12.415 - [32minfo[39m: iobroker ERR! System Linux 3.16.0-4-amd64gyp 2017-01-08 10:49:12.421 - [32minfo[39m: iobroker ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp 2017-01-08 10:49:12.429 - [32minfo[39m: iobroker ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/utf-8-validategyp ERR! node -v v4.7.2 gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok 2017-01-08 10:49:12.442 - [32minfo[39m: iobroker 2017-01-08 10:49:17.395 - [32minfo[39m: iobroker In file included from ../src/bufferutil.cc:16:0:../node_modules/nan/nan.h:261:25: error: redefinition of ‘template <class t="">v8::Local _NanEnsureLocal(v8::Local)’ NAN_INLINE v8::Local _NanEnsureLocal(v8::Local val) { ^ ! 2017-01-08 10:49:17.413 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:256:25: note: ‘template <class t="">v8::Local _NanEnsureLocal(v8::Handle)’ previously declared here NAN_INLINE v8::Local _NanEnsureLocal(v8::Handle val) { ^ ! 2017-01-08 10:49:17.469 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:13: error: ‘node::smalloc’ has not been declared , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:17.474 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:661:35: error: expected ‘,’ or ‘...’ before ‘callback’ , node::smalloc::FreeCallback callback ^ ! 2017-01-08 10:49:17.478 - [32minfo[39m: iobroker ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(char*, size_t, int)’:../node_modules/nan/nan.h:665:50: error: ‘callback’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ! 2017-01-08 10:49:17.484 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:665:60: error: ‘hint’ was not declared in this scope v8::Isolate::GetCurrent(), data, length, callback, hint); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(const char*, uint32_t)’: ../node_modules/nan/nan.h:672:67: error: call of overloaded ‘New(v8::Isolate*, const char*&, uint32_t&)’ is ambiguous return node::Buffer::New(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:17.486 - [32minfo[39m: iobroker ../node_modules/nan/nan.h:672:67: note: candidates are:In file included from ../src/bufferutil.cc:10:0: /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, v8::Local<v8::string>, node::encoding) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ ! 2017-01-08 10:49:17.489 - [32minfo[39m: iobroker /root/.node-gyp/4.7.2/include/node/node_buffer.h:34:40: note: no known conversion for argument 3 from ‘uint32_t {aka unsigned int}’ to ‘node::encoding’/root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: v8::MaybeLocal <v8::object>node::Buffer::New(v8::Isolate*, char*, size_t) <near match=""> NODE_EXTERN v8::MaybeLocal <v8::object>New(v8::Isolate* isolate, ^ /root/.node-gyp/4.7.2/include/node/node_buffer.h:46:40: note: no known conversion for argument 2 from ‘const char*’ to ‘char*’ In file included from ../src/bufferutil.cc:16:0: ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanNewBufferHandle(uint32_t)’: ../node_modules/nan/nan.h:676:61: error: could not convert ‘node::Buffer::New(v8::Isolate::GetCurrent(), ((size_t)size))’ from ‘v8::MaybeLocal<v8::object>’ to ‘v8::Local<v8::object>’ return node::Buffer::New(v8::Isolate::GetCurrent(), size); ^ ../node_modules/nan/nan.h: In function ‘v8::Local <v8::object>NanBufferUse(char*, uint32_t)’: ../node_modules/nan/nan.h:683:12: error: ‘Use’ is not a member of ‘node::Buffer’ return node::Buffer::Use(v8::Isolate::GetCurrent(), data, size); ^ ! 2017-01-08 10:49:17.751 - [32minfo[39m: iobroker make: *** [Release/obj.target/bufferutil/src/bufferutil.o] Error 1 2017-01-08 10:49:17.777 - [32minfo[39m: iobroker gyp ERR! build error 2017-01-08 10:49:17.795 - [32minfo[39m: iobroker gyp 2017-01-08 10:49:17.799 - [32minfo[39m: iobroker 2017-01-08 10:49:17.806 - [32minfo[39m: iobroker ERR! stack Error:make failed with exit code: 2gyp 2017-01-08 10:49:17.818 - [32minfo[39m: iobroker ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23) 2017-01-08 10:49:17.821 - [32minfo[39m: iobroker gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7) gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12) gyp ERR! System Linux 3.16.0-4-amd64 gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild" gyp ERR! cwd /opt/iobroker/node_modules/iobroker.kodi/node_modules/kodi-ws/node_modules/ws/node_modules/bufferutil gyp 2017-01-08 10:49:17.835 - [32minfo[39m: iobroker ERR! 2017-01-08 10:49:17.854 - [32minfo[39m: iobroker node -v v4.7.2gyp ERR! node-gyp -v v3.4.0 gyp ERR! not ok ! 2017-01-08 10:49:17.871 - [32minfo[39m: iobroker npm 2017-01-08 10:49:17.875 - [32minfo[39m: iobroker WARN optional dep failed, continuing 2017-01-08 10:49:17.880 - [32minfo[39m: iobroker utf-8-validate@1.1.0 2017-01-08 10:49:17.884 - [32minfo[39m: iobroker npm WARN 2017-01-08 10:49:17.886 - [32minfo[39m: iobroker optional dep failed, continuing bufferutil@1.1.0 2017-01-08 10:49:42.906 - [32minfo[39m: iobroker host.iobroker install adapter kodi 2017-01-08 10:49:42.965 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.kodi/admin 2017-01-08 10:49:42.998 - [32minfo[39m: iobroker upload [3] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/web.jpg web.jpg image/jpeg 2017-01-08 10:49:43.131 - [32minfo[39m: iobroker upload [2] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/remote.jpg remote.jpg image/jpeg 2017-01-08 10:49:43.361 - [32minfo[39m: iobroker upload [1] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/kodi.png kodi.png image/png 2017-01-08 10:49:43.431 - [32minfo[39m: iobroker upload [0] kodi.admin /opt/iobroker/node_modules/iobroker.kodi/admin/index.html index.html text/html 2017-01-08 10:49:43.713 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:43.716 - [32minfo[39m: host.iobroker "system.adapter.vis.0" disabled 2017-01-08 10:49:43.770 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:43.770 - [32minfo[39m: host.iobroker "system.adapter.vis.0" enabled 2017-01-08 10:49:43.891 - [32minfo[39m: iobroker Adapter "system.adapter.vis.0" restarted.got /opt/iobroker/node_modules/iobroker.kodi/www ! 2017-01-08 10:49:43.924 - [32minfo[39m: iobroker upload [2] kodi /opt/iobroker/node_modules/iobroker.kodi/www/kodi.png kodi.png image/png 2017-01-08 10:49:44.038 - [32minfo[39m: iobroker upload [1] kodi /opt/iobroker/node_modules/iobroker.kodi/www/index.html index.html text/html 2017-01-08 10:49:44.115 - [32minfo[39m: iobroker upload [0] kodi /opt/iobroker/node_modules/iobroker.kodi/www/README.md README.md text/x-markdown 2017-01-08 10:49:44.298 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi created 2017-01-08 10:49:44.402 - [32minfo[39m: iobroker host.iobroker create instance kodi 2017-01-08 10:49:44.519 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.subtitle_language created 2017-01-08 10:49:44.570 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_width created 2017-01-08 10:49:44.737 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_stereomode created 2017-01-08 10:49:44.811 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_height created 2017-01-08 10:49:44.877 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_duration created 2017-01-08 10:49:44.928 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_codec created 2017-01-08 10:49:44.975 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video_aspect created 2017-01-08 10:49:45.035 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_language created 2017-01-08 10:49:45.090 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_codec created 2017-01-08 10:49:45.145 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio_channels created 2017-01-08 10:49:45.214 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.tagline created 2017-01-08 10:49:45.275 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.video created 2017-01-08 10:49:45.397 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.subtitle created 2017-01-08 10:49:45.435 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.audio created 2017-01-08 10:49:45.493 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.showtitle created 2017-01-08 10:49:45.553 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.season created 2017-01-08 10:49:45.673 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.plot created 2017-01-08 10:49:45.722 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.originaltitle created 2017-01-08 10:49:45.769 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.imdbnumber created 2017-01-08 10:49:45.827 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.episode created 2017-01-08 10:49:45.877 - [32minfo[39m: iobroker host.iobroker object kodi.0.pause created 2017-01-08 10:49:45.944 - [32minfo[39m: iobroker host.iobroker object kodi.0.play created 2017-01-08 10:49:46.015 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.albumartist created 2017-01-08 10:49:46.170 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.id created 2017-01-08 10:49:46.303 - [32minfo[39m: iobroker host.iobroker object kodi.0.audiostream created 2017-01-08 10:49:46.367 - [32minfo[39m: iobroker host.iobroker object kodi.0.language created 2017-01-08 10:49:46.441 - [32minfo[39m: iobroker host.iobroker object kodi.0.channels created 2017-01-08 10:49:46.493 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.kernel created 2017-01-08 10:49:46.538 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.system created 2017-01-08 10:49:46.590 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.version created 2017-01-08 10:49:46.708 - [32minfo[39m: iobroker host.iobroker object kodi.0.systeminfo.name created 2017-01-08 10:49:46.782 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlist created 2017-01-08 10:49:46.830 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.year created 2017-01-08 10:49:46.901 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.type created 2017-01-08 10:49:46.966 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.track created 2017-01-08 10:49:47.036 - [32minfo[39m: iobroker host.iobroker object kodi.0.clear created 2017-01-08 10:49:47.108 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.title created 2017-01-08 10:49:47.182 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.thumbnail created 2017-01-08 10:49:47.237 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.rating created 2017-01-08 10:49:47.298 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.playcount created 2017-01-08 10:49:47.356 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.label created 2017-01-08 10:49:47.402 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.genre created 2017-01-08 10:49:47.464 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.file created 2017-01-08 10:49:47.525 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.fanart created 2017-01-08 10:49:47.597 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.artist created 2017-01-08 10:49:47.699 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.album created 2017-01-08 10:49:47.749 - [32minfo[39m: iobroker host.iobroker object kodi.0.type created 2017-01-08 10:49:47.820 - [32minfo[39m: iobroker host.iobroker object kodi.0.bitrate created 2017-01-08 10:49:47.891 - [32minfo[39m: iobroker host.iobroker object kodi.0.samplerate created 2017-01-08 10:49:47.931 - [32minfo[39m: iobroker host.iobroker object kodi.0.codec created 2017-01-08 10:49:45.862 - [32minfo[39m: vis.0 starting. Version 0.12.3 in /opt/iobroker/node_modules/iobroker.vis, node: v4.7.2 2017-01-08 10:49:48.393 - [32minfo[39m: iobroker host.iobroker object kodi.0.partymode created 2017-01-08 10:49:48.451 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlistid created 2017-01-08 10:49:48.497 - [32minfo[39m: iobroker host.iobroker object kodi.0.position created 2017-01-08 10:49:48.543 - [32minfo[39m: iobroker host.iobroker object kodi.0.speed created 2017-01-08 10:49:48.595 - [32minfo[39m: iobroker host.iobroker object kodi.0.shuffle created 2017-01-08 10:49:48.834 - [32minfo[39m: iobroker host.iobroker object kodi.0.repeat created 2017-01-08 10:49:48.872 - [32minfo[39m: iobroker host.iobroker object kodi.0.canseek created 2017-01-08 10:49:48.912 - [32minfo[39m: iobroker host.iobroker object kodi.0.playing_time_total created 2017-01-08 10:49:48.988 - [32minfo[39m: iobroker host.iobroker object kodi.0.playing_time created 2017-01-08 10:49:49.055 - [32minfo[39m: iobroker host.iobroker object kodi.0.pvr.playlist_radio created 2017-01-08 10:49:49.112 - [32minfo[39m: iobroker host.iobroker object kodi.0.pvr.playlist_tv created 2017-01-08 10:49:49.170 - [32minfo[39m: iobroker host.iobroker object kodi.0.volume created 2017-01-08 10:49:49.232 - [32minfo[39m: iobroker host.iobroker object kodi.0.playid created 2017-01-08 10:49:49.290 - [32minfo[39m: iobroker host.iobroker object kodi.0.mute created 2017-01-08 10:49:49.343 - [32minfo[39m: iobroker host.iobroker object kodi.0.stop created 2017-01-08 10:49:49.407 - [32minfo[39m: iobroker host.iobroker object kodi.0.previous created 2017-01-08 10:49:49.584 - [32minfo[39m: iobroker host.iobroker object kodi.0.next created 2017-01-08 10:49:49.898 - [32minfo[39m: iobroker host.iobroker object kodi.0.SwitchPVR created 2017-01-08 10:49:50.091 - [32minfo[39m: iobroker host.iobroker object kodi.0.youtube created 2017-01-08 10:49:50.129 - [32minfo[39m: iobroker host.iobroker object kodi.0.open created 2017-01-08 10:49:50.173 - [32minfo[39m: iobroker host.iobroker object kodi.0.seek created 2017-01-08 10:49:50.222 - [32minfo[39m: iobroker host.iobroker object kodi.0.ShowNotif created 2017-01-08 10:49:50.263 - [32minfo[39m: iobroker host.iobroker object kodi.0.ActivateWindow created 2017-01-08 10:49:50.375 - [32minfo[39m: iobroker host.iobroker object kodi.0.add created 2017-01-08 10:49:50.439 - [32minfo[39m: iobroker host.iobroker object kodi.0.ExecuteAction created 2017-01-08 10:49:50.500 - [32minfo[39m: iobroker host.iobroker object kodi.0.zoom created 2017-01-08 10:49:50.549 - [32minfo[39m: iobroker host.iobroker object kodi.0.setsubtitle created 2017-01-08 10:49:50.604 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Up created 2017-01-08 10:49:50.658 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ShowOSD created 2017-01-08 10:49:50.764 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ShowCodec created 2017-01-08 10:49:50.827 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.SendText created 2017-01-08 10:49:50.866 - [32minfo[39m: vis.0 Changes in index.html detected => update cache.manifest 2017-01-08 10:49:51.006 - [32minfo[39m: vis.0 Upload vis anew, while changes detected... 2017-01-08 10:49:51.013 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Select created 2017-01-08 10:49:51.061 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Right created 2017-01-08 10:49:51.121 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Left created 2017-01-08 10:49:51.165 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Info created 2017-01-08 10:49:51.210 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Home created 2017-01-08 10:49:51.271 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Down created 2017-01-08 10:49:51.331 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.ContextMenu created 2017-01-08 10:49:51.368 - [32minfo[39m: iobroker host.iobroker object kodi.0.input.Back created 2017-01-08 10:49:51.425 - [32minfo[39m: iobroker host.iobroker object kodi.0.currentplay created 2017-01-08 10:49:51.464 - [32minfo[39m: iobroker host.iobroker object kodi.0.playlist created 2017-01-08 10:49:51.511 - [32minfo[39m: iobroker host.iobroker object kodi.0.VideoLibrary created 2017-01-08 10:49:51.558 - [32minfo[39m: iobroker host.iobroker object kodi.0.Directory created 2017-01-08 10:49:51.598 - [32minfo[39m: iobroker host.iobroker object kodi.0.ScanVideoLibrary created 2017-01-08 10:49:51.655 - [32minfo[39m: iobroker host.iobroker object kodi.0.ScanAudioLibrary created 2017-01-08 10:49:51.741 - [32minfo[39m: iobroker host.iobroker object kodi.0.CleanVideoLibrary created 2017-01-08 10:49:51.789 - [32minfo[39m: iobroker host.iobroker object kodi.0.CleanAudioLibrary created 2017-01-08 10:49:51.854 - [32minfo[39m: iobroker host.iobroker object kodi.0.Sources created 2017-01-08 10:49:51.917 - [32minfo[39m: iobroker host.iobroker object kodi.0.OnInputRequested created 2017-01-08 10:49:51.971 - [32minfo[39m: iobroker host.iobroker object kodi.0.state created 2017-01-08 10:49:52.034 - [32minfo[39m: iobroker host.iobroker object kodi.0.info.connection created 2017-01-08 10:49:52.076 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.upload created 2017-01-08 10:49:52.117 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.uptime created 2017-01-08 10:49:52.168 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memRss created 2017-01-08 10:49:52.239 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memHeapTotal created 2017-01-08 10:49:52.299 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.memHeapUsed created 2017-01-08 10:49:52.332 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.connected created 2017-01-08 10:49:52.402 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0.alive created 2017-01-08 10:49:52.431 - [32minfo[39m: host.iobroker object change system.adapter.kodi.0 2017-01-08 10:49:52.472 - [32minfo[39m: iobroker host.iobroker object system.adapter.kodi.0 created 2017-01-08 10:49:52.483 - [32minfo[39m: iobroker exit 0 2017-01-08 10:49:52.927 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:52.942 - [32minfo[39m: host.iobroker "system.adapter.vis.0" disabled 2017-01-08 10:49:52.955 - [32minfo[39m: host.iobroker stopInstance system.adapter.vis.0 2017-01-08 10:49:53.001 - [32minfo[39m: host.iobroker object change system.adapter.vis.0 2017-01-08 10:49:53.007 - [32minfo[39m: host.iobroker "system.adapter.vis.0" enabled 2017-01-08 10:49:53.007 - [32minfo[39m: host.iobroker stopInstance system.adapter.vis.0[/code]</v8::object></v8::object></v8::object></v8::object></v8::object></near></v8::object></v8::object></near></v8::string></v8::object></v8::object></v8::object></class></class></v8::object></v8::object></v8::object></v8::object></v8::object></near></v8::object></v8::object></near></v8::string></v8::object></v8::object></v8::object></class></class>
