  4. Fehlermeldungen im log bei node10 update
node10 fehler log
1 Beiträge 1 Kommentatoren 259 Aufrufe
  • E Offline
    e-s
    schrieb am zuletzt editiert von e-s
    Hallo, seit dem ich mein System auf den aktuellen Stand gebracht habe, wird bei jeder npm Aktion eine Fehlermeldung ausgeworfen, hier zum Beispiel der Install von shelly:
    $ ./iobroker add shelly  --host ubuntuserver
    NPM version: 6.9.0
    npm install iobroker.shelly@3.0.5 --production --save --prefix "/opt/iobroker" (System call)
    In file included from ../node_modules/nan/nan.h:190:0,                 from ../src/unix_dgram.cc:5:
    ../node_modules/nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe<bool> Nan::ForceSet(v8::Local<v8::Object>, v8::Local<v8::Value>, v8::Local<v8::Value>, v8::PropertyAttribute)’:
    ../node_modules/nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
       return obj->ForceSet(GetCurrentContext(), key, value, attribs);
    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:817:60: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, func, argc, argv);
    In file included from ../node_modules/nan/nan.h:47:0,
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:177:50: note: declared here
                     NODE_EXTERN v8::Local<v8::Value> MakeCallback(
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
         __attribute__((deprecated(message))) declarator
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:831:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::String>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, symbol, argc, argv);
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:170:50: note: declared here
    ../node_modules/nan/nan.h: In function ‘v8::Local<v8::Value> Nan::MakeCallback(v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’:
    ../node_modules/nan/nan.h:845:62: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, const char*, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
             v8::Isolate::GetCurrent(), target, method, argc, argv);
    /home/iobroker/.node-gyp/10.16.0/include/node/node.h:163:50: note: declared here
    In file included from ../src/unix_dgram.cc:5:0:../node_modules/nan/nan.h: In member function ‘v8::Local<v8::Value> Nan::Callback::Call_(v8::Isolate*, v8::Local<v8::Object>, int, v8::Local<v8::Value>*) const’:
    ../node_modules/nan/nan.h:1463:5: warning: ‘v8::Local<v8::Value> node::MakeCallback(v8::Isolate*, v8::Local<v8::Object>, v8::Local<v8::Function>, int, v8::Local<v8::Value>*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Socket(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:189:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       domain      = info[0]->Int32Value();
    In file included from /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:26:0,
                     from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63,
                     from ../node_modules/nan/nan.h:47,
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2478:46: note: declared here
       V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
    /home/iobroker/.node-gyp/10.16.0/include/node/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
       declarator __attribute__((deprecated(message)))
    ../src/unix_dgram.cc:190:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       type        = info[1]->Int32Value();
    ../src/unix_dgram.cc:191:37: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       protocol    = info[2]->Int32Value();
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Bind(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:230:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       fd = info[0]->Int32Value();
    ../src/unix_dgram.cc:231:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[1]);
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2892:28: note: declared here
                       explicit Utf8Value(Local<v8::Value> obj));
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::SendTo(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:258:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:259:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       buf = info[1]->ToObject();
    In file included from /home/iobroker/.node-gyp/10.16.0/include/node/node.h:63:0,
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:10046:15: note: declared here
     Local<Object> Value::ToObject() const {
    ../src/unix_dgram.cc:260:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       offset = info[2]->Uint32Value();
    /home/iobroker/.node-gyp/10.16.0/include/node/v8.h:2477:47: note: declared here
       V8_DEPRECATED("Use maybe version", uint32_t Uint32Value() const);
    ../src/unix_dgram.cc:261:33: warning: ‘uint32_t v8::Value::Uint32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
       length = info[3]->Uint32Value();
    ../src/unix_dgram.cc:262:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
       String::Utf8Value path(info[4]);
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Send(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:302:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:303:27: warning: ‘v8::Local<v8::Object> v8::Value::ToObject() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Connect(Nan::NAN_METHOD_ARGS_TYPE)’:../src/unix_dgram.cc:340:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc:341:33: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Local<v8::Value>)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
    ../src/unix_dgram.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE {anonymous}::Close(Nan::NAN_METHOD_ARGS_TYPE)’:
    ../src/unix_dgram.cc:361:28: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
    make: *** [Release/obj.target/unix_dgram/src/unix_dgram.o] Error 1
    gyp
     ERR! build error gyp ERR! stack Error: `make` failed with exit code: 2
    gyp ERR! stack     at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:262:23)
    gyp ERR! stack     at ChildProcess.emit (events.js:198:13)
    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:248:12)
    gyp ERR! System Linux 4.15.0-51-generic
    gyp ERR! command "/usr/bin/node" "/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/unix-dgram
    gyp ERR! node -v v10.16.0
    gyp ERR! node-gyp -v v3.8.0
    gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.3 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.3: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"x64"})
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 (node_modules/unix-dgram):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: unix-dgram@0.2.3 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    host.ubuntuserver install adapter shelly
    npm install --production (System call) in "/opt/iobroker/node_modules/iobroker.shelly"
    npm
    notice
     created a lockfile as package-lock.json. You should commit this file.
    got /opt/iobroker/node_modules/iobroker.shelly/admin
    upload [2] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/words.js words.js application/javascript
    upload [1] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/shelly.png shelly.png image/png
    upload [0] shelly.admin /opt/iobroker/node_modules/iobroker.shelly/admin/index_m.html index_m.html text/html
    host.ubuntuserver object system.adapter.shelly created
    host.ubuntuserver create instance shelly
    host.ubuntuserver object shelly.0.info.connection created
    host.ubuntuserver object shelly.0.info created
    host.ubuntuserver object system.adapter.shelly.0.outputCount created
    host.ubuntuserver object system.adapter.shelly.0.inputCount created
    host.ubuntuserver object system.adapter.shelly.0.uptime created
    host.ubuntuserver object system.adapter.shelly.0.memRss created
    host.ubuntuserver object system.adapter.shelly.0.memHeapTotal created
    host.ubuntuserver object system.adapter.shelly.0.memHeapUsed created
    host.ubuntuserver object system.adapter.shelly.0.cputime created
    host.ubuntuserver object system.adapter.shelly.0.cpu created
    host.ubuntuserver object system.adapter.shelly.0.connected created
    host.ubuntuserver object system.adapter.shelly.0.alive created
    host.ubuntuserver object system.adapter.shelly.0 created
    process exited with code 0
    Hier meine Sys-Infos:
    ubuntuserver
    Betriebssystem    linux
    Architektur    x64
    CPUs    2
    Geschwindigkeit    1500 MHz
    Modell    AMD Turion(tm) II Neo N40L Dual-Core Processor
    RAM    3.73 GB
    System Betriebszeit    16 T. 05:29:55
    Node.js    v10.16.0
    NPM    6.9.0
    Habe nach Anleitung npm und node aktualisiert, anschließend fangen die Probleme im log an.
    Prinzipiell sind mir aber in der Benutzung von iobroker keine sonstigen Fehler aufgefallen.
    Aber ich mag keine Fehlermeldungen :-)
    Habe dann alles ausprobiert was ich so in den Anleitungen gefunden habe, also alle Module löschen, bis zu alles zu löschen und iobroker-data zurückspielen. Ausserdem habe ich dgram manuell nachinstalliert. Aber alles blieb gleich, selbst bein einer frischen Installation gibt es die Fehlermeldungen.
    Kann mir das nicht mehr erklären, wenn meine Daten zurückgespielt wurden, dann lief npm rebuild nie durch, nur bei der frischen Install. npm audit bringt mir auch immer eine Meldung mit der ich nichts anfangen, npm audit fix läuft auch nur bei frischer install durch, aber auch da mit Fehlern am schluss:
    132 silly install unix-dgram@0.2.3
    133 info lifecycle unix-dgram@0.2.3~install: unix-dgram@0.2.3
    134 verbose lifecycle unix-dgram@0.2.3~install: unsafe-perm in lifecycle true
    135 verbose lifecycle unix-dgram@0.2.3~install: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/unix-dgram/node_modules/.bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
    136 verbose lifecycle unix-dgram@0.2.3~install: CWD: /opt/iobroker/node_modules/unix-dgram
    137 silly lifecycle unix-dgram@0.2.3~install: Args: [ '-c', 'node-gyp rebuild' ]
    138 timing audit submit Completed in 1639ms
    139 http fetch POST 200 https://registry.npmjs.org/-/npm/v1/security/audits/quick 1638ms
    140 timing audit body Completed in 2ms
    141 silly lifecycle unix-dgram@0.2.3~install: Returned: code: 1  signal: null
    142 info lifecycle unix-dgram@0.2.3~install: Failed to exec install script
    143 timing action:install Completed in 2797ms
    144 silly doSerial postinstall 32
    145 timing action:postinstall Completed in 1ms
    146 verbose unlock done using /media/HDD/.npm/_locks/staging-66d2468782e8ffc7.lock for /opt/iobroker/node_modules/.staging
    147 timing stage:executeActions Completed in 3066ms
    148 timing stage:rollbackFailedOptional Completed in 51ms
    149 silly install runPostinstallTopLevelLifecycles
    150 silly build iobroker.inst@2.0.3
    151 info linkStuff iobroker.inst@2.0.3
    152 silly linkStuff iobroker.inst@2.0.3 has /opt as its parent node_modules
    153 silly install iobroker.inst@2.0.3
    154 info lifecycle iobroker.inst@2.0.3~install: iobroker.inst@2.0.3
    155 verbose lifecycle iobroker.inst@2.0.3~install: unsafe-perm in lifecycle true
    156 verbose lifecycle iobroker.inst@2.0.3~install: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
    157 verbose lifecycle iobroker.inst@2.0.3~install: CWD: /opt/iobroker
    158 silly lifecycle iobroker.inst@2.0.3~install: Args: [ '-c', 'node lib/checkVersions.js' ]
    159 silly lifecycle iobroker.inst@2.0.3~install: Returned: code: 0  signal: null
    160 silly postinstall iobroker.inst@2.0.3
    161 info lifecycle iobroker.inst@2.0.3~postinstall: iobroker.inst@2.0.3
    162 verbose lifecycle iobroker.inst@2.0.3~postinstall: unsafe-perm in lifecycle true
    163 verbose lifecycle iobroker.inst@2.0.3~postinstall: PATH: /usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/node-gyp-bin:/opt/iobroker/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
    164 verbose lifecycle iobroker.inst@2.0.3~postinstall: CWD: /opt/iobroker
    165 silly lifecycle iobroker.inst@2.0.3~postinstall: Args: [ '-c', 'node lib/install.js' ]
    166 silly lifecycle iobroker.inst@2.0.3~postinstall: Returned: code: 100  signal: null
    167 info lifecycle iobroker.inst@2.0.3~postinstall: Failed to exec postinstall script
    168 verbose stack Error: iobroker.inst@2.0.3 postinstall: `node lib/install.js`
    168 verbose stack Exit status 100
    168 verbose stack     at EventEmitter.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/index.js:301:16)
    168 verbose stack     at EventEmitter.emit (events.js:198:13)
    168 verbose stack     at ChildProcess.<anonymous> (/usr/local/lib/node_modules/npm/node_modules/npm-lifecycle/lib/spawn.js:55:14)
    168 verbose stack     at ChildProcess.emit (events.js:198:13)
    168 verbose stack     at maybeClose (internal/child_process.js:982:16)
    168 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5)
    169 verbose pkgid iobroker.inst@2.0.3
    170 verbose cwd /opt/iobroker
    171 verbose Linux 4.15.0-51-generic
    172 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "install"
    173 verbose node v10.16.0
    174 verbose npm  v6.9.0
    175 error code ELIFECYCLE
    176 error errno 100
    177 error iobroker.inst@2.0.3 postinstall: `node lib/install.js`
    177 error Exit status 100
    178 error Failed at the iobroker.inst@2.0.3 postinstall script.
    178 error This is probably not a problem with npm. There is likely additional logging output above.
    179 verbose exit [ 100, true ]
    0 info it worked if it ends with ok
    1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'audit' ]
    2 info using npm@6.9.0
    3 info using node@v10.16.0
    4 verbose npm-session 6fbd4fa9556d6967
    5 verbose stack Error: Errors were found in your package-lock.json, run  npm install  to fix them.
    5 verbose stack     Invalid: lock file's iobroker.admin@3.6.2 does not satisfy iobroker.admin@^3.6.3
    5 verbose stack     Invalid: lock file's iobroker.js-controller@1.5.11 does not satisfy iobroker.js-controller@^1.5.12
    5 verbose stack     at lockVerify.then (/usr/local/lib/node_modules/npm/lib/audit.js:184:19)
    6 verbose cwd /opt/iobroker
    7 verbose Linux 4.15.0-51-generic
    8 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "audit"
    9 verbose node v10.16.0
    10 verbose npm  v6.9.0
    11 error code ELOCKVERIFY
    12 error Errors were found in your package-lock.json, run  npm install  to fix them.
    12 error     Invalid: lock file's iobroker.admin@3.6.2 does not satisfy iobroker.admin@^3.6.3
    12 error     Invalid: lock file's iobroker.js-controller@1.5.11 does not satisfy iobroker.js-controller@^1.5.12
    13 verbose exit [ 1, true ]
    Suche ich nach einem Fehler, den es gar nicht gibt?
