  2. English
  3. ioBroker general
  4. iobroker - problem with the installation
    5.4k
Geplant Angeheftet Gesperrt Verschoben ioBroker general
iobroker installationiobroker updateiobroker nodejs
8 Beiträge 4 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    mguc
    Can someone help me with installation ibroker on my cubieboard?
    I try instal based on some information:
    1. Node.js
      [as user by sudo or as root]
    curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
    sudo apt-get install -y build-essential libavahi-compat-libdnssd-dev libudev-dev libpam0g-dev nodejs
    reboot
    1. iobroker
      [as user or as root]
    curl -sL https://iobroker.net/install.sh | bash -
    And.. administrator panel i see on http://192.168.10.xx:8081/
    But when i try to add some Instances from Adapters tabs then it's impossible. See on log bellow:
    $ ./iobroker add modbus --host cubietruck
    NPM version: 6.4.1
    npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
    Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
    npm ERR! cb() never called!
    npm ERR! This is an error with npm itself. Please report this error at:
    npm ERR! https://npm.community
    host.cubietruck install adapter modbus
    NPM version: 6.4.1
    NPM version: 6.4.1npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
    ERROR: host.cubietruck Cannot install modbus
    ERROR: process exited with code 13
    iobroker 2019-06-20 13:11:07.736 info exit 13
    iobroker 2019-06-20 13:11:07.701 error host.cubietruck Cannot install modbus
    iobroker 2019-06-20 13:11:07.691 info host.cubietruck install adapter modbus
    iobroker 2019-06-20 13:11:07.651 info npm ERR! https://npm.community
    iobroker 2019-06-20 13:11:07.651 info npm ERR! This is an error with npm itself. Please report this error at:
    iobroker 2019-06-20 13:11:07.640 info npm ERR! cb() never called!
    iobroker 2019-06-20 13:11:07.624 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
    iobroker 2019-06-20 13:10:41.166 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
    iobroker 2019-06-20 13:10:41.156 info NPM version: 6.4.1
    iobroker 2019-06-20 13:10:37.983 info host.cubietruck install adapter modbus
    iobroker 2019-06-20 13:10:37.946 info npm ERR! https://npm.community
    iobroker 2019-06-20 13:10:37.946 info npm ERR! This is an error with npm itself. Please report this error at:
    iobroker 2019-06-20 13:10:37.932 info npm ERR! cb() never called!
    iobroker 2019-06-20 13:10:37.912 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
    iobroker 2019-06-20 13:10:11.309 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
    iobroker 2019-06-20 13:10:11.305 info NPM version: 6.4.1
    iobroker 2019-06-20 13:10:07.994 info host.cubietruck install adapter modbus
    iobroker 2019-06-20 13:10:07.876 info npm ERR! https://npm.community
    iobroker 2019-06-20 13:10:07.876 info npm ERR! This is an error with npm itself. Please report this error at:
    iobroker 2019-06-20 13:10:07.876 info npm ERR! cb() never called!
    iobroker 2019-06-20 13:10:07.858 info Unhandled rejection Error: EACCES: permission denied, mkdir '/home/iobroker'
    iobroker 2019-06-20 13:09:40.412 info npm install iobroker.modbus@2.0.9 --production --save --prefix "/opt/iobroker" (System call)
    iobroker 2019-06-20 13:09:38.369 info NPM version: 6.4.1
    iobroker 2019-06-20 13:09:31.903 info add modbus --host cubietruck
    I try with node6, 8 and 10 with the same effect. Where is my bug ?
    • M mguc
      1. Node.js
      reboot
      1. iobroker
      NPM version: 6.4.1
      NPM version: 6.4.1
      mguc
      Finally - I found the cause of my problem :D
      The error is in the installation script (install.sh). He's creates the user "iobroker" but does not assume the home directory: / home / iobroker (at least for me).
      The installation process looks like this:
      1. Node.js installation (as user)
      sudo apt-get --purge remove node
      sudo apt-get --purge remove nodejs
      sudo apt-get autoremove
      sudo reboot
      sudo reboot
      2 iobroker installation (as user)
      iobroker stop
      sudo mkdir /home/iobroker
      sudo chown iobroker /home/iobroker
      iobroker start
      .. done.
      • M mguc
        sudo reboot
        sudo reboot
        iobroker stop
        iobroker start
        .. done.
        AlCalzoneA Offline
        AlCalzoneA Offline
        AlCalzone
        @mguc the install script executes a command that creates the user together with the home directory. If it didn't, something must have went wrong. Do you by any chance still have the output of the installer?
        M 2 Antworten Letzte Antwort
        • AlCalzoneA AlCalzone
          mguc
          @AlCalzone
          where can i find any installer log ?
            mguc
            @AlCalzone
            I found my fault. Some days ago i removed this folder (removed folder than remove iobroker user ;) )
            And when i try to install again - in system was iobroker user then (probably) install script not created it again.
            • M mguc
              @AlCalzone
              AlCalzoneA Offline
              AlCalzoneA Offline
              AlCalzone
              @mguc Yes that makes sense
                mguc
                @AlCalzone
                I reinstalled yesterday all iobroker system (now with remove user ;) ).
                After that install script works fine - then now i can confirm my mistake.
                • M mguc
                  @AlCalzone
                  AlCalzoneA Offline
                  AlCalzoneA Offline
                  AlCalzone
                  @mguc I added an issue to the installer repo so we can catch this problem in the future. Thanks for reporting.
