  4. [Fehler] Adapter deaktiviert # Adapter started (Yr, DWD)
    5.6k
1 Beiträge 1 Kommentatoren 777 Aufrufe
  • derAugeD Offline
    derAugeD Offline
    derAuge
    Habe die beiden Adapter (YR,DWD) deaktiviert.
    Es wird trotzdem versucht den Adapter zu starten
    • host-RPi2-2 2016-04-04 07:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 07:06:00 info instance system.adapter.yr.0 started with pid 4460
    host-RPi2-2 2016-04-04 07:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 07:03:00 info instance system.adapter.dwd.0 started with pid 4450
    host-RPi2-2 2016-04-04 06:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 06:06:00 info instance system.adapter.yr.0 started with pid 4234
    host-RPi2-2 2016-04-04 06:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 06:03:00 info instance system.adapter.dwd.0 started with pid 4224
    host-RPi2-2 2016-04-04 05:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 05:06:00 info instance system.adapter.yr.0 started with pid 4173
    host-RPi2-2 2016-04-04 05:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 05:03:00 info instance system.adapter.dwd.0 started with pid 4163
    host-RPi2-2 2016-04-04 04:06:03 error instance system.adapter.yr.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 04:06:00 info instance system.adapter.yr.0 started with pid 4108
    host-RPi2-2 2016-04-04 04:03:04 error instance system.adapter.dwd.0 terminated with code 3 (Adapter disabled or invalid config)
    host-RPi2-2 2016-04-04 04:03:00 info instance system.adapter.dwd.0 started with pid 4099
    Glaube das es nicht so gewollt ist
    Jürgen
