  4. Pi 3 als Bluetooth LE Scanner (Beispielscript)
    5.9k
254 Beiträge 28 Kommentatoren 78.4k Aufrufe 4 Beobachtet
    #41
    Finde das Skript auch interessant.
    Nachdem ich nach wie vor keine AHnung habe, hab ich es in ioBroker kopiert und gestartet.
    Prompt gab es eine Fehler meldung:
    javascript-0 2016-05-01 16:10:50 error WARN optional dep failed, continuing usb@1.1.2
    javascript-0 2016-05-01 16:10:50 error npm
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! not ok
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! node-pre-gyp -v v0.6.24
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! node -v v4.4.3
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! command "/usr/bin/nodejs" "/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/node_modules/.bin/node-pre-gyp" "inst
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! System Linux 4.4.7-v7+
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
    javascript-0 2016-05-01 16:10:50 error ERR! stack at maybeClose (internal/child_process.js:827:16)
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! stack at ChildProcess. (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb/node_modules/node-pre-gyp
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/nodejs /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroke
    javascript-0 2016-05-01 16:10:50 error node-pre-gyp ERR! build error
    javascript-0 2016-05-01 16:10:50 error gyp ERR! not ok
    javascript-0 2016-05-01 16:10:50 error gyp ERR! node-gyp -v v3.3.1
    javascript-0 2016-05-01 16:10:50 error gyp ERR! node -v v4.4.3
    javascript-0 2016-05-01 16:10:50 error gyp ERR! cwd /opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/node_modules/bluetooth-hci-socket/node_modules/usb
    javascript-0 2016-05-01 16:10:50 error gyp ERR! command "/usr/bin/nodejs" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.javascript/node_modules
    javascript-0 2016-05-01 16:10:50 error gyp ERR! System Linux 4.4.7-v7+
    javascript-0 2016-05-01 16:10:50 error gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:200:12)
    javascript-0 2016-05-01 16:10:50 error gyp ERR! stack at ChildProcess.emit (events.js:172:7)
    javascript-0 2016-05-01 16:10:50 error gyp ERR! stack at emitTwo (events.js:87:13)
    javascript-0 2016-05-01 16:10:50 error gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    javascript-0 2016-05-01 16:10:50 error stack Error: make failed with exit code: 2
    javascript-0 2016-05-01 16:10:50 error gyp ERR! build error
    javascript-0 2016-05-01 16:10:50 error make: *** [Release/obj.target/libusb/libusb/libusb/os/linux_udev.o] Error 1
    javascript-0 2016-05-01 16:10:50 error compilation terminated.
    javascript-0 2016-05-01 16:10:50 error ^
    javascript-0 2016-05-01 16:10:50 error #include
    javascript-0 2016-05-01 16:10:50 error ../libusb/libusb/os/linux_udev.c:40:21: fatal error: libudev.h: No such file or directory
    javascript-0 2016-05-01 16:10:21 error WARN optional dep failed, continuing xpc-connection@0.1.4
    javascript-0 2016-05-01 16:10:21 error npm
    javascript-0 2016-05-01 16:07:36 error script.js.Bluetoothscanner compile failed: SyntaxError: Unexpected token ;
    Dann erst die Anleitung gelesen und Voraussetzungen:
      ` > benötigt das node module "noble" (im Javascript Adapter eintragen) `
    ok, "noble" eingetragen, natürlich ohne "".
    javascript.0 danach wohl neustarten, oder?
      ` > globale Funktion logs() muss vorhanden sein `
    Wo bekomme ich die denn her???
    Rainer
    • ruhr70R Offline
      ruhr70R Offline
      ruhr70
      #42
      @pix:
      Danke für das Riesenskript! `
      jo. Das ist… nun ja... etwas aus dem Ruder gelaufen.
      Die Arbeit hätte ich auch in einen Adapter stecken können.
      Danke fürs testen!
      @pix:
      Habe das Skript heute installiert: Mac mini mit El Capitan, xcode vorhanden. Zuerst wollte es nicht, aber dann habe ich Bluetooth über die Menüzeile einmal aus und wieder eingeschaltet. Der Scan wurde sofort erledigt.
      Habe dann erstmal meinen Haushalt nach BT-Geräten durchsucht :lol: Ergebnis: `
      Interessant. Ich hatte es nur mit einem Pi3 getestet. Der iMac ist zu alt (BT <4). Auf dem MBP habe ich kein ioBroker.
      @pix:
      • Pulse H7 Pulsmesser: funktioniert super
      • Withings Activitee Pop: bisher keine Reaktion
      • iPhone 5s/6s: bisher keine Reaktion
      • iMac im Nebenraum: nach dem einfachen Öffnen der Systemeinstellungen sichtbar, allerdings falsche Entfernungsangabe (6.12m, tatsächlich ca. 2m). Das ist aber egal, da Scanner und iMac ja stationär. `
      Die Entfernungsangabe kannst Du kalibrieren, wenn Du das Gerät im Skript in den JSON einträgst.
      @pix:
      Manchmal allerdings kommt noch eine Fehlermeldung:
      2016-05-01 17:12:04.128  - error: message javascript.2.Bluetooth.Control_ScanOn [object Object] Could not start scanning, state is unknown (not poweredOn)
      2016-05-01 17:12:04.135  - error: Error: Could not start scanning, state is unknown (not poweredOn)
        at Noble.startScanning (/Users/pix/Documents/iobroker/node_modules/iobroker.javascript/node_modules/noble/lib/noble.js:71:17)
        at startScan (script.js.Test.BluetoothScanner:1684:11)
        at Object. <anonymous>(script.js.Test.BluetoothScanner:2061:13)
        at Object.subs.callback (/Users/pix/Documents/iobroker/node_modules/iobroker.javascript/javascript.js:1206:48)
      </anonymous>
      "Could not start scanning, state is unknown (not poweredOn)"
      Das kommt von Noble. Ist "nicht eingeschaltet".
      Warum? Auf dem Pi3 hatte ich da überhaupt kein Thema mit.
      @pix:
      oder hier, wenn man einen Channel manuel im Reiter Objekte löscht, wird er bei erneueter Suche nicht neu angelegt.
      ! `2, davon nicht erreichbar: 2 [...] Leider wurde keines der BT-Geräte mehr gefunden. ! Ist der ganze Block erledigt? D.h. es wurde nichts mehr gefunden, weil Dein AppleTV gestört hat? ! [quote] Ausserdem stört mich die Logs-Geschichte. Ich sehe meine Log Datei mit der OS X Konsole an. Da werden eh keine Farben dargestellt. Ich wünscht mir dafür eine Option, das Loggen auf Standard zu setzen. Das jeder Scan geloggt wird, lässt das Logfile auch unnötig wachsen. Auch da wünschte ich mir mehr Kontrolle. ` Die Kontrolle hats Du. ! Hab das Skript jetzt sehr überhastet veröffentlicht. Rainer weisse warum :lol: ! Es ist versehentlich mit Loglevel = "Debug2" raus. ! Wenn Du in Zeile 92: [code]var loglevel = "debug2"; // logs() - Loglevel des Scriptes (debug2, debug1, debug, info, warn, error) // benötigt den loglevel info beim Javascript Adapter [/code]` Hier den Loglevel auf "info" oder "warn" stellst, bekommst Du so gut wie nichts mehr. ! Ich selbst nutzen in den neuen kürzeren Skripts auch kein logs() mehr. ! Bei dem langen Skript war ich extrem dankbar, dass ich es innerhalb des Skripts so fein abstimmen kann. ! ~~[quote]~~ Auf deinen Hinweis, habe ich mir mal diese Mi-Armbänder angesehen. Die scheinen genau richtig für meine Anwendung zu sein (Anwesenheit). Kannst du die wirklich empfehlen? ` ` ! Das Mi habe ich selbst nicht. ! Das war ein Hinweis von simpixio: ! [http://forum.iobroker.net/viewtopic.php ... 513#p22317](http://forum.iobroker.net/viewtopic.php?f=21&amp;t=2513#p22317) ! Der Rest ist von mir. ! Generell muss man drauf achten, was man den nun scannen will. Wir reden hier von BLE. Da wirst Du normalerweise keine Macs, iPhones, usw. finden. ! Welche Geräte dauerhaft senden, hab ich am Anfang des Threads tlw. aufgeführt. ! Alle BLE Geräte, die ich gefunden habe (und bei mir waren tlw. bis zu 40) drin (die ganzen Nachbarschaft und Jogger) haben dauerhaft und stabil gesendet. Besser als mein iBeacon mit Geofency. ! Manche Geräte findet man nicht mehr, wenn man Sie für Ihren eigentlichen nutzen an einer Anwendung registriert, z.B. das Gigaset Tag. Entweder mit der Gigaset App oder als Dauerfunkfeuer für den BLE Scanner. ! Ich würde mal behaupten, Du kannst jedes BLE Gerät nehmen, also auch das Mi-Armband. `
      • ruhr70R Offline
        ruhr70R Offline
        ruhr70
        #43
        @Homoran:
        Wo bekomme ich die denn her??? `
        Ja, wenn Du ein node_modul einträgst, den Adapter neu starten.
        die Funktion logs() findest Du direkt im 2. Post.
        http://forum.iobroker.net/viewtopic.php … 513#p22194
        Die Posts 1-3 sollte man eh lesen, wenn man das Skript installiert.
        Da steht die Beschreibung drin ;-)
          #44
          @ruhr70:
          Da steht die Beschreibung drin ;-) `
          Beschreibungen werden total überbewertet :mrgreen:
          <size size="85">Außerdem versteh ich das ganze doch gar nicht 😢</size>
          Hoffentlich habe ich jetzt alles richtig gemacht; Fehler bleibt;
          javascript-0	2016-05-01 17:02:28	error	script.js.Bluetoothscanner compile failed: SyntaxError: Unexpected token ;
          Muss nach
          sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
          der RasPi neu gestartet werden?
          Hatte da allerdings folgende Meldung:
          bluez is already the newest version.
          bluez set to manually installed.
          Suggested packages:
            bluez-cups bluez-obexd
          Rainer
          • ruhr70R Offline
            ruhr70R Offline
            ruhr70
            #45
            @Homoran:
            Pi3? aktuelle Versionen von iobroker?
            Hast Du mal neu gestartet?
            Am Skript nichts verändert?
            Der Fehler könnte z.B. daherkommen, wenn ein JSON im Skript syntaktisch nicht korrekt ist.
            Auf dem Pi 3 sollte es mit installierten Bluetooth-Treiben eigentlich sehr problemlos laufen.
              #46
              @ruhr70:
              Pi3? aktuelle Versionen von iobroker? `
              Ja! Ja!
              @ruhr70:
              Hast Du mal neu gestartet? `
              iobroker ja - raspi weiß ich nicht mehr
              @ruhr70:
              Am Skript nichts verändert? `
              nö - was sollte ich als js-legastheniker denn da dran ;-)
              Na dann will ich mal den raspi nochmal starten.
              EDIT - hat nicht geholfen :(
              kann es sein, dass ich versucht hatte das Funkmodul und hmcon darauf zum laufen zu bekommen und u.a. die serielle Konsole abgeschaltet habe.
              Außerdem glaube ich, dass das hmcon install skript da etwas an gpio einstellungen manipuliert, da beim Raspi3 Teile der Einstellungen für das Funkmodul bereits für WLAN und BT genutzt wurden.
              (irgendwie so was war da :( )
              Rainer
                #47
                So, habe noch ein wenig ahnungslos, aber hoffentlich nicht ganz planlos rumgeklickt.
                Teile hatte ich im oberen Post schon reingeschrieben - jetzt wird es mehr. Für ein EDIT zu viel.
                folgendes habe ich im Skript gefunden - bis jetzt hatte ich nach debug möglichkeiten gesucht und keine Fehler im log gefunden und jetzt sehe ich, dass der Adapter anscheinend selber Fehlermeldungen ausgibt:
                Rainer
                • ruhr70R Offline
                  ruhr70R Offline
                  ruhr70
                  #48
                  @Homoran:
                  Teile hatte ich im oberen Post schon reingeschrieben - jetzt wird es mehr. Für ein EDIT zu viel. `
                  Hi Rainer,
                  schön… ;-)
                  Danke für Deine Geduld und fürs testen. Der Fehler liegt allerdings bei Dir, bzw. bei deinem NPP Versuchen ;-)
                  Die Skripte sind auf iobroker.net tlw. fehlerhaft eingepflegt. :-(
                  In Zeile 797:
                      if ((txPower < -75) || (txPower > -55)) {
                  Das < muss ein < sein, das > ein >.
                  richtig:
                  In Zeile 780 muss das & jeweils ein & sein.
                  In 780 fehlt in der Tat ein Semikolon. "Nur" einSchönheitsfehler.
                  Beim Import vom hue Skript (dynamische Szenen) sind auch Fehler mit reingekommen.
                  Das besteht auf iobroker.net quasi nur aus Fehlern, wie z.B.:
                          "hue.0.Philips_hue.wohnzimmer.kugel",
                  Das <span… hat/da/nichts/zu/suchen/und/viele/steuerzeichen/sind/auch/falsch.<br="">Da ist beim Bearbeiten der Webseite beim Skriptimport so einiges schief gegangen ;-)
                  VG
                  Michael</span…>
                    #49
                    Hallo Michael,
                    gut das wir das mit der Website schonmal kontrolliert haben. ;-)
                    ok, npp hatte ich nur "mal eben schnell" installiert und die Konfig nicht kontrolliert.
                    Muss ich mir alles nochmal ansehen und korrigieren, bevor andere meckern.
                    @ruhr70:
                    Der Fehler liegt allerdings bei Dir `
                    Damit kann ich leben.
                    Rainer
                    • ruhr70R Offline
                      ruhr70R Offline
                      ruhr70
                      #50
                      @Homoran:
                      Rainer `
                      Na da hoffe ich doch :-)
                      Kenne niemanden,d er so unermüdlich testet und hilft :-)
                      Nur an der Homepage müssen wir noch einmal ran. Wenn mir noch was auffällt, bekommst Du eine Rückmeldung. Ist mir heute Morgen nur beim Überfliegen ins Auge gesprungen, dass da Dinge drin sind, die da nicht hingehören.
                        #51
                        Bei mir läufts, npp auf UTF8 without BOP umgestellt, statt kodierung automatisch erkennen.
                        Trotzdem hat es beim Kopieren auf die Website erst einmal nicht geklappt.
                        Bin dan nicht mehr über den visuellen editor, sondern über Quelltext gegangen.
                        Jetzt scheint es zu passen.
                        Habe aber nur Zeile 797 verglichen - bin halt faul
                        EDIT:
                        nachdem jetzt keine devices gefunden werden habe ich nochmal den gesamten Thread durchgelesen.
                        ok, vielleicht habe ich ja die falschen Geräte.
                        Samsung TV steht im Keller - war noch nie angeschaltet, muss ich dann mal machen
                        Handy ist "Analog"-Handy Nokia 215
                        Mein Notebook kann angeblich auch BT 4.0 - passiert nichts, auch nicht während des selbst aktiven Scans von 2 Minuten.
                        OK, vielleicht sind es ja die falschen Geräte.
                        läuft der Scan unendlich weiter? Zur Anwesenheitserkennung UND zum Finden neuer Geräte?
                        Rainer
                        • ruhr70R Offline
                          ruhr70R Offline
                          ruhr70
                          #52
                          @Homoran:
                          EDIT:
                          OK, vielleicht sind es ja die falschen Geräte. `
                          Ja, das sind die falschen Geräte. Der Samsung TV eventuell, wenn er Bluetooth hat.
                          Im Skript ist das so eingestellt, das der Scan weiterläuft, bis 10 unterschiedliche Geräte gefunden und als Datenpunkte angelegt wurden. Die Anzahl ist einstellbar. Das Skript ist recht genügsam und frisst kaum Ressourcen. Lass einfach mal laufen. Bei mir werden auf Anhieb sechs Geräte gefunden.
                          Wenn bei Dir ein Jogger mit aktueller Fitnessuhr oder Brustgurt vorbei rennt, hast Du ihn schon einmal ;-)
                          Ansonsten werde ich mich demnächst ähnlichen Themen widmen:
                          1.) Pi3 als iBeacon/Beacon
                          2.) Pi3 als IBeacon Scanner
                          3.) Verbindung mit einem SensorTag CC2650
                          Kann man alles mit dem BLE Scanner kombinieren.
                            #53
                            Hallo Michael,
                            @ruhr70:
                            Ja, das sind die falschen Geräte. `
                            @ruhr70:
                            Wenn bei Dir ein Jogger mit aktueller Fitnessuhr oder Brustgurt vorbei rennt, `
                            Hoffnung - aber da bin ich wohl auch ein Dinosaurier;
                            Alte Polar Brustgurte herausgekramt - ohne Erfolg; aber die sind wohl auch nicht mehr "aktuell" ;-)
                            Und schon der nächste Tiefschlag:
                            Wollte todesmutig das Ganze auf dem BPi M3 ans laufen bekommen.
                            • Bluez bereits aktuelle Version, Rest installiiert. M3 rebooted, Skripte eingefügt, js.0 neu gestartet - alles rot:
                            Error: Could not start scanning, state is poweredOff (not poweredOn) at Noble.startScanning (/opt/iobroker/node_modules/iobroker.javascript/node_modules/noble/lib/noble.js:71:17) at startScan (script.js.Bluetoothscanner:1369:11) at Object. (script.js.Bluetoothscanner:1746:13) at Object.subs.callback (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:1206:48) at /opt/iobroker/node_modules/iobroker.javascript/javascript.js:541:48 at getObjectEnums (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:2430:17) at checkPatterns (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:537:17) at Object.utils.adapter.stateChange (/opt/iobroker/node_modules/iobroker.javascript/javascript.js:215:17) at Object.that.states.States.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:1973:80) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:45:30) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:263:10) at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:221:12) at Manager. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:131:20) at Manager.ondecoded (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:333:8) at Decoder. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Decoder.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20) at Decoder.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/socket.io-parser/index.js:247:12) at Manager.ondata (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/manager.js:323:16) at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15) at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at Socket.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:441:14) at WS. (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/socket.js:258:10) at WS.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/component-emitter/index.js:134:20) at WS.Transport.onPacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:143:8) at WS.Transport.onData (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transport.js:135:8) at WebSocket.ws.onmessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/lib/transports/websocket.js:132:10) at WebSocket.onMessage (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:418:14) at emitTwo (events.js:87:13) at WebSocket.emit (events.js:172:7) at Receiver.ontext (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:816:10) at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:477:18 at Receiver.applyExtensions (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:364:5) at /opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:466:14 at Receiver.flush (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:340:3) at Receiver.opcodes.1.finish (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:482:12) at Receiver.expectHandler (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:457:31) at Receiver.add (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/Receiver.js:95:24) at Socket.realHandler (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/engine.io-client/node_modules/ws/lib/WebSocket.js:800:20) at emitOne (events.js:77:13) at Socket.emit (events.js:169:7) at readableAddChunk (_stream_readable.js:153:18) at Socket.Readable.push (_stream_readable.js:111:10) at TCP.onread (net.js:531:20)
                            Wo um alles in de Welt schaltet manbei dem Teil den BT an????
                            Raiiner
                            • ruhr70R Offline
                              ruhr70R Offline
                              ruhr70
                              #54
                              Das ist doch super…
                              Ich konnte nie diesen Fehlerfall provozieren, da bei mir noble.state immer poweredOn war.
                              327_bluetooth_ble_0.4.1.js
                              Kannst Du die neue Version bitte mal probieren, ob damit der Fehler abgefangen wird?
                              Danach können wir uns um Deine exotische Hardware kümmern. ;-)
                                #55
                                @ruhr70:
                                Das ist doch super… `
                                Na, wenigstens einer, der es positiv sieht!
                                @ruhr70:
                                Kannst Du die neue Version bitte mal probieren, ob damit der Fehler abgefangen wird? `
                                Klar kann ich das!
                                Soll ich auch?
                                20:36:24.843 [info] javascript.0 Start javascript script.js.Bluetoothscanner
                                20:36:24.845 [info] javascript.0 script.js.Bluetoothscanner: --== script.js.Bluetoothscanner ==-- gestartet. Instanz: "javascript.0.", Loglevel: info
                                20:36:24.845 [info] javascript.0 script.js.Bluetoothscanner: Liste bluetoothBlacklistManufacturerData auf gültige Werte geprüft. Anzahl Einträge: 3
                                20:36:24.845 [info] javascript.0 script.js.Bluetoothscanner: Liste bluetoothBlacklistMac auf gültige Werte geprüft. Anzahl Einträge: 2
                                20:36:24.846 [info] javascript.0 script.js.Bluetoothscanner: registered 0 subscriptions and 0 schedules
                                20:36:25.844 [info] javascript.0 script.js.Bluetoothscanner: Kommando Bluetooth Scanner an: true
                                20:36:25.845 [info] javascript.0 script.js.Bluetoothscanner: noble.state ist nicht powerdOn. noble.state: poweredOff
                                ~~@ruhr70:~~
                                > Danach können wir uns um Deine exotische Hardware kümmern. ;-) `
                                Ich bitte darum :twisted:
                                Rainer
                                • ruhr70R Offline
                                  ruhr70R Offline
                                  ruhr70
                                  #56
                                  @Homoran:
                                  @ruhr70:
                                  Klar kann ich das!
                                  Soll ich auch? `
                                  Hast Du ja gemacht ;-)
                                  Also… jetzt wird es interessant.
                                  Du sagst, das Du das ausgeführt hast und es die aktuellste Version ist:?
                                  sudo apt-get install bluetooth bluez-utils libbluetooth-dev
                                  Teste mal bitte, ob hcitool installiert ist (ist in bluez-utils enthalten) und ob hcitools ein Device findet:
                                  pi@rasp31:~ $ hcitool dev
                                  Devices:
                                  	hci0	B8:27:EB:7B:99:76
                                  Du kannst auch mit dem hcitool einen Testscan machen (ein paar Sekunden Geduld):
                                  pi@rasp31:~ $ hcitool scan
                                  Scanning ...
                                  	00:1A:E8:04:16:B4	OpenStage 00:1A:E8:04:16:B4
                                  	00:24:E4:18:5F:A3	Withings Aura A2
                                  	04:0C:CE:E1:C8:39	Michaels MacBook Air
                                    #57
                                    @ruhr70:
                                    Du sagst, das Du das ausgeführt hast und es die aktuellste Version ist:? `
                                    Du glaubst mir nicht? :evil:
                                    root@bananapi:~# sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
                                    Reading package lists... Done
                                    Building dependency tree
                                    libbluetooth-dev is already the newest version.
                                    Suggested packages:
                                    The following NEW packages will be installed:
                                      bluetooth libudev-dev
                                    0 upgraded, 2 newly installed, 0 to remove and 5 not upgraded.
                                    Need to get 59.4 kB of archives.
                                    After this operation, 332 kB of additional disk space will be used.
                                    Do you want to continue? [Y/n]
                                    Get:1 http://httpredir.debian.org/debian/ jessie/main bluetooth all 5.23-2 [36.3 kB]
                                    Get:2 http://httpredir.debian.org/debian/ jessie/main libudev-dev armhf 215-17+deb8u4 [23.1 kB]
                                    Fetched 59.4 kB in 0s (106 kB/s)
                                    Selecting previously unselected package bluetooth.
                                    (Reading database ... 56285 files and directories currently installed.)
                                    Preparing to unpack .../bluetooth_5.23-2_all.deb ...
                                    Unpacking bluetooth (5.23-2) ...
                                    Selecting previously unselected package libudev-dev:armhf.
                                    Preparing to unpack .../libudev-dev_215-17+deb8u4_armhf.deb ...
                                    Unpacking libudev-dev:armhf (215-17+deb8u4) ...
                                    Setting up bluetooth (5.23-2) ...
                                    Setting up libudev-dev:armhf (215-17+deb8u4) ...
                                    @ruhr70:
                                    Teste mal bitte, ob hcitool installiert ist (ist in bluez-utils enthalten) und ob hcitools ein Device findet: `
                                    Ja, … und nein!
                                    root@bananapi:~# hcitool dev
                                    Devices:
                                    @ruhr70:
                                    Du kannst auch mit dem hcitool einen Testscan machen (ein paar Sekunden Geduld): `
                                    Nein, kann ich nicht ;-)
                                    root@bananapi:~# hcitool scan
                                    Device is not available: No such device
                                    Vielleicht doch:
                                    @ruhr70:
                                    Deine exotische Hardware `
                                    ~~@[url=http://bananapi.com/index.php/component/content/article?layout=edit&id=85:~~
                                    ~~BananaPi Website"]~~Bluetooth
                                    BT4.0 `
                                    Rainer
                                    • ruhr70R Offline
                                      ruhr70R Offline
                                      ruhr70
                                      #58
                                      @Homoran:
                                      Du glaubst mir nicht? :evil: `
                                      Naja… das hier :
                                      @Homoran:
                                      sieht anders aus, als das was ich geschrieben hatte:
                                      Wobei das auch gemein ist. In der Anleitung steht Deine Zeile.
                                      Ich meine gelesen zu haben, dass noble auf den hcitool aufsetzt. Wenn ja, dann würde es das Problem erklären.
                                      Wenn Du bluetoothctl eingibst und dann darin list.
                                      Wird dann ein Corntroler angezeigt?
                                      • ruhr70R Offline
                                        ruhr70R Offline
                                        ruhr70
                                        #59
                                        und das kannst Du auch einmal probieren:
                                        sudo service bluetooth restart
                                          #60
                                          na gut, demnächst sehe ich etwas genauer hin :(
                                          Package bluez-utils is not available, but is referred to by another package.
                                          This may mean that the package is missing, has been obsoleted, or
                                          is only available from another source
                                          However the following packages replace it:
                                            bluez
                                          E: Package 'bluez-utils' has no installation candidate
                                          @ruhr70:
                                          Wird dann ein Corntroler angezeigt? `
                                          Nö.
                                          @ruhr70:
                                          Code:
                                          sudo service bluetooth restart `
                                          Nützt auch nix:
                                          root@bananapi:~# sudo service bluetooth restart
                                          [ ok ] Stopping bluetooth: /usr/sbin/bluetoothd.
                                          [ ok ] Starting bluetooth: bluetoothd.
                                          Devices:
                                          Danke für deine Mühe, dann muss der Cubietruck am Feiertag dran glauben.
                                          Der M3 läuft mit Armbian, ich lade gerade debian und Raspbian-lite für BPi runter, falls es an der Distro liegt.
                                          Rainer
