  4. [gelöst] Fehlermeldung bei Blockly Script
    5.3k
vis
9 Beiträge 2 Kommentatoren 841 Aufrufe 1 Beobachtet
    Andre R.
    schrieb am zuletzt editiert von Andre R.
    Hallo zusammen
    hab mal wieder ne Frage. Ich habe dieses Blockly von Knuddel verwendet
     <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="S},%B!W7FjU|w+;Bi3u/" x="-662" y="-338"><field name="SCHEDULE">*/1 * * * *</field>
        <statement name="STATEMENT"><block type="comment" id="x#L9[%LY|Yrx`l)DWm|n"><field name="COMMENT">Uptime Master</field>
            <next><block type="variables_set" id="c;vRX]+MD3w~Fa4u0_oA"><field name="VAR">master_uptime_gesamt</field>
                <value name="VALUE"><block type="get_value" id="#=Ud:?8|Bc0R?oq(}{Vz"><field name="ATTR">val</field>
                    <field name="OID">rpi2.0.uptime.uptime</field></block></value>
                <next><block type="variables_set" id=":+s25++7%;E1ZPSp_bNH"><field name="VAR">master_uptime_tage</field>
                    <value name="VALUE"><block type="math_round" id="V_n,Z?87Yzo#1@Gk)B_|"><field name="OP">ROUNDDOWN</field>
                        <value name="NUM"><shadow type="math_number" id="w)m[6-o#SFO|})aX;^Sn"><field name="NUM">3.1</field></shadow>
                          <block type="math_arithmetic" id="#vPh0eWHzHbmc0{P(xGl"><field name="OP">DIVIDE</field>
                            <value name="A"><shadow type="math_number" id="bahI:FVxEi%`f[PVR#?r"><field name="NUM">1</field></shadow>
                              <block type="get_value" id="[]}_AgMQs2tS-b3SOG6:"><field name="ATTR">val</field>
                            <value name="B"><shadow type="math_number" id="cBfkqtHp/(na=hF*Xs;{"><field name="NUM">86400</field></shadow></value></block></value></block></value>
                    <next><block type="variables_set" id="xf#[c;spkxV;?_=;2t4]"><field name="VAR">master_uptime_zw</field>
                        <value name="VALUE"><block type="math_arithmetic" id="g85j0([NmkejbN]_LFQ;"><field name="OP">MINUS</field>
                            <value name="A"><shadow type="math_number" id="}H73ztKqU,dkWZ,F,i*R"><field name="NUM">1</field></shadow>
                              <block type="variables_get" id="-VqLq_~+I^S2}L3!#xzI"><field name="VAR">master_uptime_gesamt</field></block></value>
                            <value name="B"><shadow type="math_number" id="P5_|Dw(]!C*d/0LDlJX["><field name="NUM">86400</field></shadow>
                              <block type="math_arithmetic" id="8KQWiO_0+1E7KPBL`BnK"><field name="OP">MULTIPLY</field>
                                <value name="A"><shadow type="math_number" id=",I@|[8va{Mw(V#ASt9{M"><field name="NUM">1</field></shadow>
                                  <block type="variables_get" id="HYJ?9+`q-3)^O0iZJD-["><field name="VAR">master_uptime_tage</field></block></value>
                                <value name="B"><shadow type="math_number" id="@(,y`FuDg+P*5o[794U6"><field name="NUM">86400</field></shadow></value></block></value></block></value>
                        <next><block type="variables_set" id="eAJhBVv3}N8LUFKRAWGZ"><field name="VAR">master_uptime_std</field>
                            <value name="VALUE"><block type="math_round" id="/RbEc%QP!6/M9EimZe]N"><field name="OP">ROUNDDOWN</field>
                                <value name="NUM"><shadow type="math_number" id="w)m[6-o#SFO|})aX;^Sn"><field name="NUM">0</field></shadow>
                                  <block type="math_arithmetic" id="BFHl3E~ysn|,xUa5Vb8#"><field name="OP">DIVIDE</field>
                                      <block type="variables_get" id="7=o8aPA{`ENu)Ede_%B@"><field name="VAR">master_uptime_zw</field></block></value>
                                    <value name="B"><shadow type="math_number" id="6k]Nz4u+nuL.OON8Z+?j"><field name="NUM">3600</field></shadow></value></block></value></block></value>
                            <next><block type="variables_set" id=".+IdB1+tIgC(cXj^#9gr"><field name="VAR">master_uptime_zw2</field>
                                <value name="VALUE"><block type="math_arithmetic" id="Tb1}ci*dwi]?N(+VZS0*"><field name="OP">MINUS</field>
                                      <block type="variables_get" id="pl@KE2~vpoFkF~SSzk%%"><field name="VAR">master_uptime_zw</field></block></value>
                                    <value name="B"><shadow type="math_number" id="P5_|Dw(]!C*d/0LDlJX["><field name="NUM">0</field></shadow>
                                      <block type="math_arithmetic" id="pIkaJRUH0EN9i5BFh|Ou"><field name="OP">MULTIPLY</field>
                                          <block type="variables_get" id="^B.o=TuQbG!2~GNM/e-d"><field name="VAR">master_uptime_std</field></block></value>
                                        <value name="B"><shadow type="math_number" id="jHJ,OA,V7xyG1^Be^jW."><field name="NUM">3600</field></shadow></value></block></value></block></value>
                                <next><block type="variables_set" id="6GHul#I2g`ZkYC1e~C{1"><field name="VAR">master_uptime_min</field>
                                    <value name="VALUE"><block type="math_round" id="I%[WOX~v6)8yc}K1_|nS"><field name="OP">ROUNDDOWN</field>
                                          <block type="math_arithmetic" id="kqIicz=;J=5v)|+`2Vs)"><field name="OP">DIVIDE</field>
                                              <block type="variables_get" id="/E]PwFOERrG;mY.@U?fN"><field name="VAR">master_uptime_zw2</field></block></value>
                                            <value name="B"><shadow type="math_number" id=":5Jjoq2?fnn.3?nX.qu5"><field name="NUM">60</field></shadow></value></block></value></block></value>
                                    <next><block type="update" id="(g+SDiV]@I6UoHl8jE.i"><mutation delay_input="false"></mutation>
                                        <field name="OID">javascript.0.master_uptime</field>
                                        <value name="VALUE"><block type="text_join" id="|gSv+WZHIMcsYv;iY}y5"><mutation items="6"></mutation>
                                            <value name="ADD0"><block type="variables_get" id=";lH~jePSwnZZ`B9Uf9#8"><field name="VAR">master_uptime_tage</field></block></value>
                                            <value name="ADD1"><block type="text" id="_N5MntuQ3.OAGrQ,UEnV"><field name="TEXT">Tag(e),</field></block></value>
                                            <value name="ADD2"><block type="variables_get" id=".4sH_?4VFhqf^8u!M7F9"><field name="VAR">master_uptime_std</field></block></value>
                                            <value name="ADD3"><block type="text" id="V0sqG%|UzZe:%=_GTSO%"><field name="TEXT">Stunde(n),</field></block></value>
                                            <value name="ADD4"><block type="variables_get" id="~~tdGbeXHF,RXc4-gV[i"><field name="VAR">master_uptime_min</field></block></value>
                                            <value name="ADD5"><block type="text" id="1oy#IR@#^HupeI(++C48"><field name="TEXT"> Minute(n)</field></block></value></block></value></block></next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block></xml>
    und bekomme jetzt diese Warnung
    javascript.0 2019-03-29 22:18:00.007 warn at Timer.listOnTimeout (timers.js:290:5)
    javascript.0 2019-03-29 22:18:00.007 warn at tryOnTimeout (timers.js:323:5)
    javascript.0 2019-03-29 22:18:00.007 warn at ontimeout (timers.js:498:11)
    javascript.0 2019-03-29 22:18:00.007 warn at Timeout._onTimeout (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:501:7)
    javascript.0 2019-03-29 22:18:00.006 warn at /opt/iobroker/node_modules/node-schedule/lib/schedule.js:543:11
    javascript.0 2019-03-29 22:18:00.006 warn at Job.invoke (/opt/iobroker/node_modules/node-schedule/lib/schedule.js:173:10)
    javascript.0 2019-03-29 22:18:00.006 warn at Job.nodeSchedule.scheduleJob [as job] (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1181:34)
    javascript.0 2019-03-29 22:18:00.006 warn at Object.<anonymous> (script.js.umrechnen.uptime_Proxmox:12:3)
    javascript.0 2019-03-29 22:18:00.006 warn at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0 2019-03-29 22:18:00.006 warn Wrong type of javascript.0.scriptEnabled.umrechnen.uptime_Proxmox: "string". Please fix, while deprecated and will not work in next versions.
    kann mir jemand sagen an was das liegt.
    Grüße Andre
    • A Andre R.
      Hallo zusammen
      Grüße Andre
      @Andre-R sagte:
      In Zeile 12 schreibt das Skript einen String in eine Datenpunkt, der nicht vom Typ "string" ist.
        Andre R.
        kannst du mir auch evtl. sagen wie ich das ändern kann.
        Danke schonmal
        • A Andre R.
          Danke schonmal
          @Andre-R Welchen Typ hat der Datenpunkt "javascript.0.scriptEnabled.umrechnen.uptime_Proxmox" und was soll geschrieben werden ?
            Andre R.
            sorry ich hoffe das ist das was du meinst
            • A Andre R.
              @Andre-R Du hast extra einen String aufbereitet, der Datenpunkt ist aber vom Typ "Logikwert". Ändere den Datenpunkt-Typ (Art) in "Zeichenkette".
                Andre R.
                jetzt hab ich diese Fehlermeldung
                script.js.umrechnen.uptime_Proxmox: setForeignState(id=javascript.0.scriptEnabled.umrechnen.uptime_Proxmox, state={"val":"13T 9 Std 6 Min","ack":true}) - was not executed, while debug mode is active
                • A Andre R.
                  @Andre-R sagte:
                  Debug-Mode der JS-Instanz ausschalten.
                    Andre R.
                    @Andre-R sagte in Fehlermeldung bei Blockly Script:
                    vielen vielen Dank hat funktioniert
