  4. Error: ENOSPC: no space left on device, write
install fixerupdateadapter
3 Beiträge 3 Kommentatoren 1.9k Aufrufe 2 Beobachtet
  • F Offline
    fischmir
    nach ich den Installer-Fix installiert und anschließend alle Adapter ge-updated habe, startet mein iobroker nicht mehr.
    Die logs vom controller zeigen das hier:
    pi@ioBroker-RasPi:/opt/iobroker $ node node_modules/iobroker.js-controller/controller.js --logs
    2019-03-28 11:21:59.148  - info: host.ioBroker-RasPi iobroker.js-controller version 1.4.0 js-controller starting
    2019-03-28 11:21:59.155  - info: host.ioBroker-RasPi Copyright (c) 2014-2018 bluefox, 2014 hobbyquaker
    2019-03-28 11:21:59.155  - info: host.ioBroker-RasPi hostname: ioBroker-RasPi, node: v8.11.1
    2019-03-28 11:21:59.160  - info: host.ioBroker-RasPi ip addresses: 192.168.178.77 fe80::cdf3:6e27:1bba:5721
    2019-03-28 11:22:00.129  - error: host.ioBroker-RasPi Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json: SyntaxError: Unexpected end of JSON input
    2019-03-28 11:22:00.131  - error: host.ioBroker-RasPi Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/lib/objects/../../../../iobroker-data/objects.json.bak: SyntaxError: Unexpected end of JSON input
    2019-03-28 11:22:00.152  - info: host.ioBroker-RasPi  inMem-objects listening on port 9001
    2019-03-28 11:22:00.333  - info: host.ioBroker-RasPi States connected to redis: 127.0.0.1:6379
    2019-03-28 11:22:00.337  - info: host.ioBroker-RasPi InMemoryDB connected
    Cannot find view "system"
    2019-03-28 11:22:00.354  - error: host.ioBroker-RasPi _design/system missing - call node iobroker.js setup
    2019-03-28 11:22:00.383  - error: uncaught exception: Cannot convert undefined or null to object
    2019-03-28 11:22:00.386  - error: TypeError: Cannot convert undefined or null to object
        at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:863:9)
        at runCallback (timers.js:798:20)
        at tryOnImmediate (timers.js:752:5)
        at processImmediate [as _immediateCallback] (timers.js:729:5)
    2019-03-28 11:22:00.402  - error: ENOSPC: no space left on device, write
    fs.js:735
        return binding.writeBuffer(fd, buffer, offset, length, position);
        at Object.fs.writeSync (fs.js:735:20)
        at Object.fs.writeFileSync (fs.js:1309:24)
        at saveConfig (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:1897:16)
        at ObjectsInMemServer.destroy (/opt/iobroker/node_modules/iobroker.js-controller/lib/objects/objectsInMemServer.js:3088:26)
        at /opt/iobroker/node_modules/iobroker.js-controller/controller.js:2435:49
        at stopInstances (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2415:45)
        at stop (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2434:5)
        at process.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/controller.js:2614:9)
        at emitOne (events.js:116:13)
        at process.emit (events.js:211:7)
    Es gibt insgesamt 6 errors, von welchem ich jetzt nicht weiß, ob alle stimmen.
    Kennt jemand diese Meldung und kann mir sagen, was ich nun tun kann um meinen iobroker wieder ans laufen zu bekommen?
    Grüße,
    Christian
    • W Online
      W Online
      Wildbill
      Die Meldung besagt eigentlich, dass Deine SD-Karte voll ist. Wenn Du das so in die Suche oder bei Google eingibst, findest Du genug Threads. Im Normalfall wurde vergessen, das Filesystem zu vergrößern?!
      Gruss, Jürgen
      • wendy2702W Online
        wendy2702W Online
        wendy2702
        Das siehts du mit
        df -h
