  4. [gelöst] Homekit: hilfe bei Installation
    5.4k
5 Beiträge 3 Kommentatoren 1.3k Aufrufe
  • I Offline
    I Offline
    iben
    beim Versuch Homekit auf Ubuntu zu installieren erhalte ich folgende Meldung:
    root@ubuntu2cpu:/opt/iobroker# ./iobroker add homekit
    host.ubuntu2cpu install adapter homekit
    npm install iobroker.homekit --production --prefix "/opt/iobroker" (System call)
    npm http GET https://registry.npmjs.org/iobroker.homekit
    npm http 304 https://registry.npmjs.org/iobroker.homekit
    npm http GET https://registry.npmjs.org/hap-nodejs/0.2.6
    npm http GET https://registry.npmjs.org/yalm
    npm http GET https://registry.npmjs.org/yargs
    npm http 200 https://registry.npmjs.org/yargs
    npm http 304 https://registry.npmjs.org/yalm
    npm http 304 https://registry.npmjs.org/hap-nodejs/0.2.6
    npm http GET https://registry.npmjs.org/ansi-styles
    npm http GET https://registry.npmjs.org/camelcase
    npm http GET https://registry.npmjs.org/cliui
    npm http GET https://registry.npmjs.org/decamelize
    npm http GET https://registry.npmjs.org/os-locale
    npm http GET https://registry.npmjs.org/string-width
    npm http GET https://registry.npmjs.org/window-size
    npm http GET https://registry.npmjs.org/y18n
    npm http GET https://registry.npmjs.org/debug
    npm http GET https://registry.npmjs.org/node-persist
    npm ERR! not found: git
    npm ERR!
    npm ERR! Failed using git.
    npm ERR! This is most likely not a problem with npm itself.
    npm ERR! Please check if you have git installed and in your PATH.
    npm ERR! System Linux 3.19.0-25-generic
    npm ERR! command "/usr/bin/nodejs" "/usr/bin/npm" "install" "iobroker.homekit" "--production" "--prefix" "/opt/iobroker"
    npm ERR! cwd /opt/iobroker
    npm ERR! node -v v0.10.25
    npm ERR! npm -v 1.3.10
    npm ERR! code ENOGIT
    npm http 304 https://registry.npmjs.org/ansi-styles
    npm http GET https://registry.npmjs.org/color-convert
    npm http 304 https://registry.npmjs.org/camelcase
    npm http 304 https://registry.npmjs.org/y18n
    npm http 304 https://registry.npmjs.org/string-width
    npm http 304 https://registry.npmjs.org/decamelize
    npm http 304 https://registry.npmjs.org/window-size
    npm http 304 https://registry.npmjs.org/cliui
    npm http 304 https://registry.npmjs.org/os-locale
    npm http 304 https://registry.npmjs.org/debug
    npm http 304 https://registry.npmjs.org/color-convert
    npm http GET https://registry.npmjs.org/strip-ansi
    npm http GET https://registry.npmjs.org/code-point-at
    npm http GET https://registry.npmjs.org/is-fullwidth-code-point
    npm http GET https://registry.npmjs.org/lcid
    npm http GET https://registry.npmjs.org/wrap-ansi
    npm http 304 https://registry.npmjs.org/strip-ansi
    npm http 304 https://registry.npmjs.org/code-point-at
    npm http 304 https://registry.npmjs.org/lcid
    npm http 304 https://registry.npmjs.org/is-fullwidth-code-point
    npm http 304 https://registry.npmjs.org/wrap-ansi
    npm http GET https://registry.npmjs.org/invert-kv
    npm http GET https://registry.npmjs.org/ansi-regex
    npm http GET https://registry.npmjs.org/number-is-nan
    npm http 304 https://registry.npmjs.org/invert-kv
    npm http 304 https://registry.npmjs.org/ansi-regex
    npm http 304 https://registry.npmjs.org/number-is-nan
    npm http 304 https://registry.npmjs.org/node-persist
    npm ERR!
    npm ERR! Additional logging details can be found in:
    npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! not ok code 0
    host.ubuntu2cpu Cannot install iobroker.homekit: 1
    Kann mir da jemand helfen?
    Danke,
    Marco
    • N Offline
      N Offline
      nobody
      Hallo iben,
      ich hab selbst Debian und nicht ubuntu aber wenn git (Versionsmanagementsystem) nicht installiert ist, würde ich es einfach installieren.
      Das geht bei diesen beiden beiden Linux-Distributionen gleich:
      sudo apt-get install git
        aquapro
        Ohne git kann man git nicht verwenden. ;)
        War die tage schon mal die gleiche Frage, dabei steht es doch genau in der Meldung.
        Wie nobody schon schrieb, git installieren und noch einmal probieren.
        Tino
        <size size="85">BananaPi / Jessie / ioBroker deinstalliert, keine Upgradesicherheit</size>
        • I Offline
          I Offline
          iben
          Oh, Brett vorm Kopf, da ich einige Adapter am laufen habe, bin ich nicht davon ausgegangen das hinsichtlich einer Installation, etwas fehlen könnte.
          Dankeschön.
            aquapro
            Super!
            Aber genau für sowas sollte auch ein Forum da sein, wenn mal das Brett vor dem Kopf im Weg ist. :lol:
