  2. English
  3. Scripting / Logic
  5. Is there problem with Blockly after last update?
24 Beiträge 5 Kommentatoren 6.1k Aufrufe 2 Beobachtet
  • apollon77A apollon77
    Can you please show the Javascript the blockly has generated?
    ap2017
    @apollon77 said in Is there problem with Blockly after last update?:
    // Living Room Light
    schedule({astro: "goldenHour", shift: 0}, function () {
    setState("zwave.0.NODE12.SWITCH_MULTILEVEL.Level_1"/Level/, 99);
    sendTo("telegram.0", "send", {
    text: 'Light is ON'
    console.debug("telegram: " + 'Light is ON');
    schedule("30 23 * * *", function () {
    setState("zwave.0.NODE12.SWITCH_MULTILEVEL.Level_1"/Level/, 0);
    text: 'Light is OFF'
    console.debug("telegram: " + 'Light is OFF');
    • chefkoch009C chefkoch009
      @ap2017: I see you are using node: v6.14.3
      Have you tried to make an update to latest stable version of node? I think you should try at min 8.x, but 10.x should be better. There have been many significant changes between the major versions.
      However, give it a try and please post your result.
      chefkoch009
      ap2017
      schrieb am zuletzt editiert von ap2017
      @chefkoch009 said in Is there problem with Blockly after last update?:
      chefkoch009
      What is the procedure to update node? I see so many different ones on the forum.
      A 1 Antwort Letzte Antwort
      • A ap2017
        chefkoch009
        ap2017
        @chefkoch009 received node update procedure https://forum.iobroker.net/topic/21802/node-js-update will try and let you know
          @ap2017 sagte in Is there problem with Blockly after last update?:
          I hate when it fixes by itself..
          I do too!
          But it works. So have fun with it.
          Cobby12
          @Homoran said in Is there problem with Blockly after last update?:
          paris airports transfers
          I do too!
          It really works
