  4. [Erledigt]Yahka Adapter unter Proxmox Debian
proxmoxyahkaerror
5 Beiträge 2 Kommentatoren 808 Aufrufe 3 Beobachtet
  • slumaS Offline
    slumaS Offline
    sluma
    schrieb am zuletzt editiert von sluma
    Ich bin dabei ein NUC6 mit ioBroker einzurichten.
    Es läuft auf dem NUC Proxmox mit einer Debian9-VM.
    Bekomme den Yahka Adapter nicht zum laufen.
    undefined2019-03-05 08:55:32.957 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856
    2019-03-05 08:55:32.958 - error: Caught by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
    2019-03-05 08:55:32.958 - error: Caught by controller[0]: ^
    2019-03-05 08:55:32.958 - error: Caught by controller[0]: TypeError: Cannot read property 'generate' of undefined
    2019-03-05 08:55:32.958 - error: Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856:45)
    2019-03-05 08:55:32.958 - error: Caught by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
    2019-03-05 08:55:32.959 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
    2019-03-05 08:55:32.959 - error: host.ioBrokerStable instance system.adapter.yahka.0 terminated with code 1 ()
    2019-03-05 08:55:32.959 - info: host.ioBrokerStable Do not restart adapter system.adapter.yahka.0 because disabled or deleted
    2019-03-05 08:55:33.843 - info: host.ioBrokerStable object change system.adapter.yahka.0
    2019-03-05 08:55:33.856 - info: host.ioBrokerStable instance system.adapter.yahka.0 started with pid 9709
    2019-03-05 08:55:34.318 - error: Caught by controller[0]: /opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: CommunityTypes.InputVoltageAC.UUID = UUID.generate('CommunityTypes:usagedevice:InputVoltageAC');
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: ^
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: TypeError: Cannot read property 'generate' of undefined
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: at module.exports (/opt/iobroker/node_modules/iobroker.yahka/node_modules/hap-nodejs-community-types/types.js:856:45)
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object.importHAPCommunityTypesAndFixes (/opt/iobroker/node_modules/iobroker.yahka/main.js:382:26)
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object../yahka.homekit-bridge.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:1764:25)
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
    2019-03-05 08:55:34.319 - error: Caught by controller[0]: at Object../yahka.ioBroker-adapter.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:2326:16)
    2019-03-05 08:55:34.320 - error: Caught by controller[0]: at Object. (/opt/iobroker/node_modules/iobroker.yahka/main.js:271:17)
    2019-03-05 08:55:34.320 - error: Caught by controller[0]: at Object../main.ts (/opt/iobroker/node_modules/iobroker.yahka/main.js:290:30)
    2019-03-05 08:55:34.320 - error: Caught by controller[0]: at __webpack_require__ (/opt/iobroker/node_modules/iobroker.yahka/main.js:20:30)
    2019-03-05 08:55:34.320 - error: Caught by controller[0]: at /opt/iobroker/node_modules/iobroker.yahka/main.js:84:18
    2019-03-05 08:55:34.320 - error: host.ioBrokerStable instance system.adapter.yahka.0 terminated with code 1 ()
    2019-03-05 08:55:34.320 - info: host.ioBrokerStable Restart adapter system.adapter.yahka.0 because enabled
    EDIT: Ich konnte "material - Material widgets for ioBroker.vis." auch nicht über Admin installieren. Es war gar nicht aufgeführt. Habe es dann über den Terminal (Konsole) installiert.
    btw: Wo finde ich via FTP auf dem NUC den ioBroker Ordner ? 🙄
    Intel NUC6CAYH mit Debian & Proxmox
    • apollon77A Offline
      Kann es sein das DU gerade Stable nutzt und früher "Latest" als Repo genutzt hast? vismaterial ist nur in ltest und denke ahka im Stable vllt auch nicht aktuell.
      • slumaS Offline
        slumaS Offline
        sluma
        Bin nun vom Raspi mit einem Total Backup über den backitup Adapter umgezogen.
        Mit der Anleitung 👍
        Funktioniert alles bis auf den Yahka Adapter 😤
          Und was meckert er jetzt? Nochmal neu von Github installiert?
          • slumaS Offline
            slumaS Offline
            sluma
            Es kamen die gleichen Fehler !
            Bin jetzt runter auf 0.8.2 und siehe da, alles löppt 👍
            Ich hatte vorher aber auch 0.9.x installiert gehabt.
