  4. Javascript Adapter und viele WARN Meldungen
javascript script engine
4 Beiträge 3 Kommentatoren 955 Aufrufe 2 Beobachtet
  • Merlin123M Offline
    Merlin123M Offline
    Merlin123
    Mir ist aufgefallen, dass seit kurzem mein Log mit Meldungen von Javascript geflutet wird. Hatte 4.1.5 drauf, jetzt 4.1.7, aber noch das gleiche.
    Was sollen mir denn die Meldungen sagen?
    javascript.0	2019-03-03 13:32:14.334	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-03-03 13:32:14.334	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-03-03 13:32:14.333	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-03-03 13:32:14.333	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-03-03 13:32:14.332	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-03-03 13:32:14.331	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-03 13:32:14.330	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-03-03 13:32:14.330	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-03-03 13:32:14.329	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-03-03 13:32:14.328	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-03-03 13:32:14.328	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-03-03 13:32:14.327	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-03-03 13:32:14.326	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-03-03 13:32:14.325	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-03-03 13:32:14.325	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-03-03 13:32:14.317	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-03-03 13:32:14.316	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-03-03 13:32:14.315	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-03-03 13:32:14.315	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-03-03 13:32:14.314	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-03-03 13:32:14.314	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-03-03 13:32:14.313	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:32:14.313	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-03-03 13:32:14.312	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-03-03 13:32:14.312	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:32:14.311	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:32:14.311	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-03-03 13:32:14.310	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-03-03 13:32:14.309	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-03-03 13:32:14.309	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:32:14.308	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-03-03 13:32:14.308	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:32:14.307	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:32:14.306	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-03-03 13:32:14.306	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-03-03 13:32:14.305	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:32:14.305	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-03-03 13:32:14.304	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0	2019-03-03 13:32:14.303	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-03-03 13:32:14.303	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-03-03 13:32:14.302	warn	at Object.<anonymous> (script.js.common.Flur_EG_Tag:10:5)
    javascript.0	2019-03-03 13:32:14.301	warn	at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1302:25)
    javascript.0	2019-03-03 13:32:14.301	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-03-03 13:32:14.297	warn	State "knx.0.Beleuchtung.Licht_Hue_Status.Status_LichtHue_Flur_EG" not found
    knx.0	2019-03-03 13:31:21.311	debug	system.adapter.admin.0: logging true
    javascript.0	2019-03-03 13:31:03.542	warn	at TCP.onread (net.js:601:20)
    javascript.0	2019-03-03 13:31:03.541	warn	at Socket.Readable.push (_stream_readable.js:208:10)
    javascript.0	2019-03-03 13:31:03.541	warn	at readableAddChunk (_stream_readable.js:250:11)
    javascript.0	2019-03-03 13:31:03.540	warn	at addChunk (_stream_readable.js:263:12)
    javascript.0	2019-03-03 13:31:03.540	warn	at Socket.emit (events.js:211:7)
    javascript.0	2019-03-03 13:31:03.539	warn	at emitOne (events.js:116:13)
    javascript.0	2019-03-03 13:31:03.538	warn	at Socket.realHandler (/opt/iobroker/node_modules/ws/lib/WebSocket.js:825:20)
    javascript.0	2019-03-03 13:31:03.538	warn	at Receiver.add (/opt/iobroker/node_modules/ws/lib/Receiver.js:103:24)
    javascript.0	2019-03-03 13:31:03.537	warn	at Receiver.expectHandler (/opt/iobroker/node_modules/ws/lib/Receiver.js:499:31)
    javascript.0	2019-03-03 13:31:03.536	warn	at Receiver.finish (/opt/iobroker/node_modules/ws/lib/Receiver.js:541:12)
    javascript.0	2019-03-03 13:31:03.536	warn	at Receiver.flush (/opt/iobroker/node_modules/ws/lib/Receiver.js:347:3)
    javascript.0	2019-03-03 13:31:03.535	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:508:14
    javascript.0	2019-03-03 13:31:03.534	warn	at Receiver.applyExtensions (/opt/iobroker/node_modules/ws/lib/Receiver.js:371:5)
    javascript.0	2019-03-03 13:31:03.534	warn	at /opt/iobroker/node_modules/ws/lib/Receiver.js:536:18
    javascript.0	2019-03-03 13:31:03.533	warn	at Receiver.ontext (/opt/iobroker/node_modules/ws/lib/WebSocket.js:841:10)
    javascript.0	2019-03-03 13:31:03.532	warn	at WebSocket.emit (events.js:214:7)
    javascript.0	2019-03-03 13:31:03.532	warn	at emitTwo (events.js:126:13)
    javascript.0	2019-03-03 13:31:03.531	warn	at WebSocket.onMessage (/opt/iobroker/node_modules/ws/lib/WebSocket.js:442:14)
    javascript.0	2019-03-03 13:31:03.531	warn	at WebSocket.ws.onmessage (/opt/iobroker/node_modules/engine.io-client/lib/transports/websocket.js:146:10)
    javascript.0	2019-03-03 13:31:03.530	warn	at WS.Transport.onData (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:137:8)
    javascript.0	2019-03-03 13:31:03.530	warn	at WS.Transport.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/transport.js:145:8)
    javascript.0	2019-03-03 13:31:03.529	warn	at WS.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:31:03.528	warn	at WS.<anonymous> (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:268:10)
    javascript.0	2019-03-03 13:31:03.528	warn	at Socket.onPacket (/opt/iobroker/node_modules/engine.io-client/lib/socket.js:451:14)
    javascript.0	2019-03-03 13:31:03.527	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:31:03.526	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:31:03.526	warn	at Manager.ondata (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:322:16)
    javascript.0	2019-03-03 13:31:03.525	warn	at Decoder.add (/opt/iobroker/node_modules/socket.io-parser/index.js:246:12)
    javascript.0	2019-03-03 13:31:03.525	warn	at Decoder.Emitter.emit (/opt/iobroker/node_modules/socket.io-parser/node_modules/component-emitter/index.js:134:20)
    javascript.0	2019-03-03 13:31:03.524	warn	at Decoder.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:31:03.524	warn	at Manager.ondecoded (/opt/iobroker/node_modules/socket.io-client/lib/manager.js:332:8)
    javascript.0	2019-03-03 13:31:03.523	warn	at Manager.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:31:03.522	warn	at Manager.<anonymous> (/opt/iobroker/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-03-03 13:31:03.522	warn	at Socket.onpacket (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:228:12)
    javascript.0	2019-03-03 13:31:03.521	warn	at Socket.onevent (/opt/iobroker/node_modules/socket.io-client/lib/socket.js:270:10)
    javascript.0	2019-03-03 13:31:03.521	warn	at Socket.Emitter.emit (/opt/iobroker/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-03-03 13:31:03.520	warn	at Socket.<anonymous> (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-03-03 13:31:03.520	warn	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3705:37)
    javascript.0	2019-03-03 13:31:03.519	warn	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:364:25)
    javascript.0	2019-03-03 13:31:03.518	warn	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:963:38)
    javascript.0	2019-03-03 13:31:03.518	warn	at Object.<anonymous> (script.js.common.Flur_EG_Tag:6:5)
    javascript.0	2019-03-03 13:31:03.516	warn	at setStateDelayed (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1302:25)
    javascript.0	2019-03-03 13:31:03.515	warn	at Object.setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1258:20)
    javascript.0	2019-03-03 13:31:03.489	warn	State "knx.0.Beleuchtung.Licht_Hue_Status.Status_LichtHue_Flur_EG" not found
    Beta-Tester
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      Wenn du das Skript mal deaktivierst „Flur_EG_Tag“, wird es dann besser?
      • Merlin123M Merlin123
        @Merlin123 sagte in Javascript Adapter und viele WARN Meldungen:
        gibt es diesen Datenpunkt noch?
        Merlin123M 1 Antwort Letzte Antwort
          Merlin123M Offline
          Merlin123M Offline
          Merlin123
          schrieb am zuletzt editiert von Merlin123
          @Homoran sagte in Javascript Adapter und viele WARN Meldungen:
          Ah... Danke für den Hinweis... Der heißt jetzt anders :)
          Pass ich gleich mal an.
          Hatte gedacht, der wird automatisch umbenannt. Kommt vom KNX Adapter. Jetzt sollte es wieder gehen :)
          Beta-Tester
