getting started with visualisations
That works nicely, thanks.
Out of curiosity, is there any way to force subscription?
I have a case where I have mutiple values on a sensor, and I'd like to be able to just specify auto clicker wordunscrambler jumblesolverthe sensor oid for the widget, and have the implementation figure out the values.
@Bluefox I do struggle with the following instruction:
"replace index.html and edit.html replace files in /opt/iobroker/iobroker-data/files/vis/index.html and edit.html with files from /opt/iobroker/node_modules/iobroker.vis/www/index.html.original and edit.html.original. Change the file /opt/iobroker/iobroker-data/files/vis/cache.manifest. No matter what, just one symbol to trigger the browser to load files anew. The files must be smaller than 200k. If you have got wrong files, so they are definitly largen than 400k."I understood ..
Replace the following two files /opt/iobroker/iobroker-data/files/vis/index.html & /opt/iobroker/iobroker-data/files/vis/edit.html with
/opt/iobroker/node_modules/iobroker.vis/www/index.html.original and /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original.in other words..
cp /opt/iobroker/node_modules/iobroker.vis/www/index.html.original /opt/iobroker/iobroker-data/files/vis/index.html
cp /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original /opt/iobroker/iobroker-data/files/vis/edit.htmlIs this correct ?
If yes, in my installation
/opt/iobroker/node_modules/iobroker.vis/www/index.html.original and /opt/iobroker/node_modules/iobroker.vis/www/edit.html.original do not exist!
