  4. MQTT und Websocket Problem
mqtt problem
1 Beiträge 1 Kommentatoren 493 Aufrufe 1 Beobachtet
  • L Offline
    loi83
    Hallo zusammen
    Wenn ich im MQTT Adapter "Use Websocket" aktiviere, wird der Adapter Rot und im Log kommt folgende Meldung:
    2019-02-14 07:43:31.031 - error: mqtt.0 uncaught exception: listen EADDRINUSE :::1884
    2019-02-14 07:43:31.031 - error: mqtt.0 Error: listen EADDRINUSE :::1884
    at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    at listenInCluster (net.js:1401:12)
    at Server.listen (net.js:1485:7)
    at startServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1018:28)
    at _constructor (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1129:13)
    at new MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1138:7)
    at MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:12:47)
    at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.mqtt/main.js:133:64)
    at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4632:61)
    at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    2019-02-14 07:43:31.847 - info: mqtt.0 terminating
    2019-02-14 07:43:31.994 - error: Caught by controller[0]: { Error: listen EADDRINUSE :::1884
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at Server.setupListenHandle [as _listen2] (net.js:1360:14)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at listenInCluster (net.js:1401:12)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at Server.listen (net.js:1485:7)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at startServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1018:28)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at _constructor (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1129:13)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at new MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:1138:7)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at MQTTServer (/opt/iobroker/node_modules/iobroker.mqtt/lib/server.js:12:47)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at adapter.getForeignStates (/opt/iobroker/node_modules/iobroker.mqtt/main.js:133:64)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at that.states.getStates (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:4632:61)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: at Socket. (/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:157:27)
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: errno: 'EADDRINUSE',
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: code: 'EADDRINUSE',
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: syscall: 'listen',
    2019-02-14 07:43:31.995 - error: Caught by controller[0]: address: '::',
    2019-02-14 07:43:31.996 - error: Caught by controller[0]: port: 1884 }
    2019-02-14 07:43:31.996 - error: host.iO-broker instance system.``
    Kann mir da jemand helfen?
    Gruß Michi
