  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Ошибки драйвера SQL
Ошибки драйвера SQL
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
24 Beiträge 9 Kommentatoren 12.5k Aufrufe
  • I Offline
    I Offline
    instalator
    при попвтке обновится до 1.4.0.
    В итоге не обновляется
    $ ./iobroker upgrade sql
    host.Server-PC Adapter "system.adapter.sql.0" is stopped.
    npm install iobroker.sql --production --prefix "C:/ioBroker" (System call)
    npm
    WARN
    deprecated
    node-uuid@1.4.7: use uuid module instead
    gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    Error: Can't find Python executable "python", you can set the PYTHON env variable.
    gyp
    ERR!
    stack
    at failNoPython (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:449:14)
    gyp
    ERR!
    stack
    at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\configure.js:404:11
    gyp
    ERR!
    stack
    at FSReqWrap.oncomplete (fs.js:82:15)
    gyp
    ERR!
    System
    Windows_NT 6.1.7601
    gyp
    ERR!
    command
    "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "rebuild"
    gyp
    ERR!
    cwd
    C:\ioBroker\node_modules\iobroker.sql\node_modules\sql-client\node_modules\inote-util\node_modules\mmmagic
    gyp
    ERR!
    node -v
    v4.6.2
    gyp
    ERR!
    node-gyp -v
    v3.4.0
    gyp
    ERR!
    not ok
    node-pre-gyp ERR! Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v3.1.8/node-v46-win32-ia32.tar.gz node-pre-gyp ERR! Pre-built binaries not found for sqlite3@3.1.8 and node@4.6.2 (node-v46 ABI) (falling back to source compile with node-gyp)
    ! gyp
    ERR!
    configure error
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    stack
    gyp
    ERR!
    System
    Windows_NT 6.1.7601
    gyp
    ERR!
    command
    "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32"
    gyp
    ERR!
    cwd
    gyp
    ERR!
    node -v
    v4.6.2
    gyp
    ERR!
    node-gyp -v
    v3.4.0
    gyp
    ERR!
    not ok
    node-pre-gyp
    ERR!
    build error
    node-pre-gyp
    ERR!
    stack
    Error: Failed to execute 'node-gyp.cmd configure --fallback-to-build --module=C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\lib\binding\node-v46-win32-ia32' (1)
    node-pre-gyp
    ERR!
    stack
    at ChildProcess. <anonymous>(C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
    node-pre-gyp
    ERR!
    stack
    at emitTwo (events.js:87:13)
    node-pre-gyp
    ERR!
    stack
    at ChildProcess.emit (events.js:172:7)
    node-pre-gyp
    ERR!
    stack
    at maybeClose (internal/child_process.js:854:16)
    node-pre-gyp
    ERR!
    stack
    at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
    node-pre-gyp
    ERR!
    System
    Windows_NT 6.1.7601
    node-pre-gyp
    ERR!
    command
    "C:\Program Files\nodejs\node.exe" "C:\ioBroker\node_modules\iobroker.sql\node_modules\sqlite3\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
    node-pre-gyp
    ERR!
    cwd
    node-pre-gyp
    ERR!
    node -v
    v4.6.2
    node-pre-gyp
    ERR!
    node-pre-gyp -v
    v0.6.31
    node-pre-gyp
    ERR!
    not ok
    npm
    WARN
    optional dep failed, continuing
    sqlite3@3.1.8
    npm
    ERR!
    Windows_NT 6.1.7601
    npm
    ERR!
    argv
    "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\bin\npm-cli.js" "install" "iobroker.sql" "--production" "--prefix" "C:/ioBroker"
    npm
    ERR!
    node
    v4.6.2
    npm
    ERR!
    npm
    v2.15.11
    npm
    ERR!
    code
    ELIFECYCLE
    ! npm
    ERR!
    mmmagic@0.4.5 install: node-gyp rebuild
    npm
    ERR!
    Exit status 1
    npm
    ERR!
    npm
    ERR!
    Failed at the mmmagic@0.4.5 install script 'node-gyp rebuild'.
    npm
    ERR!
    This is most likely a problem with the mmmagic package,
    npm
    ERR!
    not with npm itself.
    npm
    ERR!
    Tell the author that this fails on your system:
    npm
    ERR!
    node-gyp rebuild
    npm
    ERR!
    You can get information on how to open an issue for this project with:
    npm
    ERR!
    npm bugs mmmagic
    npm
    ERR!
    Or if that isn't available, you can get their info via:
    npm
    ERR!
    npm
    ERR!
    npm owner ls mmmagic
    npm
    ERR!
    There is likely additional logging output above.
    ! npm
    ERR!
    Please include the following file with any support request:
    npm
    ERR!
    C:\ioBroker\node_modules\iobroker\npm-debug.log
    ERROR: host.Server-PC Cannot install iobroker.sql: 1
    ERROR: process exited with code 25</anonymous>
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • sigmaS Offline
      sigmaS Offline
      sigma
      SQL History 1.5.6. Коннект к внешнему серверу PostgreSQL.
      В логе постоянно сыпятся ошибки:
      sql.0	2017-10-04 10:41:45.719	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898623, 'Subscribe [Equipment/Relays/R0045]', true, 1, 0);: error: duplicate key value violates unique constraint "ts
      sql.0	2017-10-04 10:41:45.499	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898620, 'Subscribe [Equipment/Relays/R0040]', true, 1, 0);: error: duplicate key value violates unique constraint "ts
      sql.0	2017-10-04 10:41:45.467	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898619, 'Subscribe [Equipment/Relays/R0037]', true, 1, 0);: error: duplicate key value violates unique constraint "ts
      sql.0	2017-10-04 10:41:45.151	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898611, 'Subscribe [Equipment/Relays/R0029]', true, 1, 0);: error: duplicate key value violates unique constraint "ts
      sql.0	2017-10-04 10:41:45.149	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898610, 'Subscribe [Equipment/Relays/R0028]', true, 1, 0);: error: duplicate key value violates unique constraint "ts
      sql.0	2017-10-04 10:41:44.944	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898603, 'Subscribe [Equipment/Buttons/B0017]', true, 1, 0);: error: duplicate key value violates unique constraint "t
      sql.0	2017-10-04 10:41:44.890	error	Cannot insert INSERT INTO ts_string (id, ts, val, ack, _from, q) VALUES(1, 1507102898602, 'Subscribe [Equipment/Buttons/B0016]', true, 1, 0);: error: duplicate key value violates unique constraint "t
      Каким образом он умудряется выдать две записи в 1 мс?
      • BluefoxB Offline
        BluefoxB Offline
        Настрой Минимальный интервал
        • F Offline
          ford7
          Периодически слетает настройка истории в sql (активно) только для данной переменной.
          Подскажите, что бы это значило?
