  4. Module version mismatch. Expected 48, got 57.
    6.8k
3 Beiträge 2 Kommentatoren 522 Aufrufe
  • J Offline
    jsc
    Liebe ioBroker Gemeinde,
    ich habe ein Problem mit dem KM200 Adapter bzw. dort mit wohl dem npm Paket mcrypt. Fehlermeldung ist folgende:
    ! host.raspberrypi 2019-02-03 20:46:26.164 info Restart adapter system.adapter.km200.0 because enabled
    ! host.raspberrypi 2019-02-03 20:46:26.164 error instance system.adapter.km200.0 terminated with code 1 ()
    ! host.raspberrypi 2019-02-03 20:46:26.164 error Caught by controller[0]: at Module._compile (module.js:577:32)
    ! host.raspberrypi 2019-02-03 20:46:26.164 error Caught by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/mcrypt/index.js:3:37)
    ! host.raspberrypi 2019-02-03 20:46:26.164 error Caught by controller[0]: at bindings (/opt/iobroker/node_modules/mcrypt/node_modules/bindings/bindings.js:84:48)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at require (internal/module.js:20:19)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at Module.require (module.js:504:17)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at Function.Module._load (module.js:445:3)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at tryModuleLoad (module.js:453:12)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at Module.load (module.js:494:32)
    ! host.raspberrypi 2019-02-03 20:46:26.163 error Caught by controller[0]: at Object.Module._extensions..node (module.js:604:18)
    ! host.raspberrypi 2019-02-03 20:46:26.162 error Caught by controller[0]: at Error (native)
    ! host.raspberrypi 2019-02-03 20:46:26.162 error Caught by controller[0]: Error: Module version mismatch. Expected 48, got 57.
    ! host.raspberrypi 2019-02-03 20:46:26.162 error Caught by controller[0]: ^
    ! host.raspberrypi 2019-02-03 20:46:26.162 error Caught by controller[0]: throw e
    ! host.raspberrypi 2019-02-03 20:46:26.159 error Caught by controller[0]: /opt/iobroker/node_modules/mcrypt/node_modules/bindings/bindings.js:91</anonymous>
    Im raspberry bekomme ich auf npm view mcrypt version folgende Antwort:
    ! Update available 4.6.1 → 6.7.0 │
    ! │ Run npm i -g npm to update
    Was hat nun die 48 bzw. die 57 mit den Versionen des mcrypt zu tun. Bzw. ist das alles falsch gedacht? Hat irgendjemand eine Hilfestellung?
    Vielen Dank und Grüße
    Jan
    • apollon77A Offline
      Da geht nicht um mcrypt.
      Einige Module haben native Teile und werden daher beim installieren auf jedem System neu kompiliert. Wenn man dann die nodejs Version ändert wird es inkompatibel. Und das sagt der Fehler.
      npm rebuild
      Is your friend
      Gesendet vom Handy …
      • J Offline
        jsc
        Perfekt. Hat nach dem bebuild und(!) einem iobroker restart funktioniert :-D
        Danke!
