  4. [gelöst]Zigbee Adapter lässt sich nicht installieren
    6.7k
6 Beiträge 2 Kommentatoren 1.2k Aufrufe
    Skydream
    Moin,
    habe heute meinen cc2531 bekommen und wollte "mal eben" den Zigbee Adapter dazu installieren….pustekuchen.
    Die Installation endet mit einem:
    compilation terminated.
    make: *** [Release/obj.target/serialport/src/serialport_unix.o] Error 1
    gyp
     ERR! build error
    gyp
    ERR! stack Error: `make` failed with exit code: 2gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
    gyp ERR! stack     at emitTwo (events.js:106:13)
    gyp
     ERR! stack     at ChildProcess.emit (events.js:191:7)gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
    gyp ERR! System Linux 4.14.49-unRAID
    gyp
     ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"gyp ERR! cwd /opt/iobroker/node_modules/serialport
    gyp ERR! node -v v6.14.3
    gyp
     ERR! node-gyp -v v3.4.0gyp ERR! not ok
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 (node_modules/bufferutil):npm WARN optional SKIPPING OPTIONAL DEPENDENCY: bufferutil@1.1.0 install: `node-gyp rebuild`
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: Exit status 1
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 (node_modules/utf-8-validate):
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: utf-8-validate@1.1.0 install: `node-gyp rebuild`
    npm ERR! Linux 4.14.49-unRAID
    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.zigbee" "--production" "--prefix" "/opt/iobroker"
    npm ERR! node v6.14.3
    npm ERR! npm  v3.10.10
    npm ERR! code ELIFECYCLE
    npm ERR! serialport@6.2.2 install: `prebuild-install || node-gyp rebuild`
    npm ERR! Exit status 1
    npm ERR!
    npm ERR! Failed at the serialport@6.2.2 install script 'prebuild-install || node-gyp rebuild'.
    npm ERR! Make sure you have the latest version of node.js and npm installed.
    npm ERR! If you do, this is most likely a problem with the serialport package,
    npm ERR! not with npm itself.
    npm ERR! Tell the author that this fails on your system:
    npm ERR!     prebuild-install || node-gyp rebuild
    npm ERR! You can get information on how to open an issue for this project with:
    npm ERR!     npm bugs serialport
    npm ERR! Or if that isn't available, you can get their info via:
    npm ERR!     npm owner ls serialport
    npm ERR! There is likely additional logging output above.
    npm ERR! Please include the following file with any support request:npm ERR!     /opt/iobroker/npm-debug.log
    npm ERR! code 1
    host.7d365858df26 install adapter zigbee
    ERROR: host.7d365858df26 Cannot install zigbee
    ERROR: process exited with code 13
    Vollständiges Log unter: https://www.dropbox.com/s/rylf3ihembnix … l.log?dl=0
    Es handelt sich um einen Dockercontainer.
    Ich bin kein Linux experte drum steinige man mich nicht gleich….. "nodejs -v" liefert ein "not found"
    Das war aber schon immer so und hat auch noch nie gestört...muss ich das noch installieren??
    Ansonsten habe ich diverse andere Adapter laufen und es gab bisher nie eine Problem mit der Installation.
    Hat jemand einen Tip für mich?
    Gruss
    Sky
    • paul53P Offline
      @Skydream:
      @Skydream:
      Das war aber schon immer so und hat auch noch nie gestört…muss ich das noch installieren?? `
      Das sollte nicht erforderlich sein.
      node -v
      sollte eine Version >= 8.12 liefern.
        Skydream
        Hmmm….ich zieh mir mal die Eselsmütze auf.
        Wie update ich das?
        Wie gesagt ist ein Docker Container auf AlpinLinux Basis...erstellt von Bluefox. :)
        D.h. wenn es die 8 sein muss währe es am einfachsten Bluefox aktualisiert den Docker und verweist auf "mhart/alpine-node:8"
        Ist es sicher das es an der Node/npm Version liegt?
        Gruss
        Sky
        • paul53P Offline
          @Skydream:
          Ist es sicher das es an der Node/npm Version liegt? `
          Nein.
            Skydream
            Hab es….
            Die entscheide Meldung war
            src/serialport_unix.cpp:24:26: fatal error: linux/serial.h: No such file or directory
            nach einem
            apk add --no-cache linux-headers
            lies sich auch der Adapter installieren.
            Danke dir Tante Google :D
            Sky
            • paul53P Offline
              @Skydream:
              nach einem
              apk add –no-cache linux-headers
              lies sich auch der Adapter installieren. `
              Dann markiere bitte das Thema im Betreff des ersten Beitrags als [gelöst].
