  4. Fehler beim Dash- und Telegramm Adapter
    6.7k
3 Beiträge 2 Kommentatoren 298 Aufrufe 1 Beobachtet
    derrapf
    Hi alle
    Ich habe IOBroker auf einen Rock64 portiert.
    Beim Dash Button Adapter (0.3.1) und bei Telegramm (1.3.6) habe ich noch Probleme. Beim Dash Butto kommt immer wrong ELF class: ELFCLASS32
    host.ioBroker-Rock64	2019-01-18 01:27:29.332	error	instance system.adapter.amazon-dash.0 terminated with code 3 (Adapter disabled or invalid config)
    Caught	2019-01-18 01:27:29.332	error	by controller[0]: at Module.load (module.js:565:32)
    Caught	2019-01-18 01:27:29.332	error	by controller[0]: at Object.Module._extensions..js (module.js:663:10)
    Caught	2019-01-18 01:27:29.332	error	by controller[0]: at Module._compile (module.js:652:30)
    Caught	2019-01-18 01:27:29.332	error	by controller[0]: at Object. <anonymous>(/opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/pcap.js:3:21)
    Caught	2019-01-18 01:27:29.332	error	by controller[0]: at require (internal/module.js:11:18)
    Caught	2019-01-18 01:27:29.331	error	by controller[0]: at Module.require (module.js:596:17)
    Caught	2019-01-18 01:27:29.331	error	by controller[0]: at Function.Module._load (module.js:497:3)
    Caught	2019-01-18 01:27:29.331	error	by controller[0]: at tryModuleLoad (module.js:505:12)
    Caught	2019-01-18 01:27:29.331	error	by controller[0]: at Module.load (module.js:565:32)
    Caught	2019-01-18 01:27:29.330	error	by controller[0]: at Object.Module._extensions..node (module.js:681:18)
    Caught	2019-01-18 01:27:29.330	error	by controller[0]: Error: /opt/iobroker/node_modules/iobroker.amazon-dash/node_modules/pcap/build/Release/pcap_binding.node: wrong ELF class: ELFCLASS32
    amazon-dash.0	2019-01-18 01:27:29.278	error	adapter disabled</anonymous>
    Beim Telegramm Adapter habe ich folgenden Fehler:
    2019-01-18 00:41:30.718  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:31.095  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:31.490  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:31.854  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:32.199  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:32.547  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:32.891  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:33.238  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:33.586  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:33.932  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    2019-01-18 00:41:34.286  - [31merror[39m: telegram.0 polling_error:ETELEGRAM, ETELEGRAM: 401 Unauthorized
    Hat jemand einen heissen Tip?
    Node ist v8.11.1
    Nodejs ist v8.11.1
    Gruss Ralf
    • apollon77A Offline
      Telegram … was könnte unauthorized heissen? ... normalerweise ein falsches Passwort oder username
      Dash: bitte nochmal neu installieren. Da scheint beim kompilieren was nicht korrekt zu sein. Ggf im iobroker Ordner ein „npm rebuild“
      Gesendet vom Handy ...
        derrapf
        Habe jetzt einen neuen Bot erzeugt und eingetragen. Geht jetzt. Leider ist mir immer noch unklar warum es auf einmal nicht mehr ging, denn ich hatte an diesem Bot nie etwas geändert. Egal.
        Jetzt gehts wieder.
        DashButton hab ich auch rausgeworfen und neu installiert.
        Hier bleiben leider die Fehlermeldungen die Gleichen.
        Gruss Ralf
