  4. Javascript Error im Log
    5.8k
5 Beiträge 2 Kommentatoren 412 Aufrufe
  • NegaleinN Offline
    NegaleinN Offline
    Negalein
    Hallo
    Seit gestern bekomm ich im Log immer wieder einige Javascript Fehler angezeigt.
    Was könnte das sein?
    javascript.0	2019-01-16 13:45:05.912	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.912	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:05.912	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:05.911	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:05.910	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.910	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:05.910	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:05.910	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:05.910	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:05.909	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:05.909	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:05.908	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:05.907	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:05.900	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.900	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:05.900	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:05.900	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:05.899	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.899	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:05.899	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:05.899	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:05.899	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:05.899	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:05.899	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:05.898	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:05.897	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:05.260	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.260	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:05.260	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:05.259	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:05.259	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.259	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:05.259	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:05.259	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:05.259	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:05.259	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:05.259	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:05.258	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:05.257	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:05.249	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.249	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:05.248	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:05.248	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:05.248	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:05.248	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:05.248	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:05.248	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:05.248	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:05.248	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:05.248	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:05.247	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:05.247	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:04.610	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:04.610	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:04.610	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:04.610	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:04.610	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:04.610	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:04.610	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:04.610	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:04.610	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:04.609	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:04.609	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:04.608	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:04.608	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:04.599	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:04.599	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:04.599	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:04.599	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:04.599	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:04.598	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:04.598	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:04.598	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:04.598	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:04.598	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:04.598	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:04.597	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:04.597	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.919	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.919	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.919	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.919	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.919	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.919	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.919	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.919	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.919	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.918	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:03.918	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.917	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.916	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.906	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.906	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.906	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.906	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.906	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.906	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.906	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.906	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.906	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.906	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:03.905	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.905	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.905	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.839	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.839	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.839	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.839	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.839	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.839	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.839	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.839	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.839	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.839	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:03.838	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.837	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.837	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.827	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.827	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.827	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.827	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.827	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.827	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.826	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.826	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.826	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.826	error	at Object. <anonymous>(script.js.common.Wetter_2:12:169)
    javascript.0	2019-01-16 13:45:03.826	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.825	error	script.js.common.Wetter_2: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.824	error	script.js.common.Wetter_2: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.754	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.754	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.754	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.754	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.754	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.753	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.753	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.753	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.753	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.753	error	at Object. <anonymous>(script.js.common.Wetter_3:18:204)
    javascript.0	2019-01-16 13:45:03.753	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.752	error	script.js.common.Wetter_3: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.752	error	script.js.common.Wetter_3: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.742	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.742	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.742	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.742	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)
    javascript.0	2019-01-16 13:45:03.741	error	at Socket.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.741	error	at Socket. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/lib/states/statesInMemClient.js:52:30)
    javascript.0	2019-01-16 13:45:03.741	error	at Object.change (/opt/iobroker/node_modules/iobroker.js-controller/lib/adapter.js:3425:37)
    javascript.0	2019-01-16 13:45:03.741	error	at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:349:25)
    javascript.0	2019-01-16 13:45:03.741	error	at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:720:38)
    javascript.0	2019-01-16 13:45:03.741	error	at Object. <anonymous>(script.js.common.Wetter_3:18:204)
    javascript.0	2019-01-16 13:45:03.741	error	Error in callback: TypeError: Cannot read property 'val' of undefined
    javascript.0	2019-01-16 13:45:03.740	error	script.js.common.Wetter_3: Please disable that setting or use "getState" with a callback, e.g.: getState("daswetter.0.NextDaysDetailed.Location_1.Day_1.Hour_1.symbol_value", (err, state) => { ... });
    javascript.0	2019-01-16 13:45:03.740	error	script.js.common.Wetter_3: The "getState" method cannot be used synchronously, because the adapter setting "Do not subscribe to all states on start" is enabled.
    javascript.0	2019-01-16 13:45:03.664	error	at Manager.Emitter.emit (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-emitter/index.js:133:20)
    javascript.0	2019-01-16 13:45:03.664	error	at Manager. <anonymous>(/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/node_modules/component-bind/index.js:21:15)
    javascript.0	2019-01-16 13:45:03.664	error	at Socket.onpacket (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:236:12)
    javascript.0	2019-01-16 13:45:03.664	error	at Socket.onevent (/opt/iobroker/node_modules/iobroker.js-controller/node_modules/socket.io-client/lib/socket.js:278:10)</anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous></anonymous>
    ° Fixer ---> iob fix
    • H Offline
      homecineplexx
      welche javascript adapter version hast du installiert?
      • NegaleinN Offline
        NegaleinN Offline
        Negalein
        @homecineplexx:
        welche javascript adapter version hast du installiert? `
        4.0.7
        Kann es mit dem Alexa-Adapter zusammenhängen?
        Hab den gestern auf 2.0.0 upgedatet.
        • H Offline
          homecineplexx
          hast du etwas in deinem Wtter_3 script geändert?
          • NegaleinN Offline
            NegaleinN Offline
            Negalein
            @homecineplexx:
            Nein, das ist unverändert!
