  2. Русский
  3. ioBroker
  4. Ошибка
  5. ioBroker ошибки
  6. Ошибки драйвера javascript
Geplant Angeheftet Gesperrt Verschoben ioBroker ошибки
24 Beiträge 6 Kommentatoren 11.2k Aufrufe
  • I Offline
    I Offline
    instalator
    @Bluefox:
    @instalator:
    Новая ошибочка выскочила:
    request(options, function (error, response, body, callback) {
    if (!error && response.statusCode == 200) {
    log ('ЦБ ОШИБКА - ' +response.statusCode);
    ! host-Server-PC 2016-02-12 19:09:10 error instance system.adapter.javascript.0 terminated with code 6 (uncaught exception)
    ! TypeError: 2016-02-12 19:09:10 error at TCP.onread (net.js:528:27)
    ! TypeError: 2016-02-12 19:09:10 error at Socket.socketOnData [as ondata] (http.js:1584:20)
    ! TypeError: 2016-02-12 19:09:10 error at HTTPParser.parserOnHeadersComplete [as onHeadersComplete] (http.js:122:23)
    ! TypeError: 2016-02-12 19:09:10 error at HTTPParser.parserOnIncomingClient [as onIncoming] (http.js:1689:21)
    ! TypeError: 2016-02-12 19:09:10 error at ClientRequest.emit (events.js:95:17)
    ! TypeError: 2016-02-12 19:09:10 error at Request.onRequestResponse (C:\ioBroker\node_modules\iobroker.javascript\node_modules\request\request.js:898:22)
    ! TypeError: 2016-02-12 19:09:10 error at Redirect.onResponse (C:\ioBroker\node_modules\iobroker.javascript\node_modules\request\lib\redirect.js:94:13)
    ! TypeError: 2016-02-12 19:09:10 error at Request.emit (events.js:95:17)
    ! TypeError: 2016-02-12 19:09:10 error at self.callback (C:\ioBroker\node_modules\iobroker.javascript\node_modules\request\request.js:199:22)
    ! TypeError: 2016-02-12 19:09:10 error at Request._callback (script.js.Валюты:39:42)
    ! TypeError: 2016-02-12 19:09:10 error Cannot read property 'statusCode' of undefined
    ! uncaught 2016-02-12 19:09:10 error exception: Cannot read property 'statusCode' of undefined `
    Как выглядит весь кусок скрипта? Сделай так
    request(options, function (error, response, body) {
            if (!error && response && response.statusCode == 200) {
            else {
    	        log ('ЦБ ОШИБКА - '  + (response ? response.statusCode : (error || body)));
    `var request = require('request');
    ! schedule("* * * * ", function () {//40 16 * * * ""
    parsevalute();
    ! function parsevalute(){
    var urlcb = 'http://www.cbr.ru/scripts/XML_daily.asp?date_req';
    log('Идем на сайт ЦБ - '+urlcb);
    var options = {
    url: urlcb,
    headers: {
    'User-Agent': 'Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/42.0.2311.135 Safari/537.36',
    'Content-Type': 'application/x-www-form-urlencoded'
    // Отправка данных методом POST.
    if (!error/
    && response.statusCode == 200*/) {
    // log('Код ответа от сервера'+response.statusCode);
    log('Ответ от ЦБ: '+body);
    // Парсим данные
    var Valute = body.match(/<charcode>(.)</CharCode>/g);
    var Nominal = body.match(/<nominal>(.
    )</Nominal>/g);
    var Name = body.match(/<name>(.)</Name>/g);
    var Value = body.match(/<value>(.
    )</Value>/g);
    var result = [];
    for(var i = 0; i < Valute.length-1; i++) {
    result.push({
    Valute: Valute[i].replace(/<charcode>/g, "").replace(/</CharCode>/g, ""),
    Nominal: Nominal[i].replace(/<nominal>/g, "").replace(/</Nominal>/g, ""),
    Name: Name[i].replace(/<name>/g, "").replace(/</Name>/g, ""),
    Value: Value[i].replace(/<value>/g, "").replace(/[,]+/g, '.').replace(/</Value>/g, "")
    //Course = parseFloat(result[i].Value)/parseFloat(result[i].Nominal);
    createState('Valuta.'+Valute[i].replace(/<charcode>/g, "").replace(/</CharCode>/g, ""), '');
    setState ('Valuta.'+Valute[i].replace(/<charcode>/g, "").replace(/</CharCode>/g, ""), (parseFloat(result[i].Value)/parseFloat(result[i].Nominal)));
        else {
    }</charcode></charcode></value></name></nominal></charcode></value></name></nominal></charcode>`[/i][/i][/i][/i][/i][/i][/i][/i][/i][/i]
    Высокий уровень Децибел вреден для здоровья!
    http://blog.instalator.ru/
    • F Offline
      ford7
      Заглянул в лог после обновления, возможно и раньше было
      ! javascript-0 2016-10-01 07:34:13.756 info received all states
      ! javascript-0 2016-10-01 07:34:13.727 info received all objects
      ! javascript-0 2016-10-01 07:34:12.844 info requesting all objects
      ! javascript-0 2016-10-01 07:34:12.843 info requesting all states
      ! javascript-0 2016-10-01 07:34:12.802 info └── xmlbuilder@4.2.1 (lodash@4.16.2)
      ! javascript-0 2016-10-01 07:34:12.802 info ├── sax@1.2.1
      ! javascript-0 2016-10-01 07:34:12.802 info xml2js@0.4.17 opt/iobroker/node_modules/iobroker.javascript/node_modules/xml2js
      ! javascript-0 2016-10-01 07:34:06.722 error http 200 https://registry.npmjs.org/lodash/-/lodash-4.16.2.tgz
      ! javascript-0 2016-10-01 07:34:06.722 error npm
      ! javascript-0 2016-10-01 07:34:06.534 error http GET https://registry.npmjs.org/lodash/-/lodash-4.16.2.tgz
      ! javascript-0 2016-10-01 07:34:06.534 error npm
      ! javascript-0 2016-10-01 07:34:06.482 error http 200 https://registry.npmjs.org/lodash
      ! javascript-0 2016-10-01 07:34:06.482 error npm
      ! javascript-0 2016-10-01 07:34:05.264 error https://registry.npmjs.org/lodash
      ! javascript-0 2016-10-01 07:34:05.262 error http GET
      ! javascript-0 2016-10-01 07:34:05.262 error npm
      ! javascript-0 2016-10-01 07:34:05.006 error https://registry.npmjs.org/sax
      ! javascript-0 2016-10-01 07:34:05.006 error 304
      ! javascript-0 2016-10-01 07:34:05.005 error
      ! javascript-0 2016-10-01 07:34:05.005 error http
      ! javascript-0 2016-10-01 07:34:05.004 error
      ! javascript-0 2016-10-01 07:34:05.000 error npm
      ! javascript-0 2016-10-01 07:34:04.984 error https://registry.npmjs.org/xmlbuilder
      ! javascript-0 2016-10-01 07:34:04.982 error 304
      ! javascript-0 2016-10-01 07:34:04.979 error
      ! javascript-0 2016-10-01 07:34:04.978 error http
      ! javascript-0 2016-10-01 07:34:04.977 error
      ! javascript-0 2016-10-01 07:34:04.973 error npm
      ! javascript-0 2016-10-01 07:34:04.092 error http GET https://registry.npmjs.org/sax
      ! javascript-0 2016-10-01 07:34:04.091 error npm
      ! javascript-0 2016-10-01 07:34:04.065 error http GET https://registry.npmjs.org/xmlbuilder
      ! javascript-0 2016-10-01 07:34:04.065 error npm
      ! javascript-0 2016-10-01 07:34:03.735 error http 304 https://registry.npmjs.org/xml2js
      ! javascript-0 2016-10-01 07:34:03.735 error npm
      ! javascript-0 2016-10-01 07:34:02.652 error http GET https://registry.npmjs.org/xml2js
      ! javascript-0 2016-10-01 07:34:02.651 error
      ! javascript-0 2016-10-01 07:34:02.651 error npm
      ! javascript-0 2016-10-01 07:34:01.870 info npm install xml2js –production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      ! javascript-0 2016-10-01 07:34:01.856 info └── q@1.4.1
      ! javascript-0 2016-10-01 07:34:01.856 info ping@0.2.0 opt/iobroker/node_modules/iobroker.javascript/node_modules/ping
      ! javascript-0 2016-10-01 07:34:01.404 error https://registry.npmjs.org/q
      ! javascript-0 2016-10-01 07:34:01.403 error http 200
      ! javascript-0 2016-10-01 07:34:01.401 error
      ! javascript-0 2016-10-01 07:34:01.395 error npm
      ! javascript-0 2016-10-01 07:34:00.230 error http GET https://registry.npmjs.org/q
      ! javascript-0 2016-10-01 07:34:00.220 error
      ! javascript-0 2016-10-01 07:34:00.215 error npm
      ! javascript-0 2016-10-01 07:33:59.906 error http 304 https://registry.npmjs.org/ping
      ! javascript-0 2016-10-01 07:33:59.906 error npm
      ! javascript-0 2016-10-01 07:33:58.953 error http GET https://registry.npmjs.org/ping
      ! javascript-0 2016-10-01 07:33:58.952 error npm
      ! javascript-0 2016-10-01 07:33:58.037 info npm install ping --production --prefix "/opt/iobroker/node_modules/iobroker.javascript" (System call)
      ! javascript-0 2016-10-01 07:33:57.985 info starting. Version 3.0.10 in /opt/iobroker/node_modules/iobroker.javascript
        PavelMV
        Помогите. Что-то с драйвером javascript.
        есть скрипт WoL:
        ! createState('GetAdmin.WOL', '');
        ! var wol = require('wake_on_lan');
        ! on({id: 'javascript.0.GetAdmin.WOL', change: 'any'}, function (obj) {
        ! if(obj.newState.val !== ''){
        ! wol.wake(obj.newState.val);
        ! log(obj.newState.val);
        Скрипт брал на форуме.
        При запуске начинает перезапускаться драйвер javascript и ничего не работает.
        Выключаю скрипт - ошибок нет.
        • I Offline
          I Offline
          instalator
          @PavelMV:
          есть скрипт WoL:
          Выключаю скрипт - ошибок нет. `
          Разабрался? данный код работает без проблем.
