  4. Circle-knob -> verschiedene Farben Wert abhängig
    5.3k
2 Beiträge 1 Kommentatoren 520 Aufrufe
    dos1973
    ich nutze das "hqwidgets Circle-knob" um mir meine Luftfeuchtigkeit anzuzeigen.
    derzeit habe ich 3 stück übereinander liegen und zeige diese via Sichtbarkeit an oder aus, abhängig der Werte.
    Somit habe ich 18 von den Dinger auf der Seite… :-(
    gibt es einen Trick die Farbe abhängig des Wertes zu formatieren?
    kleiner 65 grün
    größer 65 gelb
    größer 75 rot
    [{"tpl":"tplHqCircle","data":{"g_fixed":false,"g_visibility":true,"g_css_font_text":false,"g_css_background":false,"g_css_shadow_padding":false,"g_css_border":false,"g_gestures":false,"g_signals":false,"g_last_change":false,"visibility-cond":">","visibility-val":"79","visibility-groups-action":"hide","oid":"javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.humidity","min":"0","max":"100","digits":"0","step":"1","is_comma":true,"displayPrevious":"true","signals-cond-0":"==","signals-val-0":true,"signals-icon-0":"/vis/signals/lowbattery.png","signals-icon-size-0":0,"signals-blink-0":false,"signals-horz-0":0,"signals-vert-0":0,"signals-hide-edit-0":false,"signals-cond-1":"==","signals-val-1":true,"signals-icon-1":"/vis/signals/lowbattery.png","signals-icon-size-1":0,"signals-blink-1":false,"signals-horz-1":0,"signals-vert-1":0,"signals-hide-edit-1":false,"signals-cond-2":"==","signals-val-2":true,"signals-icon-2":"/vis/signals/lowbattery.png","signals-icon-size-2":0,"signals-blink-2":false,"signals-horz-2":0,"signals-vert-2":0,"signals-hide-edit-2":false,"lc-type":"last-change","lc-is-interval":true,"lc-is-moment":false,"lc-format":"","lc-position-vert":"top","lc-position-horz":"right","lc-offset-vert":0,"lc-offset-horz":0,"lc-font-size":"12px","lc-font-family":"","lc-font-style":"","lc-bkg-color":"","lc-color":"","lc-border-width":"0","lc-border-style":"","lc-border-color":"","lc-border-radius":10,"lc-zindex":0,"descriptionLeft":"humidity","readOnly":true,"hideNumber":true,"color":"#89312a","bgcolor":"rgba(60, 60, 60, 20)","linecap":true,"anticlockwise":false,"thickness":"0.3","visibility-oid":"javascript.0.lmair.temp-sensoren.channel10-wohnzimmer.humidity"},"style":{"left":"23px","top":"735px","width":"36px","height":"45px","z-index":"20","color":"#acacac","font-family":"RobotoCondensed-Light"},"widgetSet":"hqwidgets"}]
      dos1973
      Falls jemadn ebenfalls sucht…
      Lösung sind die „justGage Widgets“
      Können als Donat eingestellt werden, mit 3 Farben, abhängig zu den Werten.
