  4. [gelöst] telegram adapter polling_error
    1.7k
6 Beiträge 4 Kommentatoren 2.4k Aufrufe 2 Beobachtet
    micha86
    ich weiß leider nicht seit wann, aber mein Log wird von telegram polling_error überschwemmt:
    telegram.0	2019-01-09 11:32:13.492	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:32:06.779	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:32:00.006	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:53.284	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:46.483	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:39.768	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:33.055	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:26.340	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:19.616	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:12.898	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:31:06.179	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:30:59.461	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:30:52.747	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:30:46.032	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    telegram.0	2019-01-09 11:30:39.318	error	polling_error:ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
    Folgendes ist bei mir im Einsatz:
    Telegram Adapter: 1.3.5
    Node: v8.13.0
    Nodejs: v8.13.0
    npm: 6.4.1
    Zugriff auf den Chat_bot von: 2x Smartphone und dem iobroker telegram adapter
    Auch nach einem reboot gibt es keine Besserung.
    Woran könnte das liegen?
    Besten Dank
    Michael
    • wendy2702W Offline
      wendy2702W Offline
      wendy2702
      Gab hier mal einen Lösungsvorschlag: viewtopic.php?t=8326#p88429
        micha86
        es lag scheinbar an etwas was ich nicht genau sagen kann :)
        Ich habe mehrere andere Fehler im Log behoben gehabt und mein Container neu erstellt, jetzt läuft alles wieder ohne Fehlermeldungen.
        Danke dir trotzdem.
        Beste Grüße
        Michael
          timtaylor
          ich habe aktuell das gleiche Problem.
          elegram.0
          2022-10-23 08:54:35.060	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:54:27.511	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:54:19.828	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:54:12.274	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:54:04.725	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:57.124	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:49.538	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:41.959	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:34.424	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:26.841	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:19.285	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:11.591	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          telegram.0
          2022-10-23 08:53:04.036	warn	polling_error: ETELEGRAM, ETELEGRAM: 409 Conflict: terminated by other getUpdates request; make sure that only one bot instance is running
          Ich habe jedoch nur eine Instanz laufen.
          Telegram Adapter: 1.14.1
          Node: v16.18.0
          Nodejs: v18.18.0
          npm: 8.19.2
          Gibt es hierzu einen Lösungsvorschlag?
          Vielen Dank im Voraus!
          Holger
          • T timtaylor
            elegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            telegram.0
            Node: v16.18.0
            Nodejs: v18.18.0
            npm: 8.19.2
            Holger
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @timtaylor sagte in [gelöst] telegram adapter polling_error:
            Seit wann hast Du diese Meldungen ?
            Wenn erst seit heute wäre die einfachste Lösung den Browsercache zu leeren.
            Falls dann immernoch Warnmeldungen kommen mal den Adapter neu starten und/oder die Kiste auf der Du iob nutzt rebooten.
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              timtaylor
              @djmarc75
              Danke für Deine Antwort. Die Meldungen sind schon länger da. Ich habe jetzt aber mal einen neuen API Key in Telegram generiert. Nun ist die Meldung weg.
